TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
24 registered members (dishdude, ArrestMeRedZ, clinebarger, Alfred_B, bachman, 2 invisible), 1,185 guests, and 17 spiders.
Topics306,033
Posts5,285,244
Members71,566
Page 1 of 3 1 2 3
Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? #5394498 04/05/20 12:25 PM
G
giantsforever Offline OP
G
I want to reduce oil burning and clean both my piston oil rings and my piston oil holes without having to overhaul the engine.
I reviewed threads in the UOA and this forum, but did not see a discussion of the latest (SN) version of Pennzoil Ultra and Platinum.
Pennzoil's website didn't clarify the difference.
Looking at the oil container, both have 3 star ratings for engine wear and piston cleaning.
Besides about a $5 per 5 quart difference, is there any difference between them?
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394507 04/05/20 12:34 PM
N
nobb Offline
N
For the average vehicle, I really don't see what kind of measurable difference you would see upgrading from Platinum to Ultra Platinum. Many would argue even that going from the cheapest conventional that meets the necessary manufacturer and API ratings, to a synthetic like Pennzoil Platinum would not yield any measurable difference either in a typical daily driver application.
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394510 04/05/20 12:36 PM
T
Toh1 Offline
T
I would says use Ultra for few oci like 2-3 then change brand of oil to any other brand you like but I would recommend Mobil 1 2-3 oci has AN ester which clean your engine slowly then used any other brand you like this is my 2cents or opinion . For oil burning Rislone engine treatment 16oz or if you want to used additive to clean engine
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394541 04/05/20 01:04 PM
Snagglefoot Offline
Here's a comparison. Ultra has a slightly higher kinematic viscosity. These charts don't hold much info on the base oil.
If you want the job done right......do it yourself.
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394600 04/05/20 02:38 PM
dubber09 Offline
I used both and while I liked PUP better I'd not pay much more for PUP over PP - I'd only buy PUP if the price was about same as PP.
IMHO, PUP is considerably better than PP thou.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394604 04/05/20 02:44 PM
G
G
dubber09, thanks. How is the PUP considerably better than the PP?
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394619 04/05/20 02:57 PM
R
rob1715 Offline
R
From what I've seen here and comparing both oils, PUP has a touch more additives. I don't see much difference in the long run. There was a post not too long ago where someone used Mobil 1 every 10k miles and his vehicle was perfect at 218k miles when the valve cover was changed. API certified oils are good. Synthetic has been known to flow better so I use PP 5w30. High mileage PP might be good but the jury is still out on whether it makes a marked difference. PP and PUP have better than average NOACK compared to others.
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394642 04/05/20 03:20 PM
R
RavenTai Offline
R
I was recently looking for the same answer, the VOA's show slightly more additives in the PUP, and the pup is slightly thicker, difference is not large. Pennzoil claims better cleanliness with the PUP, how or why they don't elaborate. is it all just marketing to hype a "premium" product for increased profit? or is there a grain of truth in these claims? I don't know. so is the nebulous "better" worth the extra cost? hard question to answer with limited data.
What I did find is that PUP at Walmart.com 6 x 5qt jugs are the same price as at my local brick and mortar Walmart as the vanilla platinum, actually $0.02 cheaper per jug, so I got "better" (supposedly, maybe?) for the same price, I need to change the oil in 2 large sump Toyota's now, and I will have enough left over for another change later and some top off in-between. that allowed me to stop worrying about it and just buy the ultra. maybe I got better oil, or maybe it wont make a difference but I did get a prettier bottle and that makes me happy. and having a clear decision let me move forward without my OCD pestering me.
Its cheaper than the M1 EP I used to run, it turns in Good UOA's, reports from users show excellent cleanliness under the valve cover at least so I went for it, 5 of my 6 jugs just got here today. the 6th gets here tomorrow, they shipped from different warehouses. free shipping and no extra exposure to this CO-vid mess.
2016 Toyota Sequoia
1999 Lexus LS400
1997 Toyota T100
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394732 04/05/20 05:02 PM
simple_gifts Offline
Perhaps this is a good case for Valvoline's Premium Blue Restore; It is an oil specifically designed to clean up carbon deposits.
What engine and mileage are we talking about?
2004 Prius; 131K; ATM
2007 Yaris 108K ATM
2006 B2300;137K;ALM
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394742 04/05/20 05:13 PM
T
Triple_Se7en Offline
T
You can get Ultra Platinum for the same price as Platinum - over at walmart.com. Two jugs or $35 spent, gets you free shipping.
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: simple_gifts] #5394810 04/05/20 06:25 PM
G
G
Thanks, simple_gifts. On Amazon, I could only find a synthetic blend for 10W-30 (nothing for 5W-30). They also said nothing about being specfically designed to clean engine deposits.
Likewise, Valvoline.com says nothing about that and was more spartan as to specific oil grades than Amazon:
https://www.valvoline.com/en-mea/our-products/premium-blue-products
I'm hesitant to use synthetic blends.
Do you have a link to any available Valvoline Premium Blue Restore full synthetic 10W-30 or 5W-30 (if any) and a discussion about this specific design?
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394842 04/05/20 06:57 PM
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4230571/valvoline-premium-blue-restore
Just skip over the snarky commentary; clearly people kicked it to the curb before understanding the possible benefits.
It is a product designed by Valvoline to specifically address an issue with certain cummins engines.
There may be BITOG'rs using it right now and there might be some reports on it. Not cheap (> $70/gal) but if it solves a ring sticking issue it is $ well spent.
Once again, engine and mileage?
2007 Yaris 108K ATM
2006 B2300;137K;ALM
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394851 04/05/20 07:08 PM
G
G
Thanks. 1996 Toyota Tercel 152k miles with stock 5EFE engine. Maybe there just weren't that many made, so that's why I can't find whether this engine has a bad rep of being an oil burner, such as Generation 8 Corollas (1998-2002)?
Amazon also removed the Valvoline Premium Blue Restore from my search; maybe they can't ship it to California frown
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394949 04/05/20 09:17 PM
K
khittner Offline
K
With Valvoline Premium Blue Restore, the value of the crankcase contents would exceed the value of a 24yr-old Tercel. Routine 5K-mile OCIs with a 5w-30 synthetic is all that’s warranted. Oil is cheap, so keep a tightly-closed 5qt. jug of Supertech, Kirkland, or Amazon Basics in the trunk, add as needed, and drive on.
Re: Your Opinion on Pennzoil Ultra Platinum 5W-30 (SN) vs. Pennzoil Plantinum (SN)? [Re: giantsforever] #5394999 04/05/20 10:19 PM
A
ae101 Offline
A
My previous car was a 7th gen corolla with a 4afe engine when I was living on the other side of the pacific. Most probably not a different animal from yours, i used 5w40 and 10w40 depends which I can get cheaper. And it was not an oil burner with 160k kms on it. No top ups between oil changes. And i do oil changes every 10k kms. Heck i bet i can use my wife's favorite cooking oil in it and it will still run. Lol.
Page 1 of 3 1 2 3
