98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
117 registered members (50jeffrey, 928, 53' Stude, 762fermeandyou, Al, 1978elcamino, 11 invisible), 2,721 guests, and 58 spiders.
Topics305,904
Posts5,282,526
Members71,535
Snapper drive belt install trouble LT300 #5395729 04/06/20 05:56 PM
spk2000 Offline OP
Having trouble getting belt over the pulley. Gap too small between frame and top of pulley to get belt onto pulley. Looks like nuts can be turned to slide the lower pulley section which may create a better gap. Anyone ever done one like this?
Thanks
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5395732 04/06/20 05:57 PM
spk2000 Offline OP
The belt seen is the broken one before I took it off
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5395733 04/06/20 05:57 PM
spk2000 Offline OP
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5396132 04/07/20 07:39 AM
V
vwmaniaman Offline
V
Usually on main drive belt with belt guides you have to loosen the center bolt on the motor crankshaft and pull down the pulley and istall the belt and re-install pulley on the crankshaft.
Don't waste your time on a slipshod repair.
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5396157 04/07/20 08:19 AM
M
mk378 Offline
M
The belt can't be installed by putting it over the top of the pulley because the engine shaft is there. You will need to remove the blade belt and put the new drive belt on from the bottom. Then either move the keeper guides or like @vwmaniaman said take out the shaft center bolt and slide the clutch and all the pulleys down. Do not loosen any of the three bolts on the side of the triangle part, those are holding the clutch together.
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5396173 04/07/20 08:41 AM
Cujet Online Content
Online Content
Looks to me like there is a removable belt guard by the pulley.
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5397029 04/08/20 06:06 AM
spk2000 Offline OP
Thanks everyone. Crankshaft did need to drop and the belt guide was fixed so engine had to be lifted slightly. Running great now.
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5401115 04/12/20 12:19 PM
H
HangFire Offline
H
Better than many MTD products. On my Cub Cadet you had to pull the engine or cut a flange to replace the drive belt.
Various musings: http://hangfire.net
