Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
23 registered members (77GrandPrix, Char Baby, Astro14, Astro_Guy, 97prizm, BoiseBound, 2 invisible), 1,235 guests, and 52 spiders.
Topics306,049
Posts5,286,385
Members71,593
2020 M340i - CQuartz UK 3.0 & Gliss #5393880 04/04/20 07:14 PM
G
gofast182 Offline OP
G
So I chose CQuartz UK 3.0 and Gliss despite still being dubious of coatings: 2 years of protection...IF you have a sacrificial layer for what's supposed to be your 'super durable' sacrificial layer plus other bespoke maintenance products. Anyway it still seemed like a good choice for my car as a daily driver that lives outside. Plus I really wanted the experience of applying a 'big boy' coating under my belt (my previous coating experience was Polish Angel Cosmic V2 which was very simple to use). After reading good reviews of many CarPro products, I decided to stay in the family for other things used on this project.
My Portimao Blue M340i xDrive was a special order that I picked up at the BMW Performance Center in Spartanburg, SC (one of the best experiences of my life, do it if you're getting a new BMW). I got the car in December and used the winter to decide what to use for my LSP in the spring. I maintained it with regular washes only during winter. My first and main goal of this process was to remove some factory-installed marring and micro scratches. That was accomplished with CarPro Essense and my Rupes LHR15 Mk III polisher with yellow Rupes pad. One of the best things I did for this project was convert my old PC 7424XP to a 3" setup to allow me to get into the primary area the micro scratches were bothering me (angled upper portion of the door panels). With the PC I used a 3" URO-Fiber pad which is the best pad I've ever used.
The COVID-19 situation played right into this project (silver lining I guess) allowing me to take as much time as I wanted without having to drive the car. I used my old barn/garage which usually only holds one car, my 2006 Honda S2000 track car. The lighting in there isn't great which is one of the biggest lessons learned through this process: do everything you can to bring as much light to the process as possible. Where I thought things went off the rails in a major way was when I noticed that my microfiber towels were leaving fibers/lint behind as I buffed off the CQ UK 3.0. I thought I ruined the car (at least temporarily until the coating could be polished off). Luckily that wasn't the case. The fibers were mobile and the application of Gliss collected them at the end of each stroke and my new emergency-buy Costco microfibers then helped me get them off.
Not that some folks reading this don't know already, but it was no joke when it came to high spots. I'd put the high spots into three classifications: 1. legit high spots where you could feel and see the coating sticking up from the clear, 2. rainbow spots where the product wasn't wiped off fully, and 3. slight dark spots where the coating was wiped off but just a tiny bit more was there. I had one of the first kind at the base of my driver side A-pillar, two of the second kind on each side where the fender meets the bumper, and probably half a dozen of the slightly dark spots. The slight dark spots, were only noticeable after I thought I was done and pulled the car out into daylight. A couple of the slight dark spots I was able rub CQ UK 3.0 over them enough to get the solvents to reactivate the initial coating and remove the dark spot. The others were handled with Essence and my PC since the areas were small and the URO-Fiber pad was more effective (then re-coat and re-top with Gliss).
The end result is good and I'm happy with the finish. Looking perpendicular to the finish, the gloss doesn't look too remarkable; however, when looking at oblique angles there's a noticeable increase in reflectivity. The car hasn't seen rain yet but the majority of the car has had CQ UK 3.0 and Gliss on it for a week while in the garage. The touch up spots are currently at 24h post Gliss (48h post CQ UK 3.0). At this point am I glad I did it? Absolutely. I wish I had more product and another car to do it better.
Key lessons learned for newbies using Essence and applying CQ UK 3.0 and Gliss:
  1. The URO-Fiber pad was awesome, corrected and finished down effortlessly
  2. Having a 3" setup helped tremendously with tighter areas
  3. Do everything you can to throw as much light at the work as possible, diffuse light works even better for the coating part
  4. Use new microfibers with low pile/weight for coating removal, even if you've got a great cleaning process, don't assume they're clean
  5. You've heard it before but wipe well beyond the area you're working
  6. If correcting high spots don't tape off with painter's tape, the coating darkens the finish and you will then see a line where the tape was that's hard to blend back in
PRODUCTS USED:
Wash and decon:
Meguiar's D111
Two bucket method with grit guards
MTM Hydro: hose, gun, PF-22 foam cannon
Ryobi 1600/1.2 pressure washer
Merino wool wash mitt - flats
Detailer's Domain microfiber mitt - sides and lowers
CarPro Iron-X
Pinnacle Poly Clay
Absorber chamois
Metrovac Master Blaster
Polish/correction:
Rupes LHR15 Mk III
Rupes yellow pad
PC 7424XP
Chemical Guys 3" backing plate
URO-Fiber 3" pad
CarPro Essence
Cobra Gunmetal Elite 360gsm microfiber
Coating/LSP:
CarPro CQuartz UK 3.0
Cobra Gunmetal Elite 360gsm microfiber (not new)
Supreme 530 600gsm (secondary buff) (not new)
CarPro Gliss
Costco microfiber towels, low pile (NEW)
Wheels/calipers:
Tuff shine tire cleaner
Sonax Full Effect wheel cleaner
Meguiar's wheel brush
Kitchen sponge (for stubborn dirt on barrels)
(Same wash gear as above)
CarPro Multi-X (for calipers and wheel well liners)
Tuff Shine Tire Clearcoat
Misc:
Torin Big Red Creeper Seat
Scangrip headlamp
PHOTOS:
Here's what you're all waiting for, although it's not a super exciting transformation because it's already a new car...
