0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Rotella Multivehicle 5W-30
by js1956 - 05/31/20 10:54 AM
Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Keep OE carb vs replacement
by JHZR2 - 05/31/20 10:00 AM
Gave away some of my stash
by Chris142 - 05/31/20 08:32 AM
Two year check in - Dewalt 20 V String Trimmer
by Snagglefoot - 05/31/20 08:07 AM
Sturmey Archer 3 Speed-Shifting?
by ET16 - 05/31/20 07:45 AM
AbbeyRoad, RPF, Rayi, juca, jrow96
71584 Registered Users
99 registered members (86cutlass307, 330indy, 97prizm, 2010Civic, 53' Stude, addyguy, 9 invisible), 2,432 guests, and 37 spiders.
Topics306,100
Posts5,286,420
Members71,584
Honda V6 PCV Valve - Steel Bolt #5394470 04/05/20 11:50 AM
SWS Online Content OP
OP Online Content
Honda Accord V6 - 2006, 95K miles, purchased new, Mobil 1 since new on 6-mo OCI, Climate: TN, mostly in-town driving.
Changing the PCV valve for the first time in 14 years.
I have it apart and all looks very clean inside the manifold.
Old PCV valve was coated in thin film of oil, no grit or sludge externally.
However PCV does not 'rattle' like the new one.
I will tear it apart later to check for blockage or broken spring as SatinSilver has mentioned.
New PCV is genuine Honda. I put a bit of engine oil on the O-Rings and it slid right in.
My Q is about the steel bolt & aluminum manifold threads.
Removing bolt went well, and both are in OK condition.
Aluminum manifold threads have a bit of white oxidation.
Bolt dragged while hand-turning it in, so I instinctively rubbed some M1 oil from my drip paper towel on the bolt threads and this helped.
Is this adequate, or should I do something more?
WD-40 / PB Blaster / Other? Since it gets hot, I do not want to add something that will gum-up the trreads, but I also want to take this bolt off again in 10 years, and the oxidation is a bother.
Thanks for your help!
SWS
Re: Honda V6 PCV Valve - Steel Bolt [Re: SWS] #5394474 04/05/20 11:57 AM
K
KGMtech Online Happy
Online Happy
K
Apply anti-seize to those threads and in 10 years you will be glad. Grey stuff for this application, I think it would be better than the copper coloured stuff.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Honda V6 PCV Valve - Steel Bolt [Re: SWS] #5394511 04/05/20 12:37 PM
P
painfx Offline
P
I don't add anything on my Accord 4 Cylinder. I just remove and replace the PCV.
Re: Honda V6 PCV Valve - Steel Bolt [Re: SWS] #5394611 04/05/20 02:52 PM
K
Kestas Online Content
Global Moderator
Online Content
Global Moderator
K
In my opinion I believe every steel fastener threaded into aluminum should have the threads coated with antiseize.
Same for stainless steel.
Re: Honda V6 PCV Valve - Steel Bolt [Re: Kestas] #5394653 04/05/20 03:38 PM
The Critic Offline
Do you recommend copper or nickel anti-seize?
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Honda V6 PCV Valve - Steel Bolt [Re: SWS] #5394846 04/05/20 06:59 PM
K
Global Moderator
Online Content
Global Moderator
K
I would recommend the Permatex stuff that is commonly available. Copper or nickel would work as well -- but these are more for higher temp applications.
Re: Honda V6 PCV Valve - Steel Bolt [Re: SWS] #5395455 04/06/20 12:41 PM
B
bulwnkl Offline
B
I’m with Kestas. Just normal silver-colored Permatex stuff for this, to have the best chance of removal without incident in another 15 years.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
