bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
25 registered members (CB900F2, chrome, 4WD, DaHen, 5 invisible), 788 guests, and 40 spiders.
Topics306,116
Posts5,287,815
Members71,604
Snapper drive belt install trouble LT300 #5395729 04/06/20 05:56 PM
spk2000 Offline OP
Having trouble getting belt over the pulley. Gap too small between frame and top of pulley to get belt onto pulley. Looks like nuts can be turned to slide the lower pulley section which may create a better gap. Anyone ever done one like this?
Thanks
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5395732 04/06/20 05:57 PM
spk2000 Offline OP
The belt seen is the broken one before I took it off
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5395733 04/06/20 05:57 PM
spk2000 Offline OP
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5396132 04/07/20 07:39 AM
V
vwmaniaman Offline
V
Usually on main drive belt with belt guides you have to loosen the center bolt on the motor crankshaft and pull down the pulley and istall the belt and re-install pulley on the crankshaft.
Don't waste your time on a slipshod repair.
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5396157 04/07/20 08:19 AM
M
mk378 Offline
M
The belt can't be installed by putting it over the top of the pulley because the engine shaft is there. You will need to remove the blade belt and put the new drive belt on from the bottom. Then either move the keeper guides or like @vwmaniaman said take out the shaft center bolt and slide the clutch and all the pulleys down. Do not loosen any of the three bolts on the side of the triangle part, those are holding the clutch together.
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5396173 04/07/20 08:41 AM
Cujet Offline
Looks to me like there is a removable belt guard by the pulley.
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5397029 04/08/20 06:06 AM
spk2000 Offline OP
Thanks everyone. Crankshaft did need to drop and the belt guide was fixed so engine had to be lifted slightly. Running great now.
Re: Snapper drive belt install trouble LT300 [Re: spk2000] #5401115 04/12/20 12:19 PM
H
HangFire Offline
H
Better than many MTD products. On my Cub Cadet you had to pull the engine or cut a flange to replace the drive belt.
Various musings: http://hangfire.net