These first couple shots were the primary goal of this mission...remove these defects!
[Linked Image from live.staticflickr.com]
A photo of the polishing process. I gained new respect for Brian from Apex Detail, Miranda Detail, Forensic Detailing, etc.. Not only is it not easy to take pics or video by yourself, it's even harder not to charge ahead and make progress instead of having the discipline to capture everything you want folks to see. I guess tripods and big memory cards help a lot.
Now on to the coating steps. Unfortunately I did not get a good shot of what the fibers looked like on the finish before Gliss. Imagine super fine lint/fibers stretched out straight going in the direction of how you buffed off the coating. What I'm going to show you here is how Gliss collected the fibers I was worried were cured onto the finish with the CQ UK 3.0. Then the new Costco microfibers removed them all when buffing Gliss off.
Random shot of the caliper after the first wheel removal. This was pre-clean and coat.
Here is one of the high spots that manifested as a rainbow. This had to be polished off, re-coated, and re-topped. Ironically, the same thing happened at the same spot on the other side.
Now for the end result!
2006 S2000 - Berlina Black - PU 10w30, PCX-004
2020 M340i xDrive - Portimao Blue - Dlr Fill, 114...898
2019 X5 xDrive 40i - Mineral White - Dlr Fill, 114...898
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5393903 04/04/20 07:35 PM
PimTac Offline
That looks real sharp.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5393909 04/04/20 07:37 PM
G
G
Thank you!
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5393911 04/04/20 07:38 PM
N
nicholas Offline
N
Nice job.
And really awesome car.
Wish I had one.
2019 2.0T Santa Fe
2010 3.5 Santa Fe
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5393953 04/04/20 08:36 PM
P
parshisa Offline
P
that paint looks awesome. I'm surprised though that all it took to get it corrected was just Essense
I really like carpro products, pretty much the vast majority of my detailing arsenal is carpro. My both Honda's are coated with CarPro Original - my wife's Pilot, a little over 2yrs already and still going, CQ UK - on my Civic - exactly a year and still no signs of coating degradation. I had some Gliss on hand (very first version) and really didn't like how it was applying so i gave up and just went with the mix of reload/ec2ho/water as a topper. All coatings are fairly easy to apply even for a rookie like myself.
I have a bottle of CQ UK 3.0 on hand and probably will polish and re-coat Pilot again. Slowing but surely running out of ideas what to do around the house during these days....
Yet again, congrats on awesome cars and really appreciate you keeping the paint in such an amazing condition!!!!
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5393984 04/04/20 09:22 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Nice pics! I’m a big fan of CquartzUK on vehicles, and am not dubious whatsoever. CQuartzUK is holding up on our metallic blue odyssey and my LeMans Blue 135iCM (also picked up at the performance center - agree, it’s a great experience!) quite well. Yes, I use HydrO2 or more recently, McKees 37 Hydroblue, but it’s as much a rinse aid as anything and can cpbe allied sparingly with zero additional work.
Car looks great, and I expect it will stay that way!
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5393989 04/04/20 09:27 PM
G
gregk24 Offline
G
Wow that looks good!
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5394163 04/05/20 06:08 AM
G
G
Thanks, guys!
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5394210 04/05/20 07:19 AM
Mr Nice Offline
Nice job. 👍
If you were near by I would pay you to detail my cars.
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5394755 04/05/20 05:28 PM
G
G
That's very nice of you to say, Mr Nice!
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: parshisa] #5394758 04/05/20 05:31 PM
G
G
Remember most correction has to do with the pad not the product. Essence has a mild cut and when paired with a pad that also has a mild cut but can still finish down it's just enough to get rid of that micro scratching.
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5394980 04/05/20 10:02 PM
Cujet Offline
Takes quite an eye to see those minor defects. In my current condition, I don't think I'd ever see them without 9.50 diopter reading glasses!!!
You did a great job and have a really nice car.
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5395082 04/06/20 01:12 AM
The Critic Offline
Looks great, and it sounds like you have mastered the process of applying one of the more challenging coatings. I have been meaning to do the Prius for a while and maybe this lockdown will allow me to find time to do so.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5395147 04/06/20 05:55 AM
RTexasF Offline
Absolutely superb! Having detailed for a living in the past I can truly appreciate the hard work you put in. Good equipment and products you've chosen.
Re: 2020 M340i - CQuartz UK 3.0 & Gliss [Re: gofast182] #5395175 04/06/20 06:49 AM
M
mightymousetech Offline
M
Very nice results. Have been considering using the UK 3.0 on my LMB 135i.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition PPE 5W40 MTL/MT-LV
2010 BMW 328i X-Drive, PPE 5W40 MT-LV
