TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
19 registered members (Char Baby, bachman, CatCam2, bbhero, 2015Corolla, 2 invisible), 1,096 guests, and 46 spiders.
Topics306,033
Posts5,285,256
Members71,566
what would you do #5394493 04/05/20 12:17 PM
F
FT92 Offline OP
F
I bought a new basic push mower late last year 3.5 briggs...used it maybe 3 times last year and i'm about ready to use it again...my question the oil is like new , clear and maybe a total of 3 hours at the most. would you change it or just use it as is ?
Re: what would you do [Re: FT92] #5394494 04/05/20 12:18 PM
demarpaint Offline
I'd use it, change it at the end of the season before you put it away for the winter.
God Bless Our Troops
Re: what would you do [Re: FT92] #5394501 04/05/20 12:28 PM
Dave9 Offline
Same, use it. Is that one of those engines where they pretend that the oil is lifetime and never needs changed (lol) ?
Re: what would you do [Re: FT92] #5394516 04/05/20 12:40 PM
gathermewool Offline
I usually follow the owner's manual (or am more conservative), UNLESS it says that changing ISN'T necessary - just top-off.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: what would you do [Re: FT92] #5394521 04/05/20 12:44 PM
L
Lubener Offline
L
I would change the initial fill at 5 hours regardless of color then at the end of each mowing season thereafter.
The "thinking" man's friend.
Re: what would you do [Re: Lubener] #5394547 04/05/20 01:10 PM
MolaKule Offline
Global Moderator
Global Moderator
Same here.
Drain it and see what comes out at the bottom and then look at the oil in the sunlight.
Dipsticks are shiny and tell you nothing about the oil at the bottom of the sump or how the oil's chemistry has changed with usage and storage.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: what would you do [Re: FT92] #5394549 04/05/20 01:14 PM
doitmyself Offline
I agree with Lubener and Molakule, but would push it to about 8 hours and then get rid of the break in oil. Did you extract a good amount of oil to determine your "like new" assessment? Unless Briggs came up with new engine manufacturing methods, I bet when you drain it you will see lots of sparklies when the oil is pooled in drain container.
Re: what would you do [Re: FT92] #5394555 04/05/20 01:20 PM
Snagglefoot Offline
I would use it the entire season and then change it.
If you want the job done right......do it yourself.
Re: what would you do [Re: FT92] #5394568 04/05/20 01:34 PM
B
BigCahuna Offline
B
I would suck it out of the mower, run it thru at least 2 separate coffee filters and put it back in. You know that oil is fine to use, just need to get the crumbs out if it. Most people never change their mowers oil and they last for years. Even the cheap models.,,,
Re: what would you do [Re: FT92] #5394574 04/05/20 01:43 PM
O
Oildudeny Offline
O
I'd change it. Every spring I start with fresh oil in my mower. Sitting all winter with last years dirt and not to mention the moisture.. dump it
Re: what would you do [Re: FT92] #5394614 04/05/20 02:53 PM
toneydoc Offline
Use it with no doubts.
Many people buy mowers and use them for years before they change the oil
Some mower manufacturers even say you never need to change the oil. I do not believe that
but I do know that oil is fine after 3 hours.
1994 Jeep 168k NextGen 10w30
2014 Camry 44k Castrol Magnatec 0w20
2018 Jeep Cherokee 8k Pennzoil Platinum 5w30
2014 HD Ultra 51k Mobil1 15w50
Re: what would you do [Re: FT92] #5394621 04/05/20 03:01 PM
R
rob1715 Offline
R
Oil is cheap. Drain and refill.
Re: what would you do [Re: FT92] #5394888 04/05/20 07:40 PM
spasm3 Offline
I change new ope engines at 15 minutes, again after 3 hours, then once a year. For my pushmower i change it every 2 years, as it is not run that much.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: what would you do [Re: FT92] #5394956 04/05/20 09:24 PM
R
Rand Offline
R
I'd change it, all the crud from making the engine is in there.
after that, every couple years or 50hours.
Re: what would you do [Re: FT92] #5396068 04/07/20 06:27 AM
F
FT92 Offline OP
F
thanks guys for all the info...what I might do is run it one or two times yet then change it
