Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Jcvjr, Haywood, ToOliwer, AbbeyRoad, RPF
71587 Registered Users
13 registered members (dervdave, DaHen, KneeGrinder, FordCapriDriver, BrianF, 3 invisible), 1,021 guests, and 47 spiders.
Topics306,109
Posts5,286,665
Members71,587
2017 Corvette / 14.4k / ACDelco MTF #5391286 04/01/20 08:10 PM
dparm Offline OP
This is the third manual transmission change the car has seen. Mileage worked out to nearly double (14.4k vs 7.6k) and track time was about 50% longer (22 hours vs 15 hours). The car has a dedicated transmission cooler.
Blackstone said things still look fine. Wear metals are dropping on a per-mile basis but the viscosity was again a bit thin, though didn't seem to cause any issues.
I'm now using Red Line D4 ATF instead of the OEM fluid.
Code
OIL             ACDelco    ACDelco    ACDelco
MILES IN USE    14,465     7,623      6,392
MILES           28,480     14,015     6,392
SAMPLE TAKEN    3/24/20    10/20/18   9/22/17
ALUMINUM        8          8          11
CHROMIUM        0          0          1
IRON            63         52         82
COPPER          7          12         22
LEAD            1          1          1
TIN             0          0          1
MOLYBDENUM      0          1          2
NICKEL          0          1          2
MANGANESE       7          13         35
SILVER          0          0          0
TITANIUM        1          2          3
POTASSIUM       1          1          3
BORON           109        96         46
SILICON         10         9          16
SODIUM          3          4          9
CALCIUM         30         21         0
MAGNESIUM       1          0          1
PHOSPHORUS      270        234        160
ZINC            7          7          11
BARIUM          0          1          3
INSOLUBLES      0.1        0.1        0.2
WATER           0          0          0
FLASHPOINT �F  400        390        385
SUS VIS 210�F  41.4       42.3       43.4
cSt @ 212�F    4.59       4.89       5.23
TBN
TAN             1.8        1.3        1.3
2017 Chevrolet Corvette Grand Sport
Re: 2017 Corvette / 14.4k / ACDelco MTF [Re: dparm] #5391738 04/02/20 10:29 AM
CT8 Offline
The Redline comparison will be interesting.
2015 F150 2.7
2018 F350 6.2
Re: 2017 Corvette / 14.4k / ACDelco MTF [Re: dparm] #5391747 04/02/20 10:44 AM
R
RoadDukie Offline
R
How does your shifting feel with the Redline?
1998 Mercedes S500
2003 Corvette Roadster
2007 Chevrolet Avalanche
2009 Kawasaki Concours 14-ABS/2012 Kawasaki KLX250S
2002 Polaris Sportsman 500HO
Re: 2017 Corvette / 14.4k / ACDelco MTF [Re: RoadDukie] #5391958 04/02/20 03:24 PM
dparm Offline OP
Not much different from the OEM stuff. Car already has an MGW short shifter so the shift feel was already decent.
Re: 2017 Corvette / 14.4k / ACDelco MTF [Re: dparm] #5393419 04/04/20 10:51 AM
R
RoadDukie Offline
R
Thanks dparm.
I noticed in your videos how short and crisp your shifter was. Very impressive.
I finally replaced the gearbox oil last year in my C-5 using Castrol merc-dex as it had been reported as a good substitute for Dex-3. The old oil was factory fill with about 12-13k miles. I was TOTALLY blown away in the improvement in shift quality. I had reserved myself to the fact that the stock shifter just wasn't very good.
Now with the fluid change, I absolutely love driving the car again. I guess it deteriorated so slowly I didn't notice. Mind you my car hasn't seen any track-day or similar, just spirited fun in the Rockies. It still surprised me how much the shift quality had degraded in only 13k miles.
This fluid change is now on my radar and I've been keenly watching your posts on the subject.
Thank you.
Duke.
1998 Mercedes S500
Re: 2017 Corvette / 14.4k / ACDelco MTF [Re: RoadDukie] #5395018 04/05/20 10:44 PM
dparm Offline OP
Thanks dparm.
It's an MGW shifter. One of the only mods the car has and well worth the $400. The factory shifter is trash -- mushy, poorly defined gates, no feedback. The MGW is a big improvement but the 2-3 shift is still iffy at times.
Re: 2017 Corvette / 14.4k / ACDelco MTF [Re: dparm] #5397164 04/08/20 09:14 AM
E
Emperors6 Offline
E
Thanks for posting this. I'll keep an eye on your UOAs to compare to mine since I also have a C7 smile
2013 Cadillac CTS-V
2016 Chevrolet Corvette Z06
Re: 2017 Corvette / 14.4k / ACDelco MTF [Re: dparm] #5409513 04/21/20 01:33 PM
R
RoadDukie Offline
R
Thanks dparm.
Hello again dparm.
You definitely piqued my interest with the MGW shifter. At first I was hesitant to make this change to my 50th Anniversary edition as I want to keep it 100% stock. However, two things changed my mind:
1) As you said: "The factory shifter is trash". Totally agree and believe this update would do nothing but improve the car.
2) I thought it would be obvious that the shifter isn't stock. After looking at it some more, I see that the shifter boot completely covers the shifter shaft. I can also reuse the stock shift knob for appearance.
SO.... Here's my question to you: During research of this shifter, I came across a modification called the "Anti-Venom Mod". This appears to be merely shimming the detent ball in the transmission so that it enables easier shifts. Less detent.
Have you any experience and or comments about this modification?
TIA.
Duke
1998 Mercedes S500
Re: 2017 Corvette / 14.4k / ACDelco MTF [Re: RoadDukie] #5409530 04/21/20 01:52 PM
dparm Offline OP
Thanks dparm.
Hello again dparm.
TIA.
Duke
Interesting, I had never even heard of this. Opinions seem mixed on CorvetteForum based on skimming a few threads. I guess it's worth trying if you have the time and know-how, seeing as how it's removable/reversible. Ultimately you are still fighting physics to a certain degree -- the car is a transaxle so you have a linkage going all the way back to the rear axle.
