Fram Xg3682 for ISO 32 🛠
California
Hi,
I'm looking into buying a Champion 27ton Log Splitter from Home Depot. I would buy it in the box and assemble it myself. Always wanting "better" I was trying to upgrade the hydraulic filter. With the filters listed in the manual (pictured below) would the Fram Xg3682 (specs below) be the "best" filter to use? I've never dealt with hydraulic fluid and would appreciate your opinions and recommendations.
Thanks in advance! ...
I'd probably stick with what it recommends since it's a filter in a hydraulic system that probably has rather particular requirements, that being said the specified Wix filter has microglass filter media and is rated at a nominal 11 microns, so it's probably pretty similar to the Fram Ultra but is spec'd for this application, so I'd use it.
[Linked Image]
[Linked Image]
51361 is specified, not 51631.
WIX 51361 crosses over to the Fram XG3682 on Fram's website.
[Linked Image]
[Linked Image]
Oops, I transposed the digits.
