Certified Used Toyota; 8 miles.
by simple_gifts - 05/30/20 05:47 PM
Motul Specific LL01-FE 5w-30 for BMW S55
by sharpmoney - 05/30/20 04:36 PM
Thinking of Buying Compressor
by Mr_Luke - 05/30/20 04:16 PM
Fiat 500 transmission fluid type
by oddrodtodd - 05/30/20 03:53 PM
Help with Riding Mower for Small Yard
by YardWork - 05/30/20 03:51 PM
The ole’ robin egg passed
by 53' Stude - 05/30/20 03:33 PM
Left OR Right?
by MolaKule - 05/30/20 01:46 PM
Space X launch
by MrQuackers - 05/30/20 01:33 PM
Rotella Truck 5W-30 Disco'ed at Home Depot
by josephp732 - 05/30/20 01:17 PM
320K mileage - recommendations?
by joshuawesl - 05/30/20 12:36 PM
ISO Sprint sim
by pkunk - 05/30/20 11:44 AM
2001 Mazda Miata, timing belt
by frankbee3 - 05/30/20 11:15 AM
3M tape removal
by loneryder - 05/30/20 10:31 AM
Which string trimmer
by DeafBrad - 05/30/20 10:26 AM
Conventional Oil Benefits
by Bogdon - 05/30/20 07:38 AM
I'm finally retired!
by grampi - 05/30/20 07:20 AM
2020 Equinox 1.5t
by IMPALA08 - 05/30/20 07:05 AM
jrow96, Kotsos, sharpmoney, Dermented, Twostick
71580 Registered Users
87 registered members (4WD, 53' Stude, 830Lee, 928, 2010Civic, AandPDan, 9 invisible), 2,322 guests, and 39 spiders.
Topics306,057
Posts5,285,727
Members71,580
Page 1 of 3 1 2 3
Oil for 2015 Yukon XL Denali 6.2 #5398336 04/09/20 11:17 AM
Strjock81 Offline OP
Newer to me, had oil changed at dealer with AC Delco 0w-20 it’s whole life til now. I’ve done the diffs and trans and transfer case. Have about 1800 miles til I do the oil change. I’m curious if anyone has any suggestions in particular for this engine? It gets driven very easily but does tow a boat or trailer once in a while. It’s not just a short tripper either it gets to temp for a while most times it’s run.
Plan on keeping it a long time so I want to treat it right. I like Amsoil and Schaeffer products and they’re easy to get for me. But I’m open to anything else if there’s a particular oil that might be ideally suited to this engine. Price really isn’t that big of a factor I’m more of a peace of mind person and want the best.
Also not that worried about fraction of a point of a mpg difference when using different oils so since these engines use a higher viscosity oil in other applications I’m open or even favorable to going to a high quality 0w-30.
Thanks!
2016 White Town and Country Touring
2015 White Yukon XL Denali
2014 White Ram 2500 CCSB 4x4 Cummins Bighorn
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398369 04/09/20 11:48 AM
Z
zfasts03 Offline
Z
I am running Amsoil SS 0w-20 in my `16 Suburban with the L83 5.3L that is working out well for me.
I believe both engines were designed with 0w-20 in mind. Not sure anything heavier is necessary, unless you are in death valley pulling up the steepest inclines with the maximum load, then I think I would move up to a Xw-30.
Keep in mind it does have an oil cooler and an 8 qt. sump. Someone a while back was doing UOA comparing 0w-20 and 5w-30 and wear seemed to be the same.
By the way the Amsoil SS doesn't officially meet the Dexos1gen2 spec.
Some would say (and I may also) your better just buying whatever 0w-20 Dexos1gen2 oil is cheapest and follow the OLM.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398389 04/09/20 12:11 PM
DriveHard Offline
I run 0W-40 in mine...not sure why you would choose otherwise. I just do yearly changes...which usually means about 30% life left on the OLM.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398408 04/09/20 12:27 PM
L
LDM Offline
L
Just changed mine last month in my 18 Sierra 6.2, went with Shell Rotella Gas Truck 5w30. Also what I used when I changed the oil in my Camaros last week too. I got a bunch of it for about $7 per 5qt jug so I might as well use it.
2018 GMC Sierra 1500 SLT 6.2 Max Tow
1994 Chevy Camaro Z28 5.7
1989 Chevy Camaro IROCZ28 5.7
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398420 04/09/20 12:39 PM
T
Triple_Se7en Online Content
Online Content
T
By requesting here, you will be asked to try 10 different oils. For towing - only once in a while or not, I would jump to a 0w30. Amsoil SS or Schaeffer are excellent choices. Or you can take advantage of the new 2020 Mobil-1 Rebates and buy Mobil-1. They offer 0w30 also and easy to find.
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398457 04/09/20 01:31 PM
Danno Online Content
Online Content
How many miles on it now?
