Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Keep OE carb vs replacement
by JHZR2 - 05/31/20 10:00 AM
Gave away some of my stash
by Chris142 - 05/31/20 08:32 AM
Two year check in - Dewalt 20 V String Trimmer
by Snagglefoot - 05/31/20 08:07 AM
Sturmey Archer 3 Speed-Shifting?
by ET16 - 05/31/20 07:45 AM
Power washing your home
by ARB1977 - 05/31/20 07:05 AM
Clint Eastwood car collection.
by PimTac - 05/31/20 04:51 AM
Bulk Oil Setup
by Jason_Michaels - 05/31/20 04:39 AM
First generator
by daves87rs - 05/31/20 01:50 AM
New junk tool
by P10crew - 05/31/20 01:07 AM
tetraethyl lead additive
by painfx - 05/31/20 12:40 AM
Best handheld cordless vacuum?
by montero1 - 05/31/20 12:15 AM
2005ToyotaSolara3MZ-
FE coolant leak
by juca - 05/30/20 11:22 PM
I made a dually today. Carftsman LT1000
by ls1mike - 05/30/20 10:39 PM
New Prestone Products
by Snagglefoot - 05/30/20 09:17 PM
BEST OBD2 scanner for UNDER $100
by flinter - 05/30/20 08:44 PM
Rayi, juca, jrow96, Kotsos, sharpmoney
71582 Registered Users
90 registered members (28oz, 762fermeandyou, 53' Stude, ArrestMeRedZ, 12 invisible), 2,306 guests, and 36 spiders.
Topics306,084
Posts5,286,096
Members71,582
2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil #5392796 04/03/20 03:15 PM
A
apollo18 Offline OP
A
hey guys, i have a 2003 GM 6.0 LQ4 in my truck, its been on synthetic 5w30 its whole life essentially, it used to be always on castrol 5w30 dexos but then ive regularly just been switching between amsoil pennzoil mobil/ whatever full synthetic is on sale. It developed a oil pan or real main leak, its very slight leak, it just drips very slowly. Over the course of 5000km the oil will drop from full to about minimum so its not leaking that much. By the time it gets low on the dipstick its already time for another change. What do you guys recommend i run in it? owners manual says 5w30 all the time, soon we are going to be seeing temperatures between 32 f to about 90 f , and then in the summer between 77f and 95 f. however our winters get cold cold so i probably have to stay as a 5w30 or a 0w30 in winter because we are always ranging between -4 f and -40 f.
i mostly drive city short distances, and then occasional trip on the highway.
I am not planning on getting the leak fixed until it gets much worse because its about $1200 in labor just to take everything out and replace whichever seal is leaking.
i heard high mileage oils are good for this type but do they even come in full synthetic? in canada they seem harder to find.
what do u think i should run?
thx
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5392804 04/03/20 03:27 PM
A
atikovi Offline
A
Why would you fix it at all? So it's now costing you maybe an extra $5 for a quart of oil between changes. If it got twice as bad, you would be spending $10 between 5,000km changes and over an average 20K km a year that's $40. You would have to drive it 30 years just to break even on that repair. Thing will be rusted out long before that.
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5392808 04/03/20 03:32 PM
Z
ZZman Offline
Z
Anything you want.
If it bothers you have you thought of trying a seal additive?
2005 Toyota Avalon XLS 3.5 motor
2014 Ford Fusion 2.5 motor
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5392823 04/03/20 03:44 PM
F
FordCapriDriver Offline
F
Valvoline Maxlife
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5392841 04/03/20 04:03 PM
Chris142 Offline
Smitty's super-S High milage oil stopped the leaks and oil burning on our tahoe.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5392911 04/03/20 05:24 PM
K
ka9mnx Offline
K
A HM oil will not fix a pan gasket leak. It's a 50/50 chance it will slow or stop a seeping rear main seal leak. Mobil1 HM 10w-30 eliminated a rear seal seep on my 1993 F150. Guess I was lucky?
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: atikovi] #5392974 04/03/20 07:03 PM
A
apollo18 Offline OP
A
oh ya i completely agree, i meant i wont change the pan gasket or rear main or whatever it is until its literally oozing out ahaha
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: FordCapriDriver] #5392976 04/03/20 07:06 PM
G
gman2304 Offline
G
Originally Posted by FordCapriDriver
Valvoline Maxlife
I went with the 10w30 flavor of Maxlife on my 5.3. It stopped a rear seal leak for me.
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5392992 04/03/20 07:21 PM
Snagglefoot Offline
For what is worth, last summer I ran 5w40 in my 2008 6.0.I found the oil pressure to be to be slightly higher but not a lot, so no big deal. You could try a 5w30 HM to see if it helps and if you wanted to try a higher viscosity use a 5w40 after that. 2cents
If you want the job done right......do it yourself.
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5393000 04/03/20 07:28 PM
J
Jackson_Slugger Online Content
Online Content
J
I'd try Mobil 1 High Mileage, maybe MaxLife...
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5393004 04/03/20 07:31 PM
9
92saturnsl2 Offline
9
I would run a 10w-30 or 15w-40 HDEO for warmer months, then a 5w-30HM oil in winter if it were my vehicle.
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5393058 04/03/20 08:28 PM
T
tiger862 Offline
T
Valvoline Advance Full Synthetic with Maxlife
Synthetic oil for high mileage and seal protection.
Tiger862
2018 Grand Caravan
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5393890 04/04/20 07:23 PM
T
tblt44 Offline
T
I was trying maxlife 5w 30 to fix my 5.3 rear main seal leak, didnt work
Just went to maxlife 10w 30 still leaks after 2000 miles.
I will keep tring 1 more oul change than will move to a thicker mobil 1 hm.
Mobil 1 5w 30 hm is thicker then valvoline10w 30.
2003 Avalanche Z71 5.3
2006 Tahoe 5.3
1989 Yamaha moto 4 250
2004 Key Largo w/70 Yamaha 2 stroke
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: apollo18] #5393894 04/04/20 07:27 PM
4WD Offline
Oil on driveway or classic GM wet seal seepage?
Re: 2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil [Re: tblt44] #5393898 04/04/20 07:31 PM
T
Triple_Se7en Offline
T
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
