Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
53 registered members (bdcardinal, boulderdentist, Blue_Goose, BHopkins, 3turbodiesels, 3 invisible), 1,587 guests, and 38 spiders.
Topics306,109
Posts5,286,641
Members71,586
Troy Bilt TB6044XP string trimmer dies when hot #5397721 04/08/20 07:18 PM
9
92saturnsl2 Offline OP
9
I have a Troy Bilt TB6044XP 32cc 4-cycle string trimmer that won't stay running. Starts fine and it will run for 15-20 minutes but once the unit gets good and hot, it shuts down. No sputtering, no effort to run at all, just falls flat on its face. No amount of pulling the rope will get it to start again unless you let it cool down for 15-20 minutes, then it will fire up again for a few more minutes until it gets hot. I first noticed this last summer, it would only run for 5-10 minutes in the dead of summer, but it seems to be running a bit longer now that the weather is cooler.
Any ideas? When it's running, it runs like a dream. I thought ignition coil would be an inexpensive place to start, but open to suggestions!
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5397753 04/08/20 07:50 PM
Dinoburner Offline
Have had similar problems, one the fuel line would collapse when it got hot due to ethanol and two the coil would become weak when hot. Different machines both air cooled.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5397754 04/08/20 07:50 PM
super20dan Offline
buy a real trimmer. these are junk. throwaways
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5397759 04/08/20 07:56 PM
cjolson140 Offline
I was working on a Stihl pole saw with a “4-mix” engine (4 cycle, but runs on 50:1 mix and doesn’t have oil in the crankcase, weird design). It wouldn’t idle when warmed up and lost power and died when hot, but ran great after I reset the valve clearances. If I remember correctly I think the exhaust valve was tight. Worth checking if it’s never been done.
Otherwise, if your machine idles/runs great until it suddenly dies, it’s probably the coil.
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5397760 04/08/20 07:57 PM
R
rekit Offline
R
Had an old Poulin chainsaw like that. I read the bore would get out of round when hot and lose compression. It's telling you to take a break? Or a bad coil?...
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5397771 04/08/20 08:10 PM
spasm3 Offline
Check for collapsed fuel line. When it fails to start, pull the plug, connect it, ground it and see if there is spark.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: super20dan] #5397830 04/08/20 09:06 PM
9
9
I have a "real" trimmer, this one is a backup that I use a cultivator attachment on. Problem occurs even when using as string trimmer. Not mission critical but would like to keep it running. I'm well aware of Troy-Bilt / MTD quality.
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5397844 04/08/20 09:31 PM
CT8 Online Content
Online Content
Also first check for spark when hot.
2015 F150 2.7
2018 F350 6.2
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5397866 04/08/20 09:49 PM
Z
zzyzzx Offline
Z
Throw it away and get a corded electric one.
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5397938 04/08/20 11:01 PM
samven Offline
You may be able to use a spark checker when its hot to see if the coil is the issue but also check that the choke is moving to the off position and look at the fuel line to see if it is laying up against the engine, you might be getting a vapor lock. You may have to pull the bowl and check the float level it may have gotten fuel soaked or leaked into the float. running rich when cold is not a problem but when it gets hot its just like turning the choke on. You can also get a can of starter fluid and when it dies give it a shot through the air cleaner and try starting it, if it does not at least fire for a sec or 2 its most likely spark if it does fire its fuel.
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5397948 04/08/20 11:23 PM
Dan55 Offline
Does it have adjustable valves?
2016 Lexus NX200T 2017 Mustang Conv Eco Prem
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5400840 04/12/20 07:10 AM
L
Lubener Offline
L
Check for spark when it won't start. If you get a new one, go for 2 cycle. Those 4 cycle units are heavy and can wear you out doing a lot of trimming.
The "thinking" man's friend.
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5401001 04/12/20 09:59 AM
A
ARB1977 Offline
A
My troybilt 4cycle lasted me 7 years. Was leaking oil. Not a single issue. Decided to buy a real weed eater, lol. Sthil straight shaft. So far so good 5 years later.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Troy Bilt TB6044XP string trimmer dies when hot [Re: 92saturnsl2] #5401054 04/12/20 11:04 AM
B
BrianF Offline
B
I run the Tb590ec. Other than having to drain the fuel tank after use because the carb siphons fuel out, it starts not to bad (opened up the main jet) and runs very strong. I can run it pretty much wide open for a full tank hacking down the forest.
Mine has the 29cc powerhead and they call for a valve adjustment at some interval. There are some YouTube videos showing the process.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
