Forums Migration
Please read this thread
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
24 registered members (dishdude, Dallasmale1970, ArrestMeRedZ, 19elantragt, blufeb95, deoxy4, 2 invisible), 868 guests, and 25 spiders.
Topics307,781
Posts5,317,717
Members71,917
Wrangler TJ Engine Oil #5392886 04/03/20 04:53 PM
T
TJim Offline OP
T
Hey Guys,
I have a Wrangler TJ 2004 2.4L and I would like to ask some questions about engine oil!
1) Should I prefer conventional or synthetic oil?
2) The manual refers that I have to choose a 5w30 engine oil that meets the MS-6395 standards. Should I choose an oil with the MS-6395, or any major brand 5W-30 synthetic oil is ok?
Re: Wrangler TJ Engine Oil [Re: TJim] #5392889 04/03/20 04:57 PM
O
OilReport99 Offline
O
Welcome to BITOG!
welcome
Yes, follow the manual recommendations.
2018 Ram 1500
Re: Wrangler TJ Engine Oil [Re: TJim] #5392913 04/03/20 05:26 PM
Chris142 Offline
I think every oil passes that spec. Do keep in mind that you have a very rare engine with little to no replacement parts available. Run a good oil,filters and watch the temp gauge like a hawk.
Also it is a valve bender. While the valves will not hit the pistons they can hit each other if the timing belt strips or breaks.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Wrangler TJ Engine Oil [Re: TJim] #5392919 04/03/20 05:33 PM
I
incognito_2u Offline
I
Material Standards-6395 is such a non stringent spec, and being that your out of “Warranty” you would be best served with any major producers 5W-30 oil. Synthetic will suit you fine.
With those 2.4 PowerTechs, make sure your diligent in replacing the Timing Belt......just saying!
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EP5W30/XG3600)
1999 Toyota Corolla 1.8 -92k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: Wrangler TJ Engine Oil [Re: Chris142] #5392980 04/03/20 07:08 PM
M
Miller88 Offline
M
I almost bought one in great shape with a bad headgasket. But ended up walking because it's nearly impossible to find that engine as a replacement. But those 2.4s will blow the head gasket if you sneeze wrong.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Wrangler TJ Engine Oil [Re: TJim] #5393035 04/03/20 08:04 PM
Chris142 Offline
The jeep 2.4 is based on the pt loser engine. I think the head is the same. The block is jeep only. If you window the block finding a replacement wont be easy or cheap.
