Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
35 registered members (bachman, billpace1956, ArrestMeRedZ, AndyB, ctechbob, bbhero), 1,308 guests, and 48 spiders.
Topics306,109
Posts5,286,659
Members71,586
240V Electric Hookup Questions #5395768 04/06/20 06:33 PM
9
92saturnsl2 Offline OP
9
I just got a new welder and plan on running it off my generator but the plugs are not compatible. The welder has a 6-50 3-prong plug, the generator has L14-30 and 14-50, both 4-prong outlets. I assume I can just wire up a cord with a L14-30 plug and 6-50R receptacle and just drop / disregard the neutral? Does this sound right? The welder input current is less than 30 amps.
Also my 5th wheel has the standard 30A 120V plug and my generator only has regular outlets for 120V. Can I use the L14-50 generator outlet and convert to 120V 30A receptacle that uses one of the hot legs and neutral? I understand I can get an adapter to plug into a standard outlet (which I already have) but I can imagine many scenarios where 15-20A might be limiting.
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5395772 04/06/20 06:35 PM
spasm3 Online Happy
Online Happy
How many amps will the welder pull? I'd wire it for the 50amp outlet unless its a small mig.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5395774 04/06/20 06:44 PM
spasm3 Online Happy
Online Happy
Wait a minute. Is this a 220v welder? And does your generator put out 220-240v? If its a 120v genset, i don't see how you can make this work.
6-50 220v should need 2 legs of 110 and a ground. No neutral. 14-50 has 2 legs of 110 and a neutal.
[Linked Image from ambrasta.com]
[Linked Image from doityourself.com]
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5395808 04/06/20 07:14 PM
E
eljefino Offline
E
Yes on both. How big is your generator? It's possible, by doing what you're doing, to overload half the windings on the generator while the other half go unused. The gas engine can power through this. Breakers should pop, but not always.
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5395860 04/06/20 08:19 PM
9
9
Generator is rated for 9500W running. The welder in question draws a max 26A @ 240V.
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5395878 04/06/20 08:50 PM
MolaKule Offline
Global Moderator
Global Moderator
Welder Power required = 26A @ 240V = 6240 Watts.
Welder Max current = 9500Watts/240V = 40 Amps, so you have about 14 Amps to spare.
If the Welder's plug isn't the same as your Generator's socket, then go to the hardware store and get a set of plugs and sockets for a short converter.
I would use three short wires of #10 stranded for the converter.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5395887 04/06/20 08:57 PM
dareo Offline
If your welder is inverter based look into the quality of power your generator puts out. I think they need pure sine wave or something.
2019 VW Golf Alltrack, 2018 Regal TourX, 2016 GMC 1500 SLT 6.2, 2007 GMC Savana 6.6 Duramax
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5395941 04/06/20 10:16 PM
Cujet Offline
One really cool "tool" to make is a short adapter-extension cord with all the common 240V receptacles on it. Including each of the 2 legs of 120V with high amp connectors.
You will only be able to use 1 of the 2ea 120V legs on your 5th wheel. You can use one leg from any of the outlets.
You might also be able to use the other 120V leg and an extension cord to run (for example) your microwave.
Re: 240V Electric Hookup Questions [Re: spasm3] #5396030 04/07/20 02:28 AM
O
OilUzer Offline
O
Sounds like his generator has 14-50 which is 240V.
Welder 6-50 is also 240V but no neutral . 6-50 is from old days where for example 240V ranges didn't have electronics requiring 120V so it has no neutral. Only 2 hots (240V) and ground.
14-50 has a neutral to get 120V. That would be the W in the above wiring diagram.
Based on the above everything he needs is there. I am just not sure if he can buy an adaptor or not ... or he should be able to make a cable with no W (neutral).
Disclaimer:
It's been a while since I worked on these kind of stuff and have forgotten and need to refresh my memory. If I get additional info or have time to research, I will update.
Meanwhile please double and triple check and do some research or talk to knowledgeable people who work on these on a daily basis. I don't want to give you a bad info.
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5396037 04/07/20 03:33 AM
O
OilUzer Offline
O
just checked and they sell 14-50 to 6-50 Welder adaptor and extension cord ... or you can make your own.
Long time ago, I made something similar for a friend to connect his generator. He had a secondary breaker box and a transfer switch and needed an extension cord from his generator to the breaker box. extension cord was getting too long and I said it's not a good idea. It had to go under the garage door and loop back ... we had to drill a hole from outside close to the switch and ended up using a very short cord. 15+ years later and he hasn't complained yet so it must still be working. Granted we don't lose power that often.
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5396129 04/07/20 07:38 AM
Donald Offline
You should have bought a welder/generator.
2015 Ford F-250 w/Powerstroke
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5396149 04/07/20 08:02 AM
tom slick Offline
I made the exact adapter you describe for my welder. It works well.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: 240V Electric Hookup Questions [Re: Donald] #5396613 04/07/20 04:17 PM
9
9
Didn't want a welder/generator... Less features for more money, no way to separate the two, no thanks.
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5406858 04/18/20 09:54 AM
9
9
I wired up my extension cord that coverts a L14-30 to a NEMA 6-50R. I checked the outlet with a multimeter before I plug my equipment in and I measured:
240V between both hot legs and 120V between either hot leg and ground. Is this correct? Given the 6-50R does not use the neutral wire, I was surprised to find 120V at the ground terminal.
The manual for the generator suggests two different ways of wiring it: neutral bonded to frame (default) and floating neutral. Do I need to use the floating neutral method to utilize a 6-50R outlet, or am I okay with leaving it set up to the default (neutral bonded to frame)? Figured I better check before I fire the welder up.
Re: 240V Electric Hookup Questions [Re: 92saturnsl2] #5407239 04/18/20 07:10 PM
tom slick Offline
The neutral and ground are bonded at your main panel. They are essentially redundant systems. That’s why you have 120 to neutral or ground.
As for your generator’s neutral, the floating neutral would be used if you are hooking it into your house. The bonded neutral is if you are using it as a stand alone.
