Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Jcvjr, Haywood, ToOliwer, AbbeyRoad, RPF
71587 Registered Users
15 registered members (DaHen, BrianF, BretK, ArrestMeRedZ, bachman, 2 invisible), 1,101 guests, and 35 spiders.
Topics306,109
Posts5,286,665
Members71,587
MOPAR MO-285 CUT OPEN #5393776 04/04/20 05:53 PM
53' Stude Offline OP
Good Evening BITOGERS. This is off Colton, my farmer friends 2019 Ram 2500 6.7 Cummins powered pickup. Truck was at dealer while back as he lost I believe 3rd gear in it. Under warranty, so they did oil change on it also. This filter and whatever 10w30 HDEO Ram dealer uses. Had 7,000 miles on filter and oil. Truck has just at 21k on it. He hauls horses to shows as he barrel races and shows horses. We put in Harvest King 10w30 HDEO CK4 and a Baldwin filter. Forgot that #
Enjoy the pictures.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
2009 Toyota Camry LE
Re: MOPAR MO-285 CUT OPEN [Re: 53' Stude] #5393779 04/04/20 05:58 PM
W
walterjay Offline
W
Nice pics. Thanks.
Now I know that you have cut open about every brand on this side of the ocean. What would you say are the two or three best filter brands.
Re: MOPAR MO-285 CUT OPEN [Re: walterjay] #5393797 04/04/20 06:25 PM
Originally Posted by walterjay
Nice pics. Thanks.
Thank You for the kind words sir smile
IMO, I gotta say
1. FRAM ULTRA
2. WIX
3. BALDWIN, FEDERATED, HASTINGS
Re: MOPAR MO-285 CUT OPEN [Re: 53' Stude] #5393801 04/04/20 06:29 PM
W
walterjay Offline
W
Thank you. I have been using the Fram Ultras the past few years.
And Wix on Diesel.
Re: MOPAR MO-285 CUT OPEN [Re: walterjay] #5393840 04/04/20 06:53 PM
And Wix on Diesel.
Pops, or my real dad runs Baldwin on his R model Mack day cab 1984 era rig and on his 89' Cummins ram pickup.
Wix or NAPA GOLD for diesel stuff I would use without hesitation or worry
Re: MOPAR MO-285 CUT OPEN [Re: 53' Stude] #5393931 04/04/20 08:12 PM
B
Bighorn2500 Offline
B
Mopar MO-285 = rebadged Fleetguard LF3972 still a decent filter but there are higher efficiency options for about the same cost or just a little more.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: MOPAR MO-285 CUT OPEN [Re: 53' Stude] #5393945 04/04/20 08:33 PM
K
kstanf150 Offline
K
Diesels make some nasty looking used oil !๐Ÿคจ
Re: MOPAR MO-285 CUT OPEN [Re: kstanf150] #5393966 04/04/20 08:55 PM
Chris142 Offline
It is caused by the black smoke that you see or used to see from the exhaust. Some of it gets past the rings where it stains the oil.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: MOPAR MO-285 CUT OPEN [Re: kstanf150] #5393969 04/04/20 09:03 PM
Yup, soot from diesel combustion cycle actually makes the oil pitch black. Stains anything it touches too. The filter element burned right up in bout 15 minutes
Re: MOPAR MO-285 CUT OPEN [Re: kstanf150] #5393973 04/04/20 09:06 PM
Better explanation I should say, and not from smoke at all.
[Linked Image]
Re: MOPAR MO-285 CUT OPEN [Re: 53' Stude] #5394051 04/04/20 11:25 PM
Z
ZeeOSix Offline
Z
There's also soot in diesel smoke coming out the tailpipe when heavily "rolling coal". The "smoke' that gets past the rings (due to ring blow-by) is the same smoke that goes out the tailpipe.
https://www.youtube.com/watch?v=3nxgz6rOI_c
Re: MOPAR MO-285 CUT OPEN [Re: 53' Stude] #5394146 04/05/20 04:31 AM
PimTac Offline
Looks good. Thanks Adam.
A year old truck with transmission problems already? ๐Ÿ˜ง๐Ÿ™„
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: MOPAR MO-285 CUT OPEN [Re: PimTac] #5394225 04/05/20 07:47 AM
Yeah, I was surprised when he told me about it. Definitely wasn't happy bout it
