Oil Drain vs Extraction
by js1956 - 05/30/20 08:08 PM
Toro SR Won't Stop Running
by jkasch - 05/30/20 08:05 PM
Lexus RX350 Oil Filter Housing Question (with pic)
by CrackyWainwright - 05/30/20 07:57 PM
Oil Filter and Coolant Question
by maverickfhs - 05/30/20 07:33 PM
Second change on rebuilt LS
by KirklanC - 05/30/20 07:05 PM
Certified Used Toyota; 8 miles.
by simple_gifts - 05/30/20 05:47 PM
Motul Specific LL01-FE 5w-30 for BMW S55
by sharpmoney - 05/30/20 04:36 PM
Thinking of Buying Compressor
by Mr_Luke - 05/30/20 04:16 PM
Fiat 500 transmission fluid type
by oddrodtodd - 05/30/20 03:53 PM
Help with Riding Mower for Small Yard
by YardWork - 05/30/20 03:51 PM
The ole’ robin egg passed
by 53' Stude - 05/30/20 03:33 PM
Left OR Right?
by MolaKule - 05/30/20 01:46 PM
Space X launch
by MrQuackers - 05/30/20 01:33 PM
Rotella Truck 5W-30 Disco'ed at Home Depot
by josephp732 - 05/30/20 01:17 PM
320K mileage - recommendations?
by joshuawesl - 05/30/20 12:36 PM
ISO Sprint sim
by pkunk - 05/30/20 11:44 AM
2001 Mazda Miata, timing belt
by frankbee3 - 05/30/20 11:15 AM
jrow96, Kotsos, sharpmoney, Dermented, Twostick
71580 Registered Users
98 registered members (Astro14, 53' Stude, bbhero, Alain2, 55hambone, 13 invisible), 2,166 guests, and 27 spiders.
Topics306,062
Posts5,285,787
Members71,580
Automated ABS brake system bleed #5398382 04/09/20 12:07 PM
DIY4quality Offline OP
I'd like to confirm my understanding of the bleed process when you have a scanner that supports ABS Automated Bleed.
Step 1: Bleed the brakes in the standard manner (whichever method you choose).
Step 2: Use the ABS Automated Bleed feature in your scanner to cycle the ABS. The pump action will replace the old brake fluid in the ABS components with the new brake fluid in the main circuit from Step 1.
Step 3: Bleed the brakes again in the standard manner to remove the old brake fluid the ABS injected into the main circuit from Step 2.
Is this correct? Very tedious!
Re: Automated ABS brake system bleed [Re: DIY4quality] #5398393 04/09/20 12:13 PM
U
UG_Passat Offline
U
On VW's, it is a guided system that requires you to constantly monitor the brake fluid level so it doesn't run dry and introduce more air, pump the brakes, and bleed the caliper per the guided instructions.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Automated ABS brake system bleed [Re: DIY4quality] #5398439 04/09/20 01:07 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Utoh, just bled my accord without cycling ABS. Ive heard that it sould be done, but I was under the impression that the cycling was more essential if ABS components were replaced due to remnant air bubbles. Might be incorrect. Is this always best practice per the vendors' FSM?
Re: Automated ABS brake system bleed [Re: DIY4quality] #5398469 04/09/20 01:48 PM
Yah-Tah-Hey Offline
I've replaced brake fluid every two years on my 04 Camry with ABS using Russell Speed Bleeders without a problem.
Re: Automated ABS brake system bleed [Re: DIY4quality] #5398507 04/09/20 02:19 PM
L
LazyDog Offline
L
The bleeding process will probably vary depending on which car you have and if you have a scanner that will allow you to turn on the ABS pump.
VW and other brands have their on or specific scanner that tells you what to do at each step.
Re: Automated ABS brake system bleed [Re: DIY4quality] #5398716 04/09/20 06:55 PM
E
eljefino Offline
E
This is one of those times you've got to follow directions (eg model specific forums) as each is different.
My prius will refuse to leave park it it detects low brake pressure in the rear lines due to poor bleeding. Would hate to "brick" a car doing it wrong.
