Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
20 registered members (Char Baby, edyvw, blufeb95, ArrestMeRedZ, carlprop, chemman, 2 invisible), 1,266 guests, and 56 spiders.
Topics306,079
Posts5,286,953
Members71,596
Strut leak #5392956 04/03/20 06:30 PM
F
ford46guy Offline OP
F
One of my lexus rear struts (well coilover type strut) had a film of oil. Just enough for a dirt coating, the other was clean. The leak was down to the spring seat. which is about an inch above the bottom of the strut.. I read that this is a borderline case for replacement, some leakage is acceptable per Toyota. I think 1/3 of the length is ok.
I did replace both though, the old strut isn't crazy broken if you push it in or out.
It does feel a bit tighter in the rear though.
Almost thinking of doing the front too at 100K, but they aren't leaking.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Strut leak [Re: ford46guy] #5393022 04/03/20 07:47 PM
1
14Accent Offline
1
100k is the general rule of thumb on struts. It wouldn't hurt to do the front's, if for no other reason than to keep the ride and handling in balance. Having 100k front struts with 0 mile rear's could do funky things to the drive quality.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Strut leak [Re: ford46guy] #5393032 04/03/20 08:01 PM
E
eljefino Offline
E
Yeah toyota struts leak.
You missed winter, good struts, especially in the rear, really help with stability in the snow.
Re: Strut leak [Re: ford46guy] #5393077 04/03/20 09:03 PM
doitmyself Offline
Originally Posted by ford46guy
It does feel a bit tighter in the rear though. Almost thinking of doing the front too
Goodness, these times have gotten my mind in the gutter. You made me laugh today. Any comic relief helps sooth the stress. Thank you. LOL
Re: Strut leak [Re: ford46guy] #5393181 04/04/20 03:08 AM
O
Olas Offline
O
slight dampness is a sign that the item will need replacing sooner rather than later.
put new topmounts in when the new dampers go in smile
Re: Strut leak [Re: Olas] #5393278 04/04/20 07:47 AM
F
F
The strut top has a long piece of steel, just a metal tube with bolts, nothing really to replace. It also cost $150 a side.
I did replace the rubber "sandwich" that holds the top of shock. One piece was totally crushed.
Re: Strut leak [Re: 14Accent] #5393281 04/04/20 07:52 AM
F
F
I may go for it for $200, I priced the struts and mounts. KYBs.
The OEM is KYB, the brand is on the shock. Both made in Japan. KYB said they are designed a tad bit different from the OEM to account for older suspensions. Both are made with the exact quality control. Some Toyota shocks may be reboxed gas a just.
They said both are great choices.
