Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
35 registered members (bachman, billpace1956, ArrestMeRedZ, AndyB, ctechbob, bbhero), 1,308 guests, and 48 spiders.
Topics306,109
Posts5,286,659
Members71,586
Does anyone put heat shrink tubing over a connector plug? #5397910 04/08/20 10:39 PM
M
motor_oil_madman Offline OP
M
Say a main wiring harness plug where it has those plastic connectors that connect all the individual wires together. Anyone ever unplug the connector then slide the heat shrink tubing over and then shrink it down after connecting back together? I haven't looked to see how large of a diameter they make heat shrink tubing though. I have a wiring harness plug on my lawn mower that gets wet everytime it rains and i'm surprised after 5 years it hasn't started causing an issue yet. I want to make this connector water proof.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5397913 04/08/20 10:42 PM
U
UG_Passat Online Content
Online Content
U
Certain connectors have a gasket inside along with plugs for the wire itself, to make it waterproof.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5397918 04/08/20 10:44 PM
O
oldhp Offline
O
I guess you could. The mower sits outside? I'd fill the plug ends with die-electric grease and before I shrunk the tubing down.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Does anyone put heat shrink tubing over a connector plug? [Re: UG_Passat] #5397945 04/08/20 11:21 PM
M
M
I don't think that is the case with this particular connector.
Re: Does anyone put heat shrink tubing over a connector plug? [Re: oldhp] #5397946 04/08/20 11:22 PM
M
M
The mower is used commercially, so whenever it rains it's going to get wet.
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5397979 04/09/20 01:46 AM
K
KE7JFF Offline
K
I do in certain applications...
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5397995 04/09/20 03:52 AM
ctechbob Online Content
Online Content
You could always swap that connector out for a waterproof model. Not the easiest thing ever, but far from super difficult.
The problem with heat shrink is, depending on the size of the connector and wires, you'll probably not get one that will shrink down enough to seal against the wires. If you can't seal the backside of the connector, there's no sense in sealing the middle really.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5398025 04/09/20 06:39 AM
T
tcp71 Offline
T
Heat shrink tubing with a 3:1 shrink ratio and adhesive lined. Make sure it extends well beyond the connector on each side. You can seal each end by pinching extra tubing with plyers while it’s hot.
https://www.mcmaster.com/heat-shrink-tubing/extra-thick-moisture-seal-heat-shrink-tubing/
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5398029 04/09/20 06:45 AM
Donald Offline
I often use liquid tape.
2015 Ford F-250 w/Powerstroke
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5398044 04/09/20 07:05 AM
R
RavenTai Offline
R
if you apply heat shrink will end the end the heat shrink be out of the rain? where the heat shrink ends on a bundle of wires will not be waterproof, any water that does get in will have a much harder time drying.
2016 Toyota Sequoia
1999 Lexus LS400
1997 Toyota T100
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5398053 04/09/20 07:30 AM
L
LeoStrop Offline
L
I do sometimes when i make any electrical repair on my car.
If the connectors are large, you can use 2 different sizes of tubing. Use 3 pieces, the largest on the middle (for the connectors) and then you can use the 2 small pieces of tubing, to seal the ends on each side of the large one you used for the connector.
You can also use dielectric Grease around the connectors.
Chevrolet Kadett EFI '94 (Neat ethanol) - Shell Rimula RT4X 15W40
Honda Fit '09 (FlexFuel) - Shell Helix HX8 5W30 > Motul 6100 SYN-nergy 5W30
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5398059 04/09/20 07:35 AM
R
ragtoplvr Offline
R
Harbor fright sell self vulcanizing tape, it welds into an continuous piece. Only sticks to itself. It is soft and easy to remove. Forms of this are used on military applications so it is proven. Like 5 bucks a roll. Seperate connector, clean off all corrosion. Pack cavity with die-electric silicone. Then wrap with tape.
Rod
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5398113 04/09/20 08:35 AM
K
Kira Offline
K
LIMITED EXPERIENCE....with some of it VERY heavy duty.
A neighbor showed me CRC 5-56. He used it on his tractor's connections...I use it on mine.
Re: Does anyone put heat shrink tubing over a connector plug? [Re: oldhp] #5398224 04/09/20 09:47 AM
O
OldSparks Offline
O
Winner, winner, chicken dinner! Good read here on dielectric grease, if you have the time...
https://www.w8ji.com/dielectric_grease_vs_conductive_grease.htm
Re: Does anyone put heat shrink tubing over a connector plug? [Re: motor_oil_madman] #5398260 04/09/20 10:07 AM
A
ARCOgraphite Offline
A
Weather pack connector don't need any help.
I do worry about GND eyelets rotting off frame and body and engine block - due to galvanic action.
For some of our exposed stuff, we put a paraffin wax
I would not use Silicone or RTV other than spray it yearly with "Wire Dry"
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
