Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
RedMan542, bdubb, TreePointer, PierreS, GDR
71572 Registered Users
53 registered members (Alain2, alarmguy, 94astro, aba4430, 2009Edge, 4WD, 8 invisible), 1,432 guests, and 44 spiders.
Topics306,035
Posts5,285,292
Members71,572
Update: Oil turns dark quickly #5396182 04/07/20 08:48 AM
NavyVet88 Offline OP
Hello all,
My previous “oil turns dark quickly” thread seems to have been remedied.
02’ Ford Ranger 3.0L 77k(original) 4x2 Automatic.
I bought the truck with 66k miles on it, i changed the oil which was conventional Castrol 5w20 and a champ filter over to Castrol edge 5w30 and a fram ultra. In less than 1k miles, the oil was pitch dark from the first change I did so I waited until 3500ish miles and changed it out again to the same filter and oil. Same thing again in roughly the same mileage. So a month or so ago, I changed the oil to M1 5w30 regular synthetic with a M1-209A and we are at 779 miles on the OCI and the oil is just now starting to turn an ever so slight hue of brown.
I’m guessing the add pack in Castrol edge may have had something to do with it I’m not sure, but the M1 seems to be holding well. I’m not a fan of the luevers in the M1 filter though. I’m sure it is fine, but I’m not a leuver guy. I’m probably going back to the Fram ultra after this OCI or a Napa platinum/gold.
The picture below is of the M1 after 779 miles. It is overcast outside so I apologize for the quality, but the hash marks on the stick are very visible. The Castrol Edge was so dark at the same mileage that you couldn’t even see through the little hole on the dip stick through the oil. I’m not bashing Castrol at all. It is a fine oil.
2013 Honda Civic LX 1.8L 178k M1 HM 0w20 with Fram XG7317
2002 Ford Ranger Edge 3.0L 67k Castrol Edge 5w30 with Fram XG3600
Maintenance Technician by trade, working class for life.
Re: Update: Oil turns dark quickly [Re: NavyVet88] #5396263 04/07/20 09:46 AM
T
tcp71 Offline
T
Maybe the castrol was cleaning up the internals of the engine?
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Update: Oil turns dark quickly [Re: NavyVet88] #5396272 04/07/20 09:58 AM
B
Bottom_Feeder Offline
B
I'm not following your logic here at all.
In your eyes the Castrol Edge is somehow inferior because it's turning dark sooner than the M1? The M1 is holding up better in some way? That's not how motor oil works.
Re: Update: Oil turns dark quickly [Re: NavyVet88] #5396304 04/07/20 10:25 AM
Nick1994 Offline
That's really low mileage for how old it is. It's just doing cleaning from likely short trips and not adequate oil changes.
Nothing to see here.
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Update: Oil turns dark quickly [Re: NavyVet88] #5396465 04/07/20 01:48 PM
G
Gebo Offline
G
I think the Castrol was cleaning the engine. It may be that if you did your next change with Castrol that it wouldn't turn dark brown so quickly. I would do an experiment the next OC and use the Castrol like you first did.
Would an oil that turned black quickly be better than an oil that didn't turn black quickly? Me thinks it would be.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Update: Oil turns dark quickly [Re: Bottom_Feeder] #5396472 04/07/20 01:52 PM
It was suggested in the prior thread where I initially addressed this issue that it was possibly the Castrol edge with its particular add pack cleaning the internals of the motor because it was low mileage and 20 years old. I drain and filled the crank case to see if it was the oil cleaning or if it was an additive issue. The Mobil 1 has been in service for nearly the same amount of time as the edge and the Mobil 1 is cleaner. Cleaner because the last two fills did most of the cleaning already? I don’t know. I did this for my own piece of mind.
Re: Update: Oil turns dark quickly [Re: NavyVet88] #5396492 04/07/20 02:07 PM
sloinker Online Shocked
Online Shocked
Or conversely it may show that the Casstrol is oxidizing/shearing/evaporating at a rapid rate due to its inherent cheap build quality and the M1 utilizes something better in its manufacture and stays better/cleaner/longer.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Update: Oil turns dark quickly [Re: sloinker] #5396932 04/07/20 10:42 PM
Maybe so.
Re: Update: Oil turns dark quickly [Re: sloinker] #5397048 04/08/20 06:37 AM
K
kschachn Offline
K
Or maybe it doesn't since you're just guessing and apparently making stuff up with no technical data to support your claim.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Update: Oil turns dark quickly [Re: Gebo] #5397053 04/08/20 06:46 AM
4WD Online Confused
Online Confused
[quote=Gebo]I think the Castrol was cleaning the engine. It may be that if you did your next change with Castrol that it wouldn't turn dark brown so quickly. I would do an experiment the next OC and use the Castrol like you first did.
^^this is as close to an answer as you might get^^
Both good motor oils and have not pushed either far … No worries.
Re: Update: Oil turns dark quickly [Re: 4WD] #5397325 04/08/20 11:33 AM
T
Triple_Se7en Offline
T
It's really weird how certain oils react differently to different engines and driving styles. What works for one doesn't work for the other.
I've just recently used both the Castrol Edge and Valvoline Advanced. The Castrol stayed amber much longer than the Valvoline Advanced, which turned black in under 2K. That has me to believe the Advanced has more cleaning power than Castrol Edge.
What I witnessed was done in under 11k total engine miles.... right after the factory-fill was pulled at 3K.
So all theories get blown out of the water at our BITOG residence....lol
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: Update: Oil turns dark quickly [Re: NavyVet88] #5397739 04/08/20 07:29 PM
P
painfx Offline
P
It was vice versa for me. I was using Castrol EDGE Titanium, it didn't turn dark as fast as the Mobil 1 EP 5W30.
