"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
Scam: Ghana $+2 - US $-2
by pandus13 - 06/02/20 01:09 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
41 registered members (carlprop, blufeb95, BlakeB, chemman, CELICA_XX, CDX825, 5 invisible), 1,376 guests, and 33 spiders.
Topics306,077
Posts5,286,941
Members71,596
Two filter sizes for Skyactiv 2.5? #5393513 04/04/20 12:31 PM
B
buster Offline OP
B
The oil filter Mazda parts gave me was a 1WPE-14-302, however the one I'm about to replace is a bit larger. Can I still use it? It's for a 2020 CX-30.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393518 04/04/20 12:37 PM
V
VQ35DE Offline
V
What is the one you are about to use ?
2017 Mazda CX-5 GS AWD
2018 Mazda 3 GT
2020 Toyota 4Runner Limited Nightshade AWD
2007 Chevrolet Colorado ZQ8
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393520 04/04/20 12:41 PM
B
buster Offline OP
B
The one I'm going to use is the 14-302. The one on there is a 302B.
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393521 04/04/20 12:41 PM
PimTac Offline
The 1WPE-14-302 is the one I use for my 2017 2.5. I am guessing the factory filter is Mexican sourced and what you have is Thai sourced.
I would have thought they would be the same size though.
PS: A quick call to the parts desk for confirmation wouldn’t be a bad idea.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393524 04/04/20 12:44 PM
B
buster Offline OP
B
Thanks. Parts is closed it appears.
So the one on my car is a Japan made 302B and the one I have is a 302 made in Thailand. Maybe I'll keep the filter on for this change.
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393526 04/04/20 12:46 PM
PimTac Offline
I was just going to add that as I researched that part number it comes up as a Japan made Roki.
2017 Mazda CX5
Roki OEM filter.
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393527 04/04/20 12:46 PM
B
buster Offline OP
B
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393531 04/04/20 12:49 PM
B
buster Offline OP
B
I've only used the 302 in the past from Thailand so I'll use it. Just confused me because the size is different.
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393533 04/04/20 12:53 PM
B
buster Offline OP
B
"I have been asked before about an OIL FILTER Removal Tool or Wrench for the Mazda superseded of the ORIGINAL OIL FILTER for ALL Skyactiv GASOLINE ENGINES, either 1.5 Litre, 2.0, and 2.5.
The Original now OLD Oil Filter was Mazda Part Number:
PE01-14-302 Oil Filter No Longer Parts Sold by Mazda Parts,
PE01-14-302A Oil Filter No Longer Parts Sold by Mazda Parts,
PE01-14-302B Oil Filter No Longer Parts Sold by Mazda Parts...
THE LATEST and NEW Genuine Oil Filter Worldwide is now Mazda Part Number 1WPE-14-302 Oil Filter.
Be aware these Oil Filter are SMALLER than the original, BUT is the Correct Unit to use and has the Correct By Pass Valve specification Installed.
The 1WPE-14-302 Genuine Oil Filter is for the following Mazda Models.
*Fit is for all Mazda Vehicles with SKYACTIV 4 Cylinder Gasoline:
(1500CC - 2000CC - 2500CC ) Model Years...
for Mazda 2 2014 ~
for Mazda 3 2013 ~
for Mazda 3 2019 ~
for Mazda 6 2014 ~
for Mazda MX-5 2016 ~
for Mazda CX-3 2014 ~
for Mazda CX-30 2020 ~
for Mazda CX-5 2013 ~
for Scion iA 2016 ~ 2018 (Mazda made only).
for Toyota Yaris 2019 ~ (Mazda made only)."
*For future reference.
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393538 04/04/20 12:58 PM
PimTac Offline
I always get a chuckle when the parts guy asks for the model and year knowing he is going to pull from the same shelf regardless.
I’m starting to think that Denso and Roki are running a joint factory in Thailand.
2017 Mazda CX5
Roki OEM filter.
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393544 04/04/20 01:03 PM
doitmyself Offline
Seems like you have it figured out. I wonder if it was similar to what Ford used to do. The OEM filter on the engine out of the factory was a Champion made Motorcraft filter. The Motorcraft aftermarket filters, whether supplied by a dealer or parts store, were made by Purolator.
Re: Two filter sizes for Skyactiv 2.5? [Re: buster] #5393545 04/04/20 01:04 PM
Mr Nice Offline
Are these engines are picky with the bypass valve psi like some other engines ?
Isn’t the same filter used on 2.0 and 2.5L engines ?
Re: Two filter sizes for Skyactiv 2.5? [Re: Mr Nice] #5393549 04/04/20 01:06 PM
B
buster Offline OP
B
I believe so yeah.
Re: Two filter sizes for Skyactiv 2.5? [Re: PimTac] #5393550 04/04/20 01:07 PM
B
buster Offline OP
B
LOL
Re: Two filter sizes for Skyactiv 2.5? [Re: doitmyself] #5393567 04/04/20 01:20 PM
R
Randy_R Offline
R
Is the bigger one Mazda Value Line? I took my 18 CX-5 back to selling dealer for the first oil change. Never saw what came from the factory but they gave me the bigger value line filter and overfilled it to make up for the value/cheap filter. I get the smaller made in Thailand filter from a different dealer and change it myself.
2018 Mazda CX-5 9000 miles Zepro advanced moly 0W-20 Mazda filter
08 Saturn VUE AWD 3.5 V6 70,000 miles Schaeffer 9000 5W30 Wix 51522XP
65 Pontiac Tempest 355 Chevy Schaeffer Racing 10W30 Wix 51061
