Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
29 registered members (bachman, Amkeer, ArrestMeRedZ, cjcride, classic70, dbias, 3 invisible), 1,205 guests, and 27 spiders.
Topics306,035
Posts5,285,276
Members71,566
Moisture inside double pane glass doors. #5396266 04/07/20 09:51 AM
Cujet Offline OP
My Florida home has 4 sets of french doors (so 8 doors total) and the double pane glass in most of them is fogging up badly. They are 18 years old. The doors are made of steel, and have only a minor bit of surface rust on them at the bottom. I believe I can clean that up easily (but ya never know) . The glass is held in by a retainer and screws. The window panes are large simple panes and take up most of the door.
I'd like to replace the glass. I have been looking for wind resistant hurricane glass (custom size) , unfortunately the companies that sell this don't sell it as single pane, and a double pane hurricane glass won't fit (too thick) .
Maybe a 3/8 inch thick tempered glass? I'd even consider a quality plastic, but I don't think that option is reasonable, as very few Plexiglas products hold up.
So, I'm looking for suggestions. I'd prefer not to replace all the doors, not just due to the expense, but the fact that I really feel that any quality replacement glass will work just fine and it seems quite easy to do.
EDIT: The doors seem to be quite tough, they open outward for wind resistance, and meet the 175mph wind load rating (just not impact) . The company that made them is out of business.
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396283 04/07/20 10:05 AM
B
Blueskies123 Offline
B
I have the same problem. As far as I know, the only option is to find a glass guy that is willing to just replace the glass pane but that is not so easy. Maybe a handyman that knows glass.
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396293 04/07/20 10:16 AM
B
BMWTurboDzl Offline
B
I would think if there were a market for just replacing the glass then it would be available. In any case you still want to have the insulating properties of double-pan glass so I would not expect a re-seal in the field to be as durable as an initial seal in the factory.
IMO..New Doors.
435i
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396313 04/07/20 10:33 AM
J
JohnG Offline
J
You guys are hosed. There is much more to getting hurricane rated doors than just the glass. Any Florida inspector will want to see the manufacturers certification for that specific door. The good news is that if they are covered by storm shutters, depending on type, you may get a waiver from the inspector on the glass, but he will still want to see ratings on the frame.
Here in central Florida, I think 35 mph wind is suitable for the frame. The Miami-Dade codes might require something more.
Now, to get all that accepted by your insurance company for "Wind Mitigation" would be a different story. They might go for it. They can be pretty tough on that spec though, sometimes, to get the FULL discount, they even want any glass in the garage door to be impact rated.
The other difficult part is not many local companies sell sliding glass doors that are Impact rated, and the only ones I've seen have been double pane. (The inner pane is laminated w/lexan).
I just had two Pella vinyl sliding doors installed, to the tune of $7000.00! They were behind aluminum shutters, so passed with the inspector. 35 mph wind rated frame. AND he checked that EVERY hole provided by the manufacturer had a screw in it!
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396317 04/07/20 10:35 AM
J
JMJNet Offline
J
I have 2 different double pane windows with that issue.
For the windows, there are company who comes, measure and make the replacement.
Then replace the fogging one.
  • 2017 Toyota Sienna
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396320 04/07/20 10:37 AM
J
JohnG Offline
J
Double pane replacement glass IS available. I did two side windows when I lived in Ohio, no issues. Not sure about impact glass though.
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396325 04/07/20 10:42 AM
doitmyself Offline
I do know that double pane garage door windows and building windows can be replaced as a glass-only unit - sealed glass from the factory OR aftermarket that fits into the garage door or window frame.
Large French doors might be a different story. Replacement glass might only be available from the manufacturer, unless they are standard generic sizes? I was told that door glass that a child (or anyone) could fall through has to be different (tempered/safety glass?) or plastic that won't break in a way that would stab someone. "Told", not verified.
Double panes are not only sealed, but also contain gas of some type, so I have been told. This place claims they can replace double pane French door glass: https://glassdoctor.com/expert-tips/all-about-glass-doors/french-door-replacement-glass
LOL, my in-house workplace window guy tells me my account will be charged if I request glass replacement due to fogging, but is free if a lawn mower stone breaks the window. I hate those lawn stones!
Re: Moisture inside double pane glass doors. [Re: JohnG] #5396330 04/07/20 10:45 AM
Cujet Offline OP
The original glass is simply tempered glass. It's not impact resistant. I have steel hurricane panels that cover all the doors. Replacing the glass with tempered glass would be 100% OK. I'm not required to upgrade for a simple repair.
Also of note, the pane sizes in my doors are uncommon, or at least, not the same as current stuff. I can't go out and purchase drop in panes from another manufacturer.
I plan on doing the work myself. Remember, I replace windows in aircraft with regularity. This is an order of magnitude easier. I'm thinking a single 3/8 inch pane would be sufficient. I'll bet Low-E glass would be just as efficient. NOTE: My windows are Low-E but my doors are not.
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396338 04/07/20 10:55 AM
J
JohnG Offline
J
Quote
I forgot about the glass being tempered, but yes, this is most likely the reason that they are NOT Impact Resisitant (Laminated w/Lexan). Maybe more correctly, Hurricane Rated glass.
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396352 04/07/20 11:17 AM
Number_35 Offline
Wow, you fellows have a different set of window issues down there in hurricane country!
Internal fogging on sealed dual- and tri-pane windows is common here. There are companies that do a fix without replacing the window. I'm told they install a one-way valve that allows the moist air to migrate out (as it expands with heat) but does not allow new air back in. They claim 50% cost reduction compared to full replacement. Most of the cost would be the labour involved in removing the trim, removing the window itself, and reinstalling the window and trim. I would bet that it would be very cheap to install the valve only in a sliding door.
I'm guessing this company uses the same technique:
https://winnipeg.windowmedics.com/defog/
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396377 04/07/20 12:10 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
OK, but it's double pane, right?? So a single pane will conduct more heat through it, which also means it will be much more prone to being wet with the Florida humidity. That means more rust in the door, and shorter rest of life.
If you can live with that (maybe paint/rustproof the inside of the door where water might accumulate?), then it might be worth a shot. I dont quite get how you would seal it into place, but I suspect you have the experience to figure it out.
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396440 04/07/20 01:09 PM
J
JohnG Offline
J
I'm still missing something here. If the original is double pane with fogging between, why won't replacement double pane glass fit? Plenty of companies make that....just not Hurricane rated.
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396454 04/07/20 01:35 PM
AZjeff Offline
[q I'm thinking a single 3/8 inch pane would be sufficient. I'll bet Low-E glass would be just as efficient.
Might want to check what a 3/8" pane that size would weigh. 3/8" glass is roughly 5 lbs/sq ft. (.091 lb/sq in.) Will your hinges hold it?
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Moisture inside double pane glass doors. [Re: Cujet] #5396508 04/07/20 02:19 PM
Danno Offline
Replaced 3 panes of double pane regular glass. Brought the panes to a local glass company and they duplicated the panes in size and depth and gas filled. Been great for 10 years now.
Is that not possible with these panes?
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Moisture inside double pane glass doors. [Re: Danno] #5396528 04/07/20 02:47 PM
Cujet Offline OP
Yes, it's possible and the cost is not too far out of this world. However, it would be really nice to completely avoid the risk of fogging.
No problem with the weight. 2ea 3/16th inch panes weigh exactly the same as one 3/8th inch plate. These doors are industrial tough anyway, not lightweight stuff.
