Forums Migration
Please read this thread
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
First time UOA. Questionable potassium levels
by chknkatsu - 07/06/20 07:38 PM
STP oil treatment
by wymi516 - 07/06/20 07:12 PM
sycboi, BakonBittz, ssoH, Sumpter_al, Jeffham87
71868 Registered Users
68 registered members (alarmguy, AndyB, ajchien, 4WD, 94astro, antone, 6 invisible), 1,122 guests, and 29 spiders.
Topics307,534
Posts5,312,665
Members71,868
Page 1 of 3 1 2 3
Detroit 4-53T 2009 Ford F350 Update.:) #5397863 04/08/20 09:48 PM
A
A310 Offline OP
A
Well guys, my 4-53T lasted about 600 miles before it failed. Turned out the engine was worn out and had sat outside for years in the Florida weather before it was brought inside and revived. Later sold to me as a good running Detroit where it sat in storage for another 10 years before I finally found a new home for it in my 2009 F350. Overall it ran pretty well only showing signs of trouble on long hills at 30 PSI boost where the blow-by was bad. I figured a rebuild was not far away, but an old Detroit mechanic I know said it just need a really good pull to set the rings, so that what I did. I went on a 5 hour road trip will lots of hills and it failed on the way back climbing an 8% grade after 5-7 minutes. Post inspection showed an engine that was totally trashed, amazing it ran as well as it did. #2 piston seized and broke the liner and that was it. I'm now in the process of building it up as a Silver Series with Ceramic coated pistons, new performance cam, new crank, rebuilt head. Happy time ahead.:)
Before Failure: It failed a few minutes after this video was taken.
https://www.youtube.com/watch?v=L7lUoS-1ugQ
Post Failure:
https://www.youtube.com/watch?v=Vk2Fj2P9vdA&t=10s
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: A310] #5397872 04/08/20 09:55 PM
CT8 Offline
Is the silver series like the Silver Series the high out put versions . From My fading memory Detroit offered a 430 Hp 8V92 that was really powerful in its day.
2015 F150 2.7
2018 F350 6.2
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: A310] #5397882 04/08/20 10:17 PM
M
mattd Offline
M
What were the EGTs right before it failed? I’ve rebuilt a few 8V92s but the ECM controlled ones. Certainly giving it a work out with that RPM.
Edit: I heard you say 1050* when it failed. Did ever go over 1200*? Usually that’s the rule of thumb for sustained EGTs. After seeing that rotted liner it’s no wonder it broke.
I see a lot of mcbee parts there. They have been a mixed bag of quality, particularly the seals, IME
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: A310] #5397885 04/08/20 10:23 PM
clinebarger Offline
I wonder how hard it would be to transplant 6.0L's in these dead 6.4L trucks? I realize you're already on another path, Just thinking out loud.
2001 Chevy Camaro L92/4L80E
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: A310] #5397887 04/08/20 10:24 PM
53' Stude Offline
Shame what happened to that. I have faith you will build it right smile
Keep us posted and cool shop
2009 Toyota Camry LE
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: clinebarger] #5397891 04/08/20 10:27 PM
M
mattd Offline
M
It really would not be bad. Throw away the 6.4 TCM and ECM, take the full harness from the 6.0 with ECM/FICM and you should be able to get it running. You’d have to figure out integrating the instrument cluster but that is about it. Certainly easier than the OPs project.
ASE Master, L1, L2
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: CT8] #5397895 04/08/20 10:31 PM
A
A310 Offline OP
A
Basically yes, the Silver Series was Detroits last version of this engine that improved reliability, HP and noise levels. It raised the HP from 170 HP to 185 HP.
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: mattd] #5397902 04/08/20 10:35 PM
A
A310 Offline OP
A
Yes it failed at 1050 and the hottest I've ever seen in go to is 1100 for a few seconds then back down to 1050-1060. The head parts are Mcbee's and the bottom end is all FP.
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: A310] #5397908 04/08/20 10:36 PM
CT8 Offline
sorry for the $$$$ rebuild but it will be awesome !!
2015 F150 2.7
2018 F350 6.2
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: mattd] #5397911 04/08/20 10:39 PM
A
A310 Offline OP
A
Very true, to put a 6.0 in this truck would have been a lot easier than fitting in the 4-53T.:)
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: CT8] #5397924 04/08/20 10:49 PM
A
A310 Offline OP
A
I should have done this in the beginning before I put it in the truck.:)
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: A310] #5397999 04/09/20 04:35 AM
Skippy722 Offline
But then he wouldn’t have gotten that sweet, sweet 2 stroke diesel sound!
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: A310] #5398013 04/09/20 06:00 AM
K
ka9mnx Online Content
Online Content
K
Sorry to poop on your parade. As a 30 year DD mechanic it's a bad idea to hop up/push a 53 series DD. They were not that reliable as a stock engine. :-(
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: A310] #5398076 04/09/20 07:57 AM
A
atikovi Offline
A
You replaced a big V8 Powerstroke with a little 4 banger in a heavy F350 and you're surprised this happened?
Re: Detroit 4-53T 2009 Ford F350 Update.:) [Re: atikovi] #5398120 04/09/20 08:42 AM
supton Offline
A 453T is 212 cubic inches? Pretty big for an I4. Only 175 horsepower but 420 foot-pounds torque.
http://powerforce.com/PDFs/2Cycle_Engines/DS_PF4-53T.pdf
I'm not sure what kind of derating it has, but I'm guessing that if you could cool it, it would probably be happy at full throttle (at full load) until the fuel tank went empty. It was meant to be worked, and hard.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Page 1 of 3 1 2 3
