Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
87 registered members (4WD, amblerman, 01rangerxl, 92saturnsl2, Astro14, 11 invisible), 2,275 guests, and 64 spiders.
Topics305,923
Posts5,282,820
Members71,537
Page 2 of 2 1 2
Re: Bad experience with Monroe strut assembly [Re: sasilverbullet] #5396441 04/07/20 01:11 PM
I
IndyIan Offline
I
My new KYB quickstruts were clunking a bit when I installed them. I found that the top nut was a bit loose on one, so I hit it with the impact and the noise has stopped. Good struts otherwise.
06 Focus ZXW, 5spd manual, 220km
18 Outback 2.5 CVT 35km 0W20
Re: Bad experience with Monroe strut assembly [Re: sasilverbullet] #5396474 04/07/20 01:53 PM
G
Gebo Offline
G
Monroe is not the Monroe you remember. Today some "great" companies are bought by investors that want to milk them for profits and ride on their good name. It takes years before the general public catches on.
In that time the new owners have cheapened the product and made a fortune.
OEM is the way I roll. You rolled the right way. Some have a hard time rolling the right way. sailing
They haven't learned the difference between "Price" vs "Cost."
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Bad experience with Monroe strut assembly [Re: sasilverbullet] #5396512 04/07/20 02:29 PM
A
Audios Offline
A
Same problem through my shop, warrantied a few more than once and I will only install customer supplied ones now, I wont warranty them anymore.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Bad experience with Monroe strut assembly [Re: sasilverbullet] #5396596 04/07/20 03:59 PM
N
NormanBuntz Offline
N
Originally Posted by sasilverbullet
Ordered 4 Monroe strut assemblies from RockAuto for my 2014 Accord. Rears worked fine but the front ones made popping noises when turning. Had RockAuto cross ship me another one, the replacement was even worse!
My indy finally replaced the front struts with Honda parts, noise is now totally gone. Indy thinks the problem was the bearing on the top of the strut.
RockAuto didn't give me too much trouble getting them to refund the money for the three front struts.
Bottom line, if you have a Honda, consider going with Honda parts from the start on struts.
I found this to be true for my Honda's front driveshaft, The Napa Maxdrive part caused a vibration. Paid almost double for genuine Honda, and the problem disappeared.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: Bad experience with Monroe strut assembly [Re: sasilverbullet] #5396622 04/07/20 04:24 PM
A
atikovi Offline
A
Got a pair of Gabriel rear struts plus mounts for my Escort from Rock for $40 delivered last week. Those wholesaler closeouts. Seems to be fine. One made in USA and one from Mexico. Probably sitting on the shelf the last 10-15 years though.
Re: Bad experience with Monroe strut assembly [Re: sasilverbullet] #5396674 04/07/20 05:45 PM
G
GZRider Offline
G
Sachs and KYB would be my economical suggestions. If you happen to come across a few hacked gold cards (joking please don't break the law) then Bilistein and KW and Fortune all make really nice stuff. Monroe was good many years ago, but now they are now bottom of the barrel at least handling and control wise.
Re: Bad experience with Monroe strut assembly [Re: IndyIan] #5396838 04/07/20 08:48 PM
slacktide_bitog Online Content
Online Content
Have you tried Raxles? I heard good things about them, and they rebuild axles for all Hondas.
Does Honda actually sell OEM new non-reman axles? I've only been able to find OE new axles from Ford, GM, and some German cars.
And worse, some "factory/dealer/OEM" remans are Cardone mad
Monroe had the same problem for awhile.Maybe the nuts aren't tight enough again cry
Page 2 of 2 1 2
