Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
bbrtuning, chapys, DaaBoss, C6H8O7, Jcvjr
71591 Registered Users
79 registered members (14Accent, 4WD, 2015_PSD, 28oz, 53' Stude, 10WSmuckers, 8 invisible), 2,535 guests, and 28 spiders.
Topics306,031
Posts5,286,096
Members71,591
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles #5391256 04/01/20 07:40 PM
dparm Offline OP
This is the third full interval with the M1 ESP Formula 0w40. I pushed it past my usual 20% OLM reading and let it go down to around 3% which was around 2k extra miles. But this also worked out to a lot of track time: about 15 hours! Several of those track days had ambient temps in the mid-90s but overall oil temps and pressures stayed steady. Never got oil temps above 265 F.
Blackstone said that overall it looked good, but again noted the viscosity was a bit low. I've since switched to Motul 300V 0w40 which I hope holds its viscosity a little better.
I'm still really impressed with how this thing continues to hum along without any major issues despite the hard driving. I just had it dynoed last month and it laid down 400whp, meaning it's still producing the claimed 460 crank hp (if you assume 15% drivetrain loss).
Code
OIL             M1 ESP 0w40  M1 ESP 0w40  M1 ESP 0w40  M1 5w30  M1 5w30  M1 5w30
MILES IN USE    7,095        5,230        5,915        3,848    5,651    741
MILES           28,480       21,385       16,155       10,240   6,392    741
SAMPLE TAKEN    3/24/20      9/13/19      2/26/19      6/22/18  9/22/17  4/12/17
ALUMINUM        5            5            6            6        10       3
CHROMIUM        1            1            1            1        2        1
IRON            21           18           35           34       53       48
COPPER          2            3            3            5        13       28
LEAD            0            2            1            1        1        1
TIN             0            0            0            0        0        0
MOLYBDENUM      70           66           69           80       76       84
NICKEL          0            0            0            0        0        0
MANGANESE       0            0            0            1        2        2
SILVER          0            0            0            0        0        0
TITANIUM        0            0            0            0        0        0
POTASSIUM       1            2            1            2        5        10
BORON           178          175          156          66       54       106
SILICON         7            7            10           12       40       74
SODIUM          4            4            7            4        5        7
CALCIUM         1515         1441         1539         1103     956      1043
MAGNESIUM       16           30           119          779      682      624
PHOSPHORUS      744          719          769          735      627      692
ZINC            830          798          801          819      733      753
BARIUM          0            0            0            0        0        0
INSOLUBLES      0.2          0.1          0.1          0.1      0.1      -
WATER           0            0            0            0        0        0
FLASHPOINT �F  395          410          390          395      390      SHORT
SUS VIS 210�F  61.5         64.4         62.5         56.8     54.8     -
cSt @ 212�F    10.65        11.44        10.92        9.29     8.71     SHORT
TBN             2.6          3.6          2.8          4.4      4.6      6.2
TAN             4.6          4.6          3.7          2.8      4.7      1.9
2017 Chevrolet Corvette Grand Sport
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: dparm] #5391382 04/01/20 09:51 PM
T
tcp71 Offline
T
Isn’t it supposed to be bad if the TAN number exceeds the TBN number?
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: tcp71] #5391401 04/01/20 10:19 PM
dparm Offline OP
The answer is: it depends. Some oils will have a high starting TAN, so without knowing the virgin (brand new out of the bottle) TBN and TAN, you can't definitively say that oil must be changed when TAN > TBN. That being said, I don't think the oil I used has a naturally high TAN.
Some deeper discussion on the subject:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/1970704/TBN/TAN_CrossOver_in_UOA--_Wha
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: dparm] #5391691 04/02/20 09:36 AM
B
buster Offline
B
Looks really good, especially with 15 hours of track time. Wear control is excellent.
Regarding viscosity, Mobil has to be aware that their 0w40 drops into 30 grade territory. It always has. The HT/HS of this oil is around 3.6. In order to prevent this, one could go with Redline 0w40 which has a HT/HS of 4.2, but it's not good for LSPI issues.
Mobil did 2 years worth of testing with this oil for this car. I would absolutely stay with it.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: dparm] #5404086 04/15/20 03:38 PM
A
A_Harman Offline
A
Fuel dilution? I see your UOA lab doesn't provide a fuel dilution measurement. I doubt that the oil is shearing in a GM LS-type engine.
In hot trackday conditions, I wouldn't be surprised if the ECM calibration is injecting a lot of extra fuel to save the cats.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: A_Harman] #5406974 04/18/20 12:44 PM
dparm Offline OP
Forgot to include it, but yes, Blackstone provides fuel numbers. It's been <0.5% every time.
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: dparm] #5410850 04/23/20 03:04 AM
spinkick Offline
Thanks for this! Was considering amsoil signature series or the new factory fill. I also have a 17 Grand sport. My LT1 has a supercharger added, so I am particularly interested in protecting the motor as it doesn't come stock with boost smile
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: dparm] #5411839 04/24/20 08:28 AM
B
buster Offline
B
dparm, just thinking out loud here....Driven 0w40 DI would be a great choice for this engine. This oil is mPAO/POE and has a SA of .72 and has top notch, very shear stable VII's. If I ever deviated from the M1 0w40 ESP, this would be my choice.
https://www.drivenracingoil.com/di40-0w-40-synthetic-direct-injection-performance-motor-oil-1.html
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: dparm] #5415250 04/28/20 03:32 AM
G
Gasbuggy Offline
G
Very impressive UOA. Also glad to see the new 0w40 performing well in the GM engines.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: buster] #5415294 04/28/20 06:00 AM
spinkick Offline
Never have seen driven oil before. Is it new?
I've never seen this brand. Is it new?
Re: 2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles [Re: dparm] #5421462 05/05/20 09:11 AM
P
Patman Offline
Global Moderator
Global Moderator
P
The wear numbers are good but something always bothers me about an oil that loses that much viscosity, I figure that in the long run that means the engine might not be as clean inside, as the thinning is the breaking down of the VII. I'm very glad I'm sticking with the 5w30 version of ESP Formula, it stuck at it's starting viscosity of 12.1 for my entire 7200 mile interval on my last UOA.
2018 Corvette, 21k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 156k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,130k, GC 0w40 & Fram Ultra
