320K mileage - recommendations?
by joshuawesl - 05/30/20 12:36 PM
ISO Sprint sim
by pkunk - 05/30/20 11:44 AM
2001 Mazda Miata, timing belt
by frankbee3 - 05/30/20 11:15 AM
3M tape removal
by loneryder - 05/30/20 10:31 AM
Which string trimmer
by DeafBrad - 05/30/20 10:26 AM
Conventional Oil Benefits
by Bogdon - 05/30/20 07:38 AM
I'm finally retired!
by grampi - 05/30/20 07:20 AM
2020 Equinox 1.5t
by IMPALA08 - 05/30/20 07:05 AM
Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
RedMan542, bdubb, TreePointer, PierreS, GDR
71572 Registered Users
91 registered members (4WD, 53' Stude, 03s, ArrestMeRedZ, 928, 2004tdigls, 9 invisible), 2,672 guests, and 35 spiders.
Topics306,044
Posts5,285,554
Members71,572
Any brake system engineer here to explain why #5396719 04/07/20 06:38 PM
A
atikovi Offline OP
A
First generation Honda Insights with automatic transmission have cast iron front brake calipers while manual transmissions have aluminum calipers?
Re: Any brake system engineer here to explain why [Re: atikovi] #5396737 04/07/20 07:03 PM
O
oldhp Offline
O
Manual trans is driven harder requiring more braking action, aluminum dissipates heat better. banana
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Any brake system engineer here to explain why [Re: atikovi] #5396761 04/07/20 07:29 PM
E
eljefino Offline
E
Maybe the aluminum ones cost more but save weight, and it got the car into a lower CAFE weight class.
These classes don't really-really matter, but if one can make bantamweight they get "free" MPG/ credits.
This is also why Honda does the lawnmower sized batteries.
The automatic insight doesn't need to fit any particular weight class.
OT The plastic (?) calipers on my prius are silly-light.
Re: Any brake system engineer here to explain why [Re: oldhp] #5396766 04/07/20 07:34 PM
A
atikovi Offline OP
A
The majority of people owning these drive like they have an egg between their foot and the accelerator. Neither transmission gets driven or braked hard, especially with regenerative braking where pads can last over 100,000 miles.
Re: Any brake system engineer here to explain why [Re: atikovi] #5396834 04/07/20 08:44 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I doubt Honda is that presumptive on the driving habits of drivers with particular transmissions.
I can't think of any reason to associate caliper casting material with transmission type.
Re: Any brake system engineer here to explain why [Re: Kestas] #5396872 04/07/20 09:24 PM
R
Rmay635703 Offline
R
Generally accepted theory is that the CVT weighs more and needs stronger brakes
Re: Any brake system engineer here to explain why [Re: atikovi] #5396875 04/07/20 09:26 PM
ctechbob Offline
Huh, that is a good question. All cars use the same knuckle and lower control arm, so it's not like they parts bin engineered the addition of the CVT in the second model year and changed the caliper with it. Also, the exact same rotor for both of them. Its gotta be a weight thing, but why tool up a brand new part to make something heavier in the second year?
You're right, it doesn't make much sense.
Being the same knuckle and rotor, you should be able to swap the aluminum caliper on to a cast iron car. Assuming the piston bore is the same, and vice versa.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Any brake system engineer here to explain why [Re: ctechbob] #5396921 04/07/20 10:21 PM
A
atikovi Offline OP
A
3 or 4 pounds per caliper between the two in a 2,000 pound car won't make a measurable difference. A loaded purse weighs more.
Re: Any brake system engineer here to explain why [Re: atikovi] #5397021 04/08/20 05:23 AM
dlundblad Offline
Do the cars have different assembly plants?
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Any brake system engineer here to explain why [Re: oldhp] #5397027 04/08/20 06:03 AM
L
Lubener Offline
L
I fail to see your logic that driving with a manual transmissions make someone place more stress on the brakes. ???
The "thinking" man's friend.
Re: Any brake system engineer here to explain why [Re: atikovi] #5397091 04/08/20 07:54 AM
A
ARCOgraphite Offline
A
Sounds like a running change. But first to teat your initial assertion.
Is this assertion extrapolated from personal knowledge of 2 samples?
<or>
please cite references.
Some thoughts ...
AFA MT having cast Al calipers, was this a superlight HE model?
Is it tied into regen or lack thereof on the MT car?
AFA oldhp idea, MT do not necessarily require "better" brakes, AT usually require better brakes.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Any brake system engineer here to explain why [Re: atikovi] #5397100 04/08/20 08:00 AM
R
Rmay635703 Offline
R
The insights equipt with aluminum brakes are more likely to warp, one of my MT Insights had the brakes swapped to iron when I bought it.
Re: Any brake system engineer here to explain why [Re: ARCOgraphite] #5397140 04/08/20 08:55 AM
A
atikovi Offline OP
A
Nope, same throughout the 2000-2006 model run.
Re: Any brake system engineer here to explain why [Re: atikovi] #5397155 04/08/20 09:06 AM
H
hallstevenson Offline
H
Ever heard the saying "every little bit helps" ? I'm willing to bet that it was done for weight savings and the caliper isn't the only thing you'll find that they use a different material with.
Re: Any brake system engineer here to explain why [Re: hallstevenson] #5397174 04/08/20 09:29 AM
A
atikovi Offline OP
A
So why didn't they use aluminum on the automatic model? They do use magnesium for the oil pan on both.
