Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
53 registered members (bullwinkle, 4WD, 86cutlass307, 2010Civic, Amkeer, 5 invisible), 1,308 guests, and 71 spiders.
Topics306,050
Posts5,286,395
Members71,593
Touch up paint #5393941 04/04/20 08:31 PM
W
WhyMe Offline OP
W
got a couple of chips in my honda civic already. i was gonna get some honda factory touch up paint ,but some of the reviews on Amazon says its does not match well. one place i found online ask for a extra code. is the extra code really needed ? nh830m is the code for my car.
so anyone have experience with this company or can recommend another place online to get quality touch up paint.
https://www.paintscratch.com/touch_...Civic-Lunar-Silver-Metallic-NH-830M.html
Re: Touch up paint [Re: WhyMe] #5393968 04/04/20 09:01 PM
Dave9 Offline
Metallic paint never matches from a touch-up. The most you can hope for is that they made an honest attempt and it isn't much lighter or darker.
Re: Touch up paint [Re: WhyMe] #5393987 04/04/20 09:24 PM
G
gregk24 Offline
G
I have heard Doctor Color Chip is good. I used the OEM Volkswagen paint pen for our 2014 Jetta in Platinum Grey Metallic and it dried much darker than the paint.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Touch up paint [Re: WhyMe] #5394022 04/04/20 10:28 PM
9
97prizm Offline
9
Around here Napa matches paint very well.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Touch up paint [Re: WhyMe] #5394102 04/05/20 02:02 AM
bachman Offline
I've heard the better results have to do with a layer or two of clearcoat after the initial touch up color is layed in.
"Leveling" the chip has a lot to do with how light is reflected and hits the surface.
The last touch up job I had was Brembro brakes on the Infiniti, a very weird golden color. One day, I noted a Civic in town that had to be so close it was good enough. Went straight to the Honda dealer and order the 'pen'.
It worked well but those calipers are well hidden so perfect or close enough ? Who knows .... LOL
95 Honda Nighthawk- Rotella T6 syn
17 Golf SW 4MO dsg- Dealer LOF/5-6k *New spec syn -VW/Audi XOM ?
16 Mazda CX9 Tour- Dealer LOF/5-6k Casterol full syn
Re: Touch up paint [Re: WhyMe] #5394158 04/05/20 05:39 AM
M
MoneyJohn Offline
M
I am looking for a touchup paint for 2015 Subaru (metallic silver) and came across Dr Color Chip
Re: Touch up paint [Re: WhyMe] #5394173 04/05/20 06:23 AM
A
Amkeer Online Content
Online Content
A
The touch up paint that I have for my Tacoma and Camry match extremely well. You have to make sure you shake the container for a minute or two to mix the paint properly. I would say most of the complaints are user error and should be ignored. There are plenty of people that don't have a clue, ignore the noise.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
Re: Touch up paint [Re: WhyMe] #5394302 04/05/20 09:06 AM
K
Kira Offline
K
Could you further describe the "color code" as we know it and then describe this "extra code".
For example: Are "both" codes on a plate or sticker?
Is the "extra code" possibly just a date code?
Could the "extra code" be an assembly plant code?
There's gotta be something to that.
Re: Touch up paint [Re: WhyMe] #5394349 04/05/20 09:48 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Ive been satisfied with paint scratch. As others have said, it’s tough to get a great match on metallics, especially if the paint is aged.
Re: Touch up paint [Re: WhyMe] #5394371 04/05/20 10:19 AM
Spector Offline
I have had good experience with this one
https://www.automotivetouchup.com/touch-up-paint
Re: Touch up paint [Re: Kira] #5394435 04/05/20 11:12 AM
W
WhyMe Offline OP
W
my code is U
https://www.paintscratch.com/hondatag.htm
Re: Touch up paint [Re: WhyMe] #5395337 04/06/20 09:59 AM
Dwight_Frye Offline
I have tried Dr. Colorchip twice. Both times for cars with metallic paint. I followed the directions to a T regarding stirring up the paint and shaking it as well. In the case of the paint on my Nissan 370Z, the touch up paint was noticeably lighter. In the case of my Mazda CX 5, the paint was noticeably darker. Both were used when the cars were only a few months old and got their first rock chips so the factory paint hadn't faded. Good thing the chips to be repaired were just small rock chips or they would really stand out.
Their suggested technique of smearing the paint blob over the chip area with a latex gloved finger or thumb is one of the stupidest suggestions ever. I used a small wedge shaped silicone squeegee that came with a screen protector kit for a cell phone which worked very well. Why Dr. Colorchip doesn't include something like that with their very expensive kit is beyond me. I got one with a cell phone screen protector that cost under $10.
Re: Touch up paint [Re: Dwight_Frye] #5396948 04/07/20 11:13 PM
CaptainHazelwood Offline
They actually do include a silicone squeegee with the more expensive kits. I've had very good results with Dr. Colorchip. The color isn't always a 100% perfect match but neither are dealer touch-up paints in most cases. I imagine some are closer than others. Just got a promo code email today for 18% off: TOGETHER
[Linked Image from drcolorchip.com]
Re: Touch up paint [Re: WhyMe] #5397049 04/08/20 06:37 AM
R
RyanY Offline
R
I am far from a pro detailer/paint corrector but have tried numerous aftermarket touch up paints over the years. The best match has always been the touch-up paint I get at the dealer body shop (Honda black was perfect). The only caveat is that the dealer paint is just a bottle of paint and doesn't provide the additional equipment like the aftermarket kits do.
2007 Cadillac CTS 3.6L >130k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >108k miles; QSUD 0W20 + STP S6607XL
