Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
20 registered members (A_Privateer, Char Baby, blufeb95, ArrestMeRedZ, carlprop, chemman, 2 invisible), 1,274 guests, and 55 spiders.
Topics306,079
Posts5,286,953
Members71,596
Page 1 of 3 1 2 3
Smith & Wesson Model 66 - Old or New? #5398604 04/09/20 04:35 PM
R
RonRonnster Offline OP
R
Ever since shooting my grandfather's Smith & Wesson .357 revolver I've always wanted to own a S&W revolver. I'm obsessed with the Model 66 in either polished or brushed nickel. Does S&W still manufacture the Model 66? Is there a newer alternative based off of the Model 66? I'm a casual shooter, so I could look at a used model, either vintage or late model. Any specific years or models to keep an eye out for?
Thanks all for your input! Here's basically what my grandfather's .357 looked liked, except this has polished nickel finish that I like.
[Linked Image]
- 2007 GMC Yukon XL Denali - 6.2L / 81k mi.
- 1998 Chev K1500 4x4 - 5.7L / 155k mi.
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398614 04/09/20 04:42 PM
JohnnyJohnson Offline
Have one of those it has a 3" barrel and its a Lew Horton ported. Sweet shooting gun.
2004 Corolla 140116
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398641 04/09/20 05:01 PM
CT8 Offline
S&W makes the nicest revolvers. The new stuff is good. Be picky about the old stuff some are just good others are great. I have a Mod 10 that works really good..
2015 F150 2.7
2018 F350 6.2
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398642 04/09/20 05:02 PM
H
hatt Offline
H
If Smith has an old version and a new version the answer is always old. I have a 2-1/2 inch 66. They don't make them like they use to.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398651 04/09/20 05:09 PM
R
ripcord Offline
R
The 66 and 19 (blued version) was discontinued in the late nineties but was reintroduced more recently with a slightly longer barrels than before.
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398680 04/09/20 05:58 PM
M
Mr_Joe Offline
M
I always like older stuff in good shape, if you can find it.
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398691 04/09/20 06:15 PM
Slick17601 Offline
Go with a 686.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Smith & Wesson Model 66 - Old or New? [Re: hatt] #5398712 04/09/20 06:49 PM
B
bsmithwins Offline
B
The old S&W guns are better made with tighter fit and finish. The lockhole is an abomination.
BSW
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398725 04/09/20 07:05 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
An old 66, if slightly used, would be pretty great. Shoot .38 spl through it and enjoy.
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398727 04/09/20 07:07 PM
R
R
I'm kind of partial to the older stuff - partially because I think older stuff is just cooler (mostly purchasing this gun to collect it) but I also think there's something to be said for the way they made things back in the day. I'm going to check some local gun shops for anything. Does anyone use a good online source for purchasing used firearms? I really don't shop for guns much. Last gun I purchased was a SIG semi-auto at a local Home and Ranch store.
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398735 04/09/20 07:23 PM
N
nwjones18 Offline
N
Model 66's are all stainless. the earliest ones like you have pictured have the matching stainless rear sight. Newer ones (still old) have a black rear sight. Someone has polished the one pictured as well to give it a more nickel like appearance. Model 19 is the same gun except its either blued or nickle. Model 67 is the same gun but 38 special only. When it comes to S&W revolvers I only like pre-lock stuff, not that the new stuff is bad, I just hate the lock.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398739 04/09/20 07:34 PM
W
Wurlitzer Offline
W
The gun in the picture you posted is an N-frame. Correction, the 66 is a K-frame.
Other N-frames with a similar appearance are models: 27, 28, 29, and 629, with the 629 being a stainless .44 mag.
586s and 686s are similar looking L-frames, blue and stainless respectively.
The model 19 is an even smaller, yet still aesthetic also a K-frame.
With S&W revolvers the older manufactures are more more collectable and some would argue better quality. Do some quick research on what a "pinned and recessed" S&W is. Pinned and recessed Smiths are generally pre-1982 manufactures. If you pick a Smith up that's pinned and recessed, you may not know the exact year of its manufacture, but you at least know that you have a classic.
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398740 04/09/20 07:36 PM
shanneba Offline
Yes they still make the model 66. It is stainless steel.
http://www.smith-wesson.com/firearms/model-66
The model 19 is the same K frame and was available in blue or nickle.
http://www.smith-wesson.com/firearms/model-19-classic
The S&W K frame was designed for the 38 special, later was used for the 357 magnum.
Later they introduces a slightly larger L frame, it would be a model 586 in blue or 686 in stainless.
2003 BMW 330Ci
2013 HD Sportster XL1200C
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398755 04/09/20 08:06 PM
J
jhellwig Offline
J
A friend of mine has a 66 that was from his dad when he was the town cop. It is a nice fitting gun in my large hands. I want to have one of my own but only ever see the rubber grip ones.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Smith & Wesson Model 66 - Old or New? [Re: RonRonnster] #5398756 04/09/20 08:08 PM
E
Elkins45 Offline
E
The older (non-lock) 66s are not going to be found for cheap unless they are shot loose, banged up or have a cracked forcing cone. The current production 66 has a 4.2” barrel, tensioned barrel and internal lock. Purists don’t care for the new guns because they are different, but they do come with a lifetime service policy so if it’s not a good specimen then S&W will fix it for you.
The new iteration of the 66 has a different forcing cone than the old one so there’s less of a chance of cracking. Because it’s built on the 38 (K) frame it’s lighter and handier than the L frame 686. If you plan to shoot mostly 38 special with only occasional 357 then the 66 would be my choice. If you want to shoot a lot of full power magnums then consider a 686. You can get a seven shot version of it as well.
Page 1 of 3 1 2 3
