Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
30 registered members (blufeb95, Cdn17Sport6MT, bachman, alchargo, Avery4, ctechbob, 1 invisible), 1,344 guests, and 27 spiders.
Topics306,109
Posts5,286,660
Members71,586
Shell oil help #5395434 04/06/20 12:18 PM
I
IvanPletex Offline OP
I
Hi,
What is the diffrence between Shell helix ultra 5w40 and Shell helix ultra 5w40 ( with Diesel sign on it).
For my car is recommended one without diesel sign, but I excidently bought one with diesel label. Also my car is diesel. Will It cause any problems ? Or can I use it without worries?
Re: Shell oil help [Re: IvanPletex] #5395444 04/06/20 12:31 PM
K
kschachn Offline
K
In and of itself the word "diesel" doesn't mean much, what matters are the approvals and certifications. What is different between the two and what do you need? If both have what you require then either one is fine. If not, pick the one that has what you need.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Shell oil help [Re: kschachn] #5395447 04/06/20 12:34 PM
I
I
As I know, my car needs 5w40 A3/B4 API CF both are that. But I wonder what means Diesel on package...
Re: Shell oil help [Re: IvanPletex] #5395453 04/06/20 12:39 PM
K
kschachn Offline
K
What licenses and approvals does each oil have?
1994 BMW 530i, 252K
Re: Shell oil help [Re: kschachn] #5395461 04/06/20 12:50 PM
I
I
This is OEM oil sheet for my car.
Re: Shell oil help [Re: IvanPletex] #5395466 04/06/20 12:56 PM
I
I
On shell page, finder says for my car is shell helix ultra 5w40, as I said I bought shell helix ultra 5w40 (diesel). Who knows main diffrence between this two? Thanks.
Re: Shell oil help [Re: IvanPletex] #5395470 04/06/20 01:01 PM
K
kschachn Offline
K
You were asking why one container says "diesel" and the other one does not. That specific question isn't related to what your car needs or requires.
The main difference is in the certifications, licenses or approvals each oil has or does not have.
If you post the list of the certifications, licenses or approvals each oil has or does not have then you will answer your question.
1994 BMW 530i, 252K
Re: Shell oil help [Re: IvanPletex] #5395474 04/06/20 01:11 PM
J
JohnG Offline
J
Just guessing here, but what is the sulfated ash content of each? That MIGHT be the difference.
Re: Shell oil help [Re: IvanPletex] #5395476 04/06/20 01:12 PM
U
UG_Passat Offline
U
https://www.shell.com/motorist/oils...y-synthetic/shell-helix-ultra-5w-40.html
API SN/CF; ACEA A3/B3, A3/B4; BMW LL-01; MB approval 229.5, 226.5; VW 502.00/505.00; Porsche A40; Renault RN0700, RN0710; PSA B71 2296, Ferrari. Meets the requirements of Fiat 9.55535-Z2 and Chrysler MS-10725
https://www.shell.com/motorist/oils...etic/shell-helix-ultra-diesel-5w-40.html
API CF; ACEA A3/B3, A3/B4; BMW LL-01; MB approval 229.5, 226.5; VW 505.00; Renault RN0710. Meets the requirements of Fiat 955535.Z2
UltraDiesel appears to be the same, but doesn't list some gas specs it already meets.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Shell oil help [Re: UG_Passat] #5395782 04/06/20 06:52 PM
K
kschachn Offline
K
There you have it. An amazingly scant difference, considering the substance of those approvals.
1994 BMW 530i, 252K
Re: Shell oil help [Re: IvanPletex] #5396626 04/07/20 04:28 PM
K
Kamele0N Offline
K
Additionaly....diesel version is usually more expensive for a few bucks for a jug...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Shell oil help [Re: IvanPletex] #5397004 04/08/20 02:47 AM
F
FordCapriDriver Offline
F
Probably actually the same oil just in different bottles, SHU 5W-40 is probably perfectly able to meet all those specs without a separate diesel version.
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
