Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
77 registered members (aquariuscsm, 2011335d, ABN_CBT_ENGR, 830Lee, bdcardinal, Alfred_B, 6 invisible), 2,140 guests, and 67 spiders.
Topics306,090
Posts5,287,253
Members71,596
2017 Corvette / 14.4k / ACDelco 75w90 gear oil #5391272 04/01/20 07:59 PM
dparm Offline OP
This is the third rear differential fluid change the car has seen. Mileage worked out to a tad longer (14.4k vs 11k) but overall track time was similar (22 hours vs 24 hours). The car has a dedicated differential cooler.
Blackstone highlighted that iron came down even further despite the longer run and everything else is steady. They attributed the aluminum to something "benign" like oxides. Confusing to see it continue to rise, but I don't consider it a wear metal for a differential. Open to ideas.
I'm now using Red Line 75w90 GL-5 gear oil instead of the OEM GM fluid.
Code
OIL             ACDelco    ACDelco    ACDelco
MILES IN USE    14,465     11,057     2,958
MILES           28,480     14,015     2,958
SAMPLE TAKEN    3/24/20    10/20/18   7/3/17
ALUMINUM        174        111        40
CHROMIUM        1          1          1
IRON            123        138        107
COPPER          5          4          3
LEAD            1          1          1
TIN             0          0          0
MOLYBDENUM      1          1          1
NICKEL          4          3          2
MANGANESE       4          6          7
SILVER          0          0          0
TITANIUM        0          0          0
POTASSIUM       1          2          5
BORON           67         62         56
SILICON         6          7          7
SODIUM          7          7          9
CALCIUM         14         16         11
MAGNESIUM       8          4          4
PHOSPHORUS      2291       2103       2299
ZINC            18         16         20
BARIUM          0          1          3
INSOLUBLES      0.3        0.3        0.2
WATER           0          0          0
FLASHPOINT �F  390        380        380
SUS VIS 210�F  69.4       71.1       73.7
cSt @ 212�F    12.80      13.23      13.93
TBN             3.1
TAN             6.4        9.2
2017 Chevrolet Corvette Grand Sport
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5391610 04/02/20 07:51 AM
B
benjy Offline
B
redline lubes are as good as it gets + besides protecting more they last longer. only downside of excesive changes is $$$
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5391751 04/02/20 10:46 AM
R
RhondaHonda Offline
R
Any idea how much is left behind in the diff cooler when you change it? I’m looking to change my 2017 Grand Sport soon if anything because I’m bored.
2019 Ford Raptor
2017 Corvette Grand Sport
2017 Yukon XL Denali
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: RhondaHonda] #5391966 04/02/20 03:35 PM
dparm Offline OP
Not sure, but when my shop changed it out, I gave them the gallon jug and they said they used "most of it". I can't remember if this is the process for the diff, MT, or both, but it involves putting fluid in and then putting the car in gear and running it at low speed for like 10 minutes -- then topping it off.
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5391974 04/02/20 03:48 PM
R
RhondaHonda Offline
R
Thanks. I’ll read up on the procedure before attempting.
2019 Ford Raptor
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5397163 04/08/20 09:14 AM
E
Emperors6 Offline
E
Thanks for posting this. I'll keep an eye on your UOAs to compare to mine since I also have a C7 smile
2013 Cadillac CTS-V
2016 Chevrolet Corvette Z06
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5402126 04/13/20 02:47 PM
J
jtwrace Offline
J
Aluminum could be your cooler coming apart internally.
"Science is not a democracy"-Earl Geddes Ph.D.
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5407824 04/19/20 01:40 PM
E
Emperors6 Offline
E
I also have aluminum in my diff oil changes for my C7. It's reassuring you're also getting it, since it might be normal wear.
2013 Cadillac CTS-V
