Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
36 registered members (daves87rs, AndyB, ctechbob, DeafBrad, bbhero, 830Lee, 1 invisible), 1,392 guests, and 53 spiders.
Topics306,109
Posts5,286,657
Members71,586
Welding Helmet Fogging Up #5397870 04/08/20 09:54 PM
G
George7941 Offline OP
G
Same issue with motorcycle helmets in cold weather. I have tried shampoo, shaving cream and a raw cut potato. They don't help much.
While welding, what helped me the most was exhaling with my upper lip protruding over my lower lip which directs the moist air downwards. Not as hard as it sounds, some practice is all it takes. Inhale deeply through your nose and exhale through your mouth.
There is still some fog build up and I am going to mount a small fan at the top of the welding helmet and have it blow downwards. Am planning to mount 4 rechargeable NiMh AAs to drive the 5V fan. I am attaching a photo of a 5V fan I have, it is about 2 ins square.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Welding Helmet Fogging Up [Re: George7941] #5398063 04/09/20 07:40 AM
T
Trav Offline
T
Re: Welding Helmet Fogging Up [Re: George7941] #5398080 04/09/20 08:01 AM
SpitFire6 Offline
Rainx AntiFog?
2002 206 CC 2L 4Cyl. 0W40 FS
1972 Spit 2L5 6Cyl. 0W40 FS
Re: Welding Helmet Fogging Up [Re: Trav] #5398136 04/09/20 08:52 AM
G
G
That film is for welding goggles, not helmets. I have fixed shade googles but use it only with my oxy-acetylene torch.
Here is the Miller goggles https://weldfabulous.com/miller-280982-weld-mask-2-auto-darkening-welding-goggles/
I should have mentioned in my original post that I wear glasses, so fogging causes twice as much problems, both my glasses lenses and my helmet lens fog up.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Welding Helmet Fogging Up [Re: SpitFire6] #5398236 04/09/20 09:55 AM
Cujet Offline
Originally Posted by SpitFire6
Rainx AntiFog?
This is the best solution I've found. It simply works.
Re: Welding Helmet Fogging Up [Re: Cujet] #5400708 04/11/20 11:53 PM
G
G
RainX AntiFog did not work for me. I bought a bottle this morning and tried it out this afternoon. It did not diminish fogging at all. I will try reapplying the Rainx.
It looks like I will go ahead with mounting the fan on my helmet.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Welding Helmet Fogging Up [Re: George7941] #5401201 04/12/20 01:44 PM
P10crew Offline
George are you welding out in the cold?
I’m not sure what you are doing but I weld aluminum power bus in all temp extremes and have never had this problem.
Maybe try putting a hanky over your face with the hopes that it would force some of your exhale out the bottom and more importantly collect moisture.
Re: Welding Helmet Fogging Up [Re: P10crew] #5401546 04/12/20 10:00 PM
G
G
Yes, I am welding out in the cold. Just welded up this rear truck bumper.
1987 BMW R80 - sold
2015 Honda CBR300R
