VIRGIN ST 9688 CUT OPEN
In the shop
Good Friday Morning BITOGERS
This filter Triple_Se7en sent me. Looks very good I will say. Enjoy the pictures and stay safe. Gorgeous here and to be 61F today so maybe I'll go for run later
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Last picture is 53' Stude or Adam. Yes, I need a haircut
I've seen it in other videos as well, why the brown/red stain on the side of the filter media?
I cant honestly answer that
I wonder if it's a dab of grease to keep the filter media from getting too dry sitting on the shelf for a long period.
Looks like a Champ e-core in a fram can.
I don't like the larger center tube that takes up too much volume that could be better used for more media.
Tiny thing is only big enough for a "fuel filter" in my estimation.
thanks for the c&p Stude !
You are welcome arco
That's a clean little machine, Adam … did you try to tear the media to see how weak it is ? I'm starting to think when you see that extra corrugated look (like a cardboard) box … they do that to stiffen up weak paper media. Not seen on thicker blended filters.
(Purolator/MC does this some).
I wonder if that cheap paper can handle a longer pleat = or to your point seems they would.
I can. Stay tuned as I'll try to tear some media
This is a rather wide filter overall, look at how nice and tight those pleats are for a $3 filter. Plenty of media on this filter for the 10K stated mileage.
I would run this for a normal factory OCI and sleep like a baby.
Sure you didnt shoot t with a 45acp JHP?
Aw ! Adam, you Should have excised it with an exacto and measured the filter area - since I'm having filter area arguments on here with ST E cores.
I guess you still could - if you ignore the hole.
-Ken
Yeah … better filters use strong synthetic fiber within the cellulose …
All the unused Purolator filters I cut open tore like Xerox paper … other makes are very tough …
(not thinking of XP, XG, RP… the wire is there to support flexible fiber, different animals)
Thanks Adam …
Thanks Adam …
You are welcome sir
Originally Posted by wemay
Looks good Adam! Thanks
That hair is nothing a brush couldn't put into place.
It gets wavy and curly when it's been December when mom cut it for me. Pops (real dad) hair is same. I'm bout to buzz cut it way the U.S. NAVY does
