Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
93 registered members (bbhero, antonmnster, Astro14, 5AcresAndAFool, 77GrandPrix, Alfred_B, 9 invisible), 2,116 guests, and 45 spiders.
Topics306,108
Posts5,286,601
Members71,586
Baldwin B5134 Coolant Filter Cut Open #5393992 04/04/20 09:32 PM
F
FordFETruck Offline OP
F
About 750 or so miles on it and about 2 months. When I initially installed the filter it plugged immediately so It took it back off and washed it out, tons of crud came out when I did that then!
The car is a 99 grand marquis which is in great shape except it had the original what used to be green coolant in it when I got it. I've flushed the system 3 times now and put all new hoses on and a new water pump as well as a overflow tank for preventative maintenance and converted to G-05 coolant. This system was nasty.
91859703_296794181332890_5973745122947366912_n.jpg91873018_218043646177006_7899843728192307200_n.jpg
1986 F250. 4x2 351w Edelbrock heads, xe250h cam and the works. 245k miles
1999 Mercury Grand Marquis gs 4.6. 3.27 LSD, JMOD 120k miles
Re: Baldwin B5134 Coolant Filter Cut Open [Re: FordFETruck] #5394020 04/04/20 10:27 PM
R
rubberchicken Offline
R
What type of mount did you use ? I was interested in putting one on my boat.
Re: Baldwin B5134 Coolant Filter Cut Open [Re: rubberchicken] #5394101 04/05/20 01:56 AM
F
F
I used a Moeller fuel filter base with the 11/16 threads. Only reason I chose that is I use that filter for a fuel filter for my truck and kept the fuel filter it came with as a spare, plus it was cheaper than the other coolant filter bases. Worked out really well.
Re: Baldwin B5134 Coolant Filter Cut Open [Re: FordFETruck] #5394112 04/05/20 02:24 AM
O
Olas Offline
O
Remove and backflush the radiator to get a lot of material out,
Also run the engine with a hosepipe stuffed into the waterpump, let it through the block and spew out before re-entering the rad.
Re: Baldwin B5134 Coolant Filter Cut Open [Re: FordFETruck] #5394655 04/05/20 03:40 PM
53' Stude Offline
Very good write up and pictures. What filter did you pit back on? Thank You sir laugh
2009 Toyota Camry LE
Re: Baldwin B5134 Coolant Filter Cut Open [Re: FordFETruck] #5397335 04/08/20 11:44 AM
M
mattwithcats Offline
M
Wix 24019 filter base
Wix coolant filter
24069, short
24070, long
Do not use 24071-24075, they have additives in them...
Look on Rock Auto for good prices, but watch the shipping...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Baldwin B5134 Coolant Filter Cut Open [Re: FordFETruck] #5425250 05/10/20 06:23 AM
M
mpack88 Offline
M
I never heard of a coolant filter. Obviously this is something you did to clean the system. Can you do another post on how you did it. I have many vehicles, some with alot of crude. It's hard to get it all out.
Re: Baldwin B5134 Coolant Filter Cut Open [Re: mpack88] #5426481 05/11/20 02:25 PM
Colt45ws Offline
They are common on heavy trucks. Excess material circulating the system can affect the cylinder liners among other things. Things are different when you are trying to get a million miles out of a engine rebuild.
Some of us have installed them in other vehicles because they do help when you have a poorly or never maintained cooling system.
Ive posted some pics in this thread about putting one on my Crown Vic.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Baldwin B5134 Coolant Filter Cut Open [Re: Colt45ws] #5430406 05/16/20 06:30 AM
M
mpack88 Offline
M
Coolx thanks man.
