Originally Posted by NormanBuntz
for my Honda's front driveshaft, The Napa Maxdrive part caused a vibration. Paid almost double for genuine Honda, and the problem disappeared.
Have you tried Raxles? I heard good things about them, and they rebuild axles for all Hondas.
Does Honda actually sell OEM new non-reman axles? I've only been able to find OE new axles from Ford, GM, and some German cars.
And worse, some "factory/dealer/OEM" remans are Cardone
Originally Posted by IndyIan
My new KYB quickstruts were clunking a bit when I installed them. I found that the top nut was a bit loose on one, so I hit it with the impact and the noise has stopped. Good struts otherwise.
Monroe had the same problem for awhile.Maybe the nuts aren't tight enough again
