2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
bbrtuning, chapys, DaaBoss, C6H8O7, Jcvjr
71591 Registered Users
111 registered members (ABN_CBT_ENGR, 2165, 830Lee, 2015_PSD, 2004tdigls, 14 invisible), 2,379 guests, and 55 spiders.
Topics306,035
Posts5,286,136
Members71,591
Grease fittings on drop links - is this a defect? #5393420 04/04/20 10:51 AM
W
wolfestone Offline OP
W
Hi all,
I'm replacing some drop links and this is my first time dealing with ball joints that have zerk/grease fittings so I'm not sure if I'm missing something obvious here.
The ball joint links came from NAPA, and included grease fittings which install in a pre drilled hole on the side of each ball joint.
However, when I look in the hole, I see some of them have a very obvious channel which gives the grease a path to the ball. Others do not.
My best guess here is that when the ball joint cups are pressed into the drop link housings, they are supposed to align the grease channel on the cup with the hole in the housing, and they've failed to do so.
I've attached a photo of one that looks correct (red lines show where I see the channel) and also one that looks like it's misaligned with no way for the grease to get into the ball joint.
Apologies if this is a stupid question, just want to be sure that I'm not installing defective parts.
(the 'flake' of stuff inside the hole on the second picture isn't grease, it appears to be paint or powder coating that got scraped off when the ball joint was pressed in).
Ball joint WITH visible grease channel
Ball joint with no visible grease channel
Re: Grease fittings on drop links - is this a defect? [Re: wolfestone] #5393622 04/04/20 02:39 PM
B
bullwinkle Offline
B
I've always just pumped in enough grease to see the bellows/boot swell a little & then stopped. Can't remember ever having one fail doing that, I just figured it worked it's way in.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Grease fittings on drop links - is this a defect? [Re: wolfestone] #5396725 04/07/20 06:45 PM
W
W
Thank you, I'll screw in the fittings and see if I can get grease to flow through the ones that have no groove. smile