If it was my vehicle, 5W-30 PP and change it at 7500 miles, 20% OLM or 1 year, whichever comes 1st.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398461 04/09/20 01:33 PM
P
PontiacHO Offline
P
It seems to be common practice here to always recommend a heavier grade oil than what’s specified. Is anyone taken into consideration the newer GM engines with the two stage oil pumps, redesigned cylinder deactivation system, and piston cooling jets all designed to operate with 0w20? Just wondering.
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398463 04/09/20 01:41 PM
Online Content
What is the same engine specced to use in non-CAFE jurisdictions, say middle East or South America?
2010 Mazda 3 2.0L
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398465 04/09/20 01:42 PM
Bryanccfshr Offline
I think you should run a Dexos 5w30. The OLM on these are fairly accurate. But depending on your service and climate you may want to stop at 20%.
Nice ride.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Danno] #5398494 04/09/20 02:05 PM
P
PontiacHO Offline
P
Good question. Perhaps someone from there can chime in.
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398508 04/09/20 02:21 PM
P
PontiacHO Offline
P
So for clarification, if the manufacture specifies a particular oil weight then the owner should automatically assume it’s for no other reason than to meet a government required fuel mileage? Furthermore if for that reason then an engine will surely fail using the lighter oil? Wondering if the dealerships are replacing engines due to this light oil requirement? Looking back approximately 28 years ago Ford specified 5w20 for the 4.6 V8 in the Crown Vic patrol car. The fleet that I managed at that time had 200+ for as long as the CV was available. We lost two engines. One was due to the scientist driving it running it thru flood waters and the other was due to a damaged oil cooler leaking and that scientist tried to drive back to our shop with no oil. I guess we were just plain lucky that these cars ran at least 12 hour shifts everyday without being shut down. Our summers are long and 95 degree heat is common. Wow. Can’t believe we survived on that “thin” CAFE oil.
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398568 04/09/20 03:35 PM
CT8 Offline
0W-30 Mobil 1 AFE oil.
2015 F150 2.7
2018 F350 6.2
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398570 04/09/20 03:37 PM
F
Falcon_LS Offline
F
For over 2 decades, the Yukon Denali has been the vehicle of choice for special law enforcement units in Kuwait and much of the Middle East, including close protection. I can’t think of another vehicle that is “abused” as much as these.
They’re loaded with all sorts of equipment, including heavy wrap-around push bars front and rear that are custom made for them out of steel, and a ton of gear in the cargo area with four heavily armed occupants whenever they are used. Countless full throttle runs on and off in heavy traffic, heavy braking, driving on and off curbs, driving on shoulders at highway speeds where rumble strips are one foot apart and an inch deep, extended idling for hours, towing, desert heat, dust and high sulfur gasoline. They’re basically used hard and put away wet and they do extremely well.
As far as engine oil is concerned, 20W-50 was the default standard by dealerships until about 2014, at which point they switched to 5W-30. To this day, ACDelco 5W-30 (Dexos1) remains the most popular option. For fleet vehicles in severe service, 5W-40 is the go-to, although I am not sure what brand.
If you look at the 2020 Middle East Tahoe/Suburban/Yukon/Denali manual, this is what you see under Recommended Fluids and Lubricants:
[Linked Image from i.ibb.co]
When you go to page 278:
So we go to Selecting the Right Engine Oil on the next page:
Although available to buy, there is no mention of 0W-20 anywhere. Fullsize GM trucks are extremely popular here, and many folks I know actually run 15W-40 with no ill effects and zero issues well past the 200,000 km (125,000 mile) mark. They change oil frequently, usually after a 25% drop in the OLM, and replace the oil and air filter with the oil when it zeros out.
Make of it what you will, but if it were my truck where you are, I would probably run Pennzoil Platinum Euro L 5W-30 or Mobil 1 ESP 5W-30 and follow the OLM. 2cents
Also worth mentioning, from my own personal experience back in California, running Pennzoil Platinum Euro L 5W-30 in an '18 Yukon XL with an L83 5.3L, it was quieter and smoother. No difference in gas mileage compared to 0W-20 factory fill, still averaging 20 MPG combined on Shell V-Power 93.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: Strjock81] #5398575 04/09/20 03:42 PM
B
BAJA_05 Online Content
Online Content
B
Another vote for the Pennzoil Platinum 5W30 or QSUD 5W30.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Oil for 2015 Yukon XL Denali 6.2 [Re: PontiacHO] #5398583 04/09/20 04:02 PM
4WD Online Confused
Online Confused
I point this out on my two L83’s … it’s running ECM controlled functions with the oil like Arco points out wrt other engines.
I start mine and it’s about 42 psi … if it’s hot and I look down at a red light it might be at 25 psi … punched it on the back road the other day … instantly at 70 psi.
That’s a stiff 6 bolt lower end too … I’m not really worried about 0w20.
Page 1 of 3 1 2 3
