Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
Coolant UV Dye - for without flushing
by Ndx - 05/24/20 09:10 PM
STP S8A C&P
by mpack88 - 05/24/20 07:50 PM
Aprons
by buck91 - 05/24/20 07:35 PM
Oil Additives for GDI engines
by Drew99GT - 05/24/20 07:21 PM
Memorial Day - Veteran's Cemetery
by JeffKeryk - 05/24/20 07:18 PM
rickyradit, YogiTheCat, StevePLR, BBC_bias, rabblrouzr
71525 Registered Users
100 registered members (4WD, 2015_PSD, 14Accent, 87sammy, 2010Civic, 53' Stude, 7 invisible), 2,519 guests, and 21 spiders.
Topics305,839
Posts5,281,254
Members71,525
Roller lubrication on door hinges #5395214 04/06/20 07:45 AM
Snagglefoot Offline OP
I had a look at my driver’s side door hinge of my 2008 Suburban and compared its function to the other three doors.I noticed the steel roller mounted on the vertical pin was not rotating on the driver’s door. Instead, the pin itself was doing the rotating as the door was opened and closed. I imagine this would eventually cause problems.
It took several carefully aimed shots with GM’s Super Lube with Teflon to clean out the black gunk between the roller and pin. I use that lube and also white lithium grease but I probably didn’t aim it well enough to enter the gap at the top of the roller. Cold weather just makes it worse. Check your rollers! laugh
If you want the job done right......do it yourself.
Re: Roller lubrication on door hinges [Re: Snagglefoot] #5395393 04/06/20 11:20 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Im not sure lithium is great in there long term. I think that's why GM sells that super lube. That, or an oil perhaps, would be better as it wont gunk up, collect a ton of dust, and dry out.
Im actually thinking an 00 type grease is likely best to be in there...
Re: Roller lubrication on door hinges [Re: Snagglefoot] #5395411 04/06/20 11:52 AM
U
UG_Passat Offline
U
Maybe try Boeshield. If it works for bicycle chains, it should work on doors.
I eventually switched to it, as I ran out of Wurth HHS-K, and it is hard to find and quite pricey.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Roller lubrication on door hinges [Re: Snagglefoot] #5395436 04/06/20 12:21 PM
B
Bebop367 Offline
B
Fluid Flim is the best I tried. Gets in there and stays a long time.
Re: Roller lubrication on door hinges [Re: Snagglefoot] #5395475 04/06/20 01:11 PM
Dave9 Offline
Yeah once you let the grease dry out, the damage gets done and you're left trying to merely stop it from getting worse. That and those vehicles that use nylon bushings that just wear no matter what because plastic.
Re: Roller lubrication on door hinges [Re: Bebop367] #5395498 04/06/20 01:33 PM
F
ford46guy Offline
F
I agree. I have old cars in the salt belt and the lock mechanisms look brand new. Every 6 months they get doused in it.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Roller lubrication on door hinges [Re: Snagglefoot] #5395613 04/06/20 03:39 PM
Here is what the GM owners manual has recommended for years. Canadian part number shown.
Re: Roller lubrication on door hinges [Re: Snagglefoot] #5396017 04/07/20 01:20 AM
Here is a page from the 2019 Chevy Silverado owners manual. No matter what lube you use, make sure that roller is turning on the pin. laugh
Re: Roller lubrication on door hinges [Re: Snagglefoot] #5396052 04/07/20 04:59 AM
O
OilUzer Offline
O
I've used WD-40 to clean and then drop or two of engine oil and it works pretty good. iirc, had a silicon? spray in the garage somewhere and that works good also ... but last time I couldn't find it and went the WD-40 route.
WD-40 solves half the world's problems grin2
Re: Roller lubrication on door hinges [Re: OilUzer] #5396065 04/07/20 06:11 AM
4WD Online Confused
Online Confused
That’s pretty much how I use WD40 … kinda like a pre flush that’s compatible with a bit of thin oil behind it.
I still use 3 in 1 on hinges … don’t always want a big spray can and they have some clever tips these days.
Re: Roller lubrication on door hinges [Re: Snagglefoot] #5396180 04/07/20 08:46 AM
I
ironman_gq Offline
I
Flush it out and spray it with Boeshield T9 or Fluid Film, I've limped those rollers along for years doing this. Never did understand why Chevy stuck with that setup and used the internal ones on the GMC line until relatively recently, the GMC ones just work and stay quiet.
