About 750 or so miles on it and about 2 months. When I initially installed the filter it plugged immediately so It took it back off and washed it out, tons of crud came out when I did that then!
The car is a 99 grand marquis which is in great shape except it had the original what used to be green coolant in it when I got it. I've flushed the system 3 times now and put all new hoses on and a new water pump as well as a overflow tank for preventative maintenance and converted to G-05 coolant. This system was nasty.
