Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
105 registered members (apollo18, 2015_PSD, ArrestMeRedZ, agarb, 4WD, 2010Civic, 11 invisible), 2,272 guests, and 30 spiders.
Topics305,921
Posts5,282,802
Members71,537
Oil change #5390944 04/01/20 12:52 PM
I
IvanPletex Offline OP
I
Hi,
What is the best oil change interval for small diesel engines. (1300ccm) (Capacity 3.2L). Engine oil is always 100% synthetic 5w40. Car travells about 15k kilometers per year. Mostly city driving.
Re: Oil change [Re: IvanPletex] #5390949 04/01/20 01:00 PM
gathermewool Offline
If the majority of your travel is AT temperature (e.g., constantly moving, highway, etc.) then I'd go yearly.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Oil change [Re: IvanPletex] #5390950 04/01/20 01:02 PM
O
Olas Offline
O
It depends on the car and it’s tech. as much as anything, but;
If your city driving is mostly short journeys then the oil might not get up to full temp so a shorter interval of 10k KM could be beneficial. If you drive for long enough to get the oil properly hot then 20k KM is reasonable.
Re: Oil change [Re: IvanPletex] #5390951 04/01/20 01:05 PM
A
Audios Offline
A
You may want to have it tested to be sure its holding up for that interval, its probably fine though.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Oil change [Re: IvanPletex] #5391005 04/01/20 02:22 PM
G
Gebo Offline
G
Since it's city with small oil capacity, I'd change it every 5k Kilometers and never have to worry.
Or you could go a little longer and change every 6 months. Easier to keep up with.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Oil change [Re: IvanPletex] #5391017 04/01/20 02:52 PM
sloinker Offline
Originally Posted by IvanPletex
Hi,
Which 100% synthetic oil are you using?
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Oil change [Re: IvanPletex] #5391027 04/01/20 03:16 PM
CT8 Online Content
Online Content
What does the manufacture recommend?
2015 F150 2.7
2018 F350 6.2
Re: Oil change [Re: sloinker] #5391548 04/02/20 06:26 AM
I
I
So far I have been using Selenia WR 5W40.
On the next oil change I am gonna switch on Shell helix ultra 5w40( since it is GTL based).
Re: Oil change [Re: CT8] #5391549 04/02/20 06:28 AM
I
I
Manufacture says change your oil every 30k kilometers. Nonsense. Iam chaning it every 8k-10k max.
Re: Oil change [Re: IvanPletex] #5391663 04/02/20 09:01 AM
sloinker Offline
If you are changing it every 8-10k kilometers you can use whatever is cheapest that meets the manufacturers specification. The "100% synthetic oil' you have been using is a good oil and could coceivably deliver much longer change intervals but you will need to monitor/test it.
Selenia WR 5W40:
40.0-50.0 % Distillates (petroleum),
hydrotreated heavy
paraffinic (649-467-00-8)
CAS:64742-54-7
EC:265-157-1
Asp. Tox. 1, H304,
DECLL(*)
01-2119484627-25-
XXXX
1.0-2.0 % Zinc
bis[O-(6-methylheptyl)]
bis[O-(sec-butyl)]
bis(dithiophosphate)
CAS:93819-94-4
EC:298-577-9
Skin Irrit. 2, H315; Eye
Dam. 1, H318; Aquatic
Chronic 2, H411
01-2119543726-
33XXXX
1.0-2.0 % C14-16-18 Alkyl phenol Skin Sens. 1, H317; STOT
RE 2, H373; Aquatic
Chronic 4, H413
01-2119498288-19-
XXXX
1.0-2.0 % Reaction products of
Benzeneamine, N-phenylwith nonene (branched)
CAS:36878-20-3
EC:253-249-4
Aquatic Chronic 4, H413 01-2119488911-28-
XXXX
30.0-40.0 % Not classified oils
Re: Oil change [Re: IvanPletex] #5392406 04/03/20 07:51 AM
T
Tikka Offline
T
Hi
For city driving I would change it every 6 months. I suppose only an analysis will help but oil is relatively cheap. 3.2 litre you say? Is it a Ford Ranger?
Is a C3 oil a better choice for a modern turbo diesel engine like this? Something like a MB229.51?
Tikka.
Re: Oil change [Re: Tikka] #5392428 04/03/20 08:12 AM
I
I
It is Fiat Grande Punto 1.3 MJD, year 2007. I deleted DPF, iam using full SAPS oils for, never had problems with it 182k kilometers. For the next oil change I bought Shell helix ultra diesel 5w40 A3/B4 , API CF.
