Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
bbrtuning, chapys, DaaBoss, C6H8O7, Jcvjr
71591 Registered Users
82 registered members (14Accent, 4WD, 2015_PSD, 28oz, 10WSmuckers, 2010Civic, 8 invisible), 2,488 guests, and 26 spiders.
Topics306,031
Posts5,286,096
Members71,591
More home made junk #5393289 04/04/20 08:11 AM
P10crew Offline OP
More metal working tools. [Linked Image]
[Linked Image]
8” plate roller
7” press brake
I made a little bugger about 25 years ago that is now pretty much relegated to rod bending. Decided to make a bigger one. [Linked Image]
Re: More home made junk [Re: P10crew] #5393303 04/04/20 08:25 AM
53' Stude Online Content
Online Content
Very nice work. Thanks for the pics smile
2009 Toyota Camry LE
Re: More home made junk [Re: P10crew] #5393308 04/04/20 08:30 AM
Cujet Offline
NICE!!!!
I think we will see a move back to domestic manufacturing and maybe your "tools" should be a part of that. Many people don't realize that tool and die makers are now a rare breed here.
I needed to re-wind a high tension stator coil for a vintage motorcycle. 22,000 turns, and I was not about to do that by hand. So I made a spinning tool that held a spool of wire, counter balanced with a weight, and fed the tiny wire out via a set of tiny pulleys that created just the right wire tension. Mounted it in the milling machine and devised a way to move the "magnetic core" (the steel laminated plates) up and down at the correct rate, as wire was wrapped. It worked perfectly, and made a factory quality part. I'll post a pic if I ever find it again.
It absolutely could be used to make quality electric motor windings.
Re: More home made junk [Re: P10crew] #5393311 04/04/20 08:35 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Neat! Did you weld the frames and paint them that nice chartreuse color?
Re: More home made junk [Re: P10crew] #5393313 04/04/20 08:36 AM
T
Trav Offline
T
Love it! Nice work.
Re: More home made junk [Re: P10crew] #5393314 04/04/20 08:36 AM
T
tig1 Offline
T
Thanks for posting. Very clever.
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: More home made junk [Re: P10crew] #5393334 04/04/20 09:02 AM
A
atikovi Offline
A
If that's junk, I'll be glad to take it to the dump for you. Now show us your good stuff.
Re: More home made junk [Re: P10crew] #5393341 04/04/20 09:07 AM
P10crew Offline OP
Thanks fellas.
Cujet a few years ago I was very serious about building one of these with a recipe that the original Australian inventors have posted on the net. The coil or coils are wrapped using a plywood form and a low rpm motor. The sourcing of all the material went well till I got to the point of locating the core steel. Since the nearest source was 500 miles from here I gave up the plan and we found an original Australia built unit in great shape locally. The original Australian units were fully rated to 16 gauge and they well bend 16 gauge at full length. Not sure exactly when but an American company bought the rights to this brake and they went down hill from there. If you buy one now days you will be lucky to Bend full length 18 gauge. The inventors are ashamed of how their clever tool has been [censored] over the years. According to the inventors it’s all about saving a little copper and the incorrect core steel. [Linked Image]
Was
Re: More home made junk [Re: atikovi] #5393350 04/04/20 09:21 AM
SLO_Town Offline
Exactly!
Scott
03 BMW E46 330Ci ZSP (Euro Castrol 0W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: More home made junk [Re: P10crew] #5393376 04/04/20 10:01 AM
4WD Online Confused
Online Confused
Amazing ! What does the dial indicator do ?
Re: More home made junk [Re: P10crew] #5393379 04/04/20 10:05 AM
CT8 Offline
P10crew, your Fabricating skill are magnificent ,,, most impressive.
2015 F150 2.7
2018 F350 6.2
Re: More home made junk [Re: P10crew] #5393404 04/04/20 10:37 AM
W
walterjay Offline
W
That is just incredible. I don't think you realize what a skill you have.
Re: More home made junk [Re: P10crew] #5393486 04/04/20 12:07 PM
R
racer44 Offline
R
Very crafty very nice would love to have a set like that!
Re: More home made junk [Re: P10crew] #5393494 04/04/20 12:17 PM
FADEC Offline
Thats far from junk. Very nice workmanship.
Re: More home made junk [Re: P10crew] #5393525 04/04/20 12:45 PM
J
JTK Offline
J
Amazing!!
You've got some serious skills.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
