Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
26 registered members (Aero540T, ChristianBerg, 19elantragt, Creekside, carlprop, BigGeo, 4 invisible), 743 guests, and 43 spiders.
Topics307,388
Posts5,309,604
Members71,821
Wrangler TJ Engine Oil #5392886 04/03/20 04:53 PM
T
TJim Offline OP
T
Hey Guys,
I have a Wrangler TJ 2004 2.4L and I would like to ask some questions about engine oil!
1) Should I prefer conventional or synthetic oil?
2) The manual refers that I have to choose a 5w30 engine oil that meets the MS-6395 standards. Should I choose an oil with the MS-6395, or any major brand 5W-30 synthetic oil is ok?
Re: Wrangler TJ Engine Oil [Re: TJim] #5392889 04/03/20 04:57 PM
O
OilReport99 Offline
O
Welcome to BITOG!
welcome
Yes, follow the manual recommendations.
2018 Ram 1500 - VME 5W-20
Re: Wrangler TJ Engine Oil [Re: TJim] #5392913 04/03/20 05:26 PM
Chris142 Offline
I think every oil passes that spec. Do keep in mind that you have a very rare engine with little to no replacement parts available. Run a good oil,filters and watch the temp gauge like a hawk.
Also it is a valve bender. While the valves will not hit the pistons they can hit each other if the timing belt strips or breaks.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Wrangler TJ Engine Oil [Re: TJim] #5392919 04/03/20 05:33 PM
I
incognito_2u Offline
I
Material Standards-6395 is such a non stringent spec, and being that your out of “Warranty” you would be best served with any major producers 5W-30 oil. Synthetic will suit you fine.
With those 2.4 PowerTechs, make sure your diligent in replacing the Timing Belt......just saying!
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EP5W30/XG3600)
1999 Toyota Corolla 1.8 -92k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: Wrangler TJ Engine Oil [Re: Chris142] #5392980 04/03/20 07:08 PM
M
Miller88 Offline
M
I almost bought one in great shape with a bad headgasket. But ended up walking because it's nearly impossible to find that engine as a replacement. But those 2.4s will blow the head gasket if you sneeze wrong.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Wrangler TJ Engine Oil [Re: TJim] #5393035 04/03/20 08:04 PM
Chris142 Offline
The jeep 2.4 is based on the pt loser engine. I think the head is the same. The block is jeep only. If you window the block finding a replacement wont be easy or cheap.
