Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
103 registered members (ABN_CBT_ENGR, 53' Stude, 2015_PSD, 762fermeandyou, 1978elcamino, 2004tdigls, 11 invisible), 2,680 guests, and 60 spiders.
Topics305,904
Posts5,282,485
Members71,535
Are all JWS3309 ATF’s the same? #5391521 04/02/20 05:03 AM
dlundblad Offline OP
The wife’s Volvo with the AW-55 is about due for a transmission drain and fill.
Would say a Volvo, Idemitsu or Aisin fluid carrying this approval be identical to Mobil 3309?
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Are all JWS3309 ATF’s the same? [Re: dlundblad] #5391529 04/02/20 05:20 AM
T
Trav Offline
T
Yes as well as Toyota T IV. I have been using AISIN ATF0T4 in the AW-55/AW-57for a long time without any problems, it is spec fluid.
Rock Auto has the best price so far $4.87 qt.
https://www.rockauto.com/en/moreinfo.php?pk=7668688&cc=1433175&jsn=363
Re: Are all JWS3309 ATF’s the same? [Re: dlundblad] #5391552 04/02/20 06:32 AM
Astro14 Online Content
Online Content
You need a JWS-3309, or Toyota T-IV spec fluid. (I know you're already aware.) Are they all the same? Don't know, haven't tried every brand...
What I can say, is that I’ve used Toyota T-IV, MOBIL 3309, AMSOIL Signature Series, and Valvoline Import multi-vehicle with success in my P2 Volvos (AW-55).
I’ve never used the Volvo fluid - at nearly $30/quart, for a mineral oil, it’s outrageously priced. The Toyota T-IV is identical.
Picking up a case of T-IV at the Toyota dealer is both convenient and a decent deal. That's my recommendation.
If you ever start to have the shift problems for which the '01-'02 AW-55 is known, PM me - I've done valve body surgery on all three of mine. Most recently, I swapped a brand new GM Valve Body*, bought on Amazon for $495, into the '01 V70. A slight modification to the wiring harness was needed, and I had to swap the S4 solenoid from the old VB. A reasonably cheap fix for an AW-55 with shifting issues.
*Some GM cars and some NIssans also used the AW-55, though GM called it the AF-33. So, GM still has valve bodies for sale. The key point of failure on the early valve bodies was the bore for the SLT solenoid, which controls line pressure. Bore wears, allowing fluid to leak resulting in low line pressure. With low line pressure, the transmission starts acting up. Various kits exist to fix this problem, and many companies rebuild that particular body with a sleeve kit in the SLT bore. The GM body is new manufacture, and doesn't have the problem. At $495, it's cheaper than rebuilding the old body. A quick programming and drive adaptation is needed for the install.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Are all JWS3309 ATF’s the same? [Re: Astro14] #5391709 04/02/20 09:48 AM
Thanks Astro. Hope all is well with you and the current events.
I may do your filter addition too. You did a spin on and magnafine both, correct?
Mobil 3309 and Yoda is just best bet. Just keeping an eye on prices and since I can’t drive to the dealer... I need to buy some things for the A4 so I was just planning on adding stuff onto an order from FCP.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Are all JWS3309 ATF’s the same? [Re: Trav] #5391710 04/02/20 09:49 AM
Thanks for the link.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Are all JWS3309 ATF’s the same? [Re: Trav] #5391719 04/02/20 10:00 AM
K
kschachn Offline
K
"Spec" in that Aisin specifies it for this use, but it is not Toyota T-IV licensed (and like other Asian manufacturers they typically do not license any of their fluids).
In Aisin's own language:
Quote
ATF-0T4 specifically engineered for Toyota, Lexus, Scion and many other domestic and import vehicles.
As always, not saying it is deficient however.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Are all JWS3309 ATF’s the same? [Re: kschachn] #5391729 04/02/20 10:16 AM
T
Trav Offline
T
It may not be Toyota approved but they AW did manufacture the box so one would assume they know what fluid will work properly in it and have it made for them to that spec.
Re: Are all JWS3309 ATF’s the same? [Re: dlundblad] #5391748 04/02/20 10:45 AM
U
UG_Passat Offline
U
No issues with Pentosin ATF-1.
The new shop I use, they use Liqui Moly top tec 1200
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Are all JWS3309 ATF’s the same? [Re: dlundblad] #5391807 04/02/20 11:51 AM
Yah-Tah-Hey Offline
JWS3309 is the spec. Just like DOT 3 or R-134A. There probably is some variation from brand to brand but not enough to be of concern. Regards
Re: Are all JWS3309 ATF’s the same? [Re: dlundblad] #5391868 04/02/20 01:09 PM
U
UG_Passat Offline
U
JWS is a Exxon-Mobil standard though, not a Toyota or Aisin-specific standard
Re: Are all JWS3309 ATF’s the same? [Re: UG_Passat] #5392308 04/03/20 04:11 AM
Are you saying Toyota Type IV is the incorrect fluid?
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Are all JWS3309 ATF’s the same? [Re: dlundblad] #5392362 04/03/20 07:10 AM
Online Content
Thanks for the kind words. We are fine, at the moment. Terribly uncertain future...
Back to cars - I did only the spin-on filter with my Volvos and their cooler/thermostat set-up. A magnefine wouldn't hurt, but I didn't do it. Just did a drain and fill on my wife's XC* last week. At 256,000 miles, the fluid came out clear and red. So far, so good.
Since you can't drive to the dealer, I would use whatever you can get from FCP. Looking at their site, I'm frankly shocked that they can offer the Volvo fluid for $15/liter, when the dealer wants twice that. Still, it's crazy for what you get. The Aisin and the Idemitsu look good to me. I would be fine using the Aisin in my Volvo, after all, they built the transmission. I've gotta' believe they make a fluid that's in spec...
*Original transmission, got the valve body rebuilt at about 110,000.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Are all JWS3309 ATF’s the same? [Re: dlundblad] #5392518 04/03/20 09:48 AM
Isn’t the tranny cooler line steel lined and hard to cut?
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
