Originally Posted by WillB
I am staying synthetic!
Can't run a 5W30 in the LT engines due to AFM & VVT.
You can use whatever viscosity grade you like ... however the above statement is not valid as far as I know. Maybe you should spend more time on bitog or I should spend less
Edit:
Fyi, I have a 0W20 truck (vvt-i but no cylinder activation/deactivation thingy) and it's getting a relatively higher hths 10W30.
Edit:
