I have a 1996 Grand Prix that I need to replace brake lines on. I started a thread that covered that topic, but while under the vehicle I notice the steel fuel lines nearby will likely also need replaced. Does anyone know if replacing these is similar? I didn't spend enough time under the car to see what type of connections are under there, but figured you guys might have some experience with this. I'm considering the Mastercool 72485 hydraulic flaring kit because it has dies for GM fuel lines, but is this the correct type of tool for the job, or does this only work on low pressure fuel systems (carburetor)? Any help would be appreciated.
