Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
15 registered members (Garen, bachman, FordCapriDriver, dishdude, Hohocc, ctechbob), 1,086 guests, and 28 spiders.
Topics306,109
Posts5,286,664
Members71,586
LG Stove Top Gone Crazy #5398192 04/09/20 09:28 AM
G
Gebo Offline OP
G
I have a problem with my stove top switches. One switch operates 2 eyes and another switch operates a different eye.
We were cooking home made sausage and started to boil eggs and well, the "high" setting on the boiled egg burner caused havoc on the cast iron sausage eye.
I'm glad we have a whole house fan!
The left rear control operates both the left rear and left front. The rear center causes the left front to come on. The left front only controls the left front.
The 2 right side controls work fine. So my problem is with the left rear and rear center.
Is this a simple fix?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398206 04/09/20 09:34 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I have to wonder if the control boards get too hot from the stove top. If there is some insulation that is overheating or causing intermittent shorting, Id suspect that the board is done for and would need to be removed and replaced. Not clear if such a scenario could be repaired as DIY.
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398215 04/09/20 09:39 AM
Donald Offline
I pulled a control board from an electric stove and sent it to an aftermarket company that repairs them. I am thinking it was in the $100 to $150 range. I my case the new control board was not available. The aftermarket company swapped my board for one they had repaired so turn around was quick.
2015 Ford F-250 w/Powerstroke
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398241 04/09/20 09:57 AM
L
LoneRanger Offline
L
I don't get it, what is the issue the photo shows? Are the speckles in the smooth ceran top not supposed to be there? The Whirlpool Estate range top in my former house had speckles as a feature and I prefer it to the non-speckled ceran top of the higher end Whirlpool range in our current house, as the speckles break up the appearance of smudges and etc.
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398257 04/09/20 10:04 AM
A
ARCOgraphite Offline
A
Problem is its not a GAS range.
That Control panel looks like my Samsung panel.
Must use same membrane OE
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398288 04/09/20 10:33 AM
V
vwmaniaman Offline
V
We have gas at both homes.. Standing pilot at one and igniter at the other.. Both were a God send when we had no power for 2 weeks from an ice storm. The Samsungs and LG's make great TV but their appliances just miss the mark of durabiliy.
Don't waste your time on a slipshod repair.
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398316 04/09/20 11:01 AM
K
Kira Offline
K
So a cooking surface (or burner) is called an "eye"? Who knew?
I opened a panel in the back of our LG fridge and saw a large control card.
Suppose it's so I can link my fridge to my laptop or doorbell.
Trouble there is that companies which go in for that stuff have to stick it everywhere.
Hot, greasy locations are not ideal for circuit boards. Foolish application.
Heck, Samantha Steven's stove clock failed after a while and it had gears!
Re: LG Stove Top Gone Crazy [Re: JHZR2] #5398322 04/09/20 11:06 AM
A
Aredeeem Offline
A
Had the same problem with my LG range, out of warranty of course. The tech who came out said “Yea, these control boards can’t handle heat and moisture.” And I said, “ You mean, like when I use the stovetop and when I try to clean the control board display after I use the stovetop?” He said,” Yea.”
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398401 04/09/20 12:21 PM
B
bullwinkle Offline
B
Makes me remember why I have a GE gas range with burners & knobs!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: LG Stove Top Gone Crazy [Re: Aredeeem] #5398402 04/09/20 12:21 PM
A
azjake Offline
A
We have a LG cooktop with the touch controls at the front of the cooktop and the burners in the back. With this setup the area where the controls are never gets hot. With the controls in the back and above the burners like it is in the picture I can see how they would be exposed to a lot of heat.
2019 Kia Niro EX w/Premium pkg.
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398446 04/09/20 01:12 PM
A
Aredeeem Offline
A
Rest easy Bullwinkle. If you’re old enough to remember why you prefer a GE gas range with burners and knobs you’re wise enough to know you’re a dying breed. You’ve outgrown your role as a market segment, as I have I. It’s ok.
Re: LG Stove Top Gone Crazy [Re: Aredeeem] #5398518 04/09/20 02:30 PM
B
bullwinkle Offline
B
One of these days I'll move up to a drop-in gas range-but it'll still have burners and knobs! I'm spoiled by gas burner's instant-on heating, I would never go back to electric. I don't have front-loader washers or dryers at home either! Must be getting old...
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398566 04/09/20 03:33 PM
CT8 Offline
I'll tell my tale.2003 my oven wouldn't heat up. Yes I am so Smart I took out the wiring diagram and all the circuits were good so all that is could be was the circuit board. The stove was not like the stoves to day . I order the circuit board and put it back together and only half the oven would heat up. I called the service guy and watched him do exactly what I did ! He said the circuit board was bad. I showed him the receipt and he called his boss and they did a warranty on the circuit board and charged me half the labor. I became a loyal customer and I now call the guy.
2015 F150 2.7
2018 F350 6.2
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398582 04/09/20 03:59 PM
H
henni Offline
H
Breaker for range Off/On
Re: LG Stove Top Gone Crazy [Re: Gebo] #5398715 04/09/20 06:52 PM
V
vwmaniaman Offline
V
Talk about behind the times, I still use a percolator. Makes great flavor in the coffee.
