Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
59 registered members (alchargo, azianbob, Astro14, 4WD, 86cutlass307, 2010Civic, 5 invisible), 1,360 guests, and 57 spiders.
Topics306,050
Posts5,286,400
Members71,593
Blueing steel #5394061 04/04/20 11:53 PM
K
koffy Offline OP
K
I want my slx 7100 groupset to look black,,,, Casey super blue is in my mind,,, tell me about your experience with this stuff.🤔
Re: Blueing steel [Re: koffy] #5394106 04/05/20 02:15 AM
V
vavavroom Offline
V
Isn't the cassette nickel-plated? You'd have to remove the plating. I suppose you could add a black nickel plating on top but its not very wear-resistant. Or maybe strip the nickel and have the steel parkerized. This would be the most durable solution, I think. Someone might suggest using a Sharpie. Just saying.
There is also JAX Iron, Steel & Nickel Blackener. No idea how well it works and if the finish is resilient.
https://jaxchemical.com/shop/jax-iron-steel-nickel-blackener/
Re: Blueing steel [Re: koffy] #5394109 04/05/20 02:17 AM
O
Olas Offline
O
I dont know your location, however, every gun shop I can think of in my area offer a blueing service - leave the hardware with them and pick it up 1 week later.
Re: Blueing steel [Re: koffy] #5394232 04/05/20 07:58 AM
L
Langanobob Offline
L
Aren’t all the parts either plated steel or anodized aluminum? Hard to blue those. Not trying to be a smart aleck but I would experiment on a part or two with a Sharpie and a light clearcoat.
Re: Blueing steel [Re: koffy] #5394471 04/05/20 11:50 AM
K
koffy Offline OP
K
All the cogs but one are made of steel, however, they don’t rust so there must be a kind of platting,,, it’s gonna be harder than I though I guess.
Thanks for your help.
Re: Blueing steel [Re: koffy] #5394559 04/05/20 01:22 PM
V
vavavroom Offline
V
Usually, there's nickel plating for corrosion protection. You can easily confirm where the chain has worn the plating off, or if a new cassette, you can scuff an edge. Under the nickel plating is always copper plating. You should be able to see a copper-colored outline along the wear edges.
