Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Jcvjr, Haywood, ToOliwer, AbbeyRoad, RPF
71587 Registered Users
22 registered members (Donald1953, farrarfan1, ctechbob, emod, ArrestMeRedZ, dixon66, 2 invisible), 1,126 guests, and 29 spiders.
Topics306,109
Posts5,286,665
Members71,587
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi #5391257 04/01/20 07:41 PM
d00df00d Offline OP
Previous UOA here. Now at 105176 miles on the engine.
In the 20k miles prior to this OCI, I caught and fixed at least 3 possible causes of fuel dilution: failed coolant thermostat, a precat exhaust leak, and a precat O2 sensor failure. Each time I hoped the fuel dilution would come down. Maybe it finally happened, if only slightly.
Nothing else of note in this OCI.
Copying the numbers here because I don't like how Polaris's reports are formatted:
Wear Metals
Iron - 6
Chromium - 0
Nickel - 0
Aluminum - 3
Copper - 2
Lead - 0
Tin - 0
Cadmium - 0
Silver - 0
Vanadium - 0
Particle Quantifier (PQ) Index - 13
Contaminant Metals
Silicon - 7
Sodium - 10
Potassium - 0
Multi-Source Metals
Titanium - 0
Molybdenum - 44
Antimony - 0
Manganese - 0
Lithium - 0
Boron - 49
Additive Metals
Magnesium - 21
Calcium - 2249
Barium - 0
Phosphorus - 716
Zinc - 828
Other Contaminants
Fuel Dilution - 1.5% (GC)
Soot - <0.1% by vol.
Water - <0.1% by vol. (FTIR)
Fluid Properties
Viscosity @ 100º C - 17.6 cSt
TBN - 4.31
Oxidation - 11
Nitration - 10
[Linked Image]
2008 BMW M3 Sedan 6MT
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi [Re: d00df00d] #5391290 04/01/20 08:13 PM
dparm Offline
Looks good. I wouldn't sweat it with the fuel dilution if you're driving the car the way it was meant to be.
Curious why you added 2L between changes versus 1L on the previous ones. The digital dipstick was always a bit awkward on that car...
BTW, has it had bearings changed out?
2017 Chevrolet Corvette Grand Sport
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi [Re: dparm] #5391294 04/01/20 08:18 PM
d00df00d Offline OP
Polaris only lets you enter integers for amount added. The real amount was more like 1.5L, and that was at least partly because I hadn't achieved a full fill from the get-go.
I know I'm losing some oil through a weep at the oil fill cap that I never bothered to completely fix. I did a quick thing to reduce it a while back; maybe it has gotten slightly worse since then.
(Rod bearings, right?)
Yes. Had that done around 82k miles. BMW bearings and bolts, so it now has the newer lead-free bearings.
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi [Re: d00df00d] #5391300 04/01/20 08:26 PM
dparm Offline
There was a revised oil cap IIRC, but they all sorta weep. Hope you're still hooning it on a daily basis!
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi [Re: dparm] #5391306 04/01/20 08:30 PM
d00df00d Offline OP
cheers
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi [Re: d00df00d] #5391576 04/02/20 07:02 AM
B
BMWTurboDzl Offline
B
Low tension rings my friend. Fuel dilution is always going to be there.
435i
