P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
65 registered members (ArrestMeRedZ, aquariuscsm, AurionX2, 4WD, AutoCoil, 94astro, 3 invisible), 1,556 guests, and 79 spiders.
Topics306,051
Posts5,286,416
Members71,593
What would kill batteries in < 20 mo for daily driver in temperate climate? #5391153 04/01/20 06:07 PM
O
Oneill5491 Offline OP
O
Wondering what issues anyone may know of that can make car batteries prematurely fail when it's daily driven and not exposed to climates with excessive heat?
Have a CX-5 using Group Size 35 batteries. Last two batteries I've had to replace at about 19 months. It's daily driven in a temperate (Oregon) climate. No aftermarket accessories like crazy car stereo or anything.
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391156 04/01/20 06:09 PM
Chris142 Offline
Short trips that are not long enough to fully recharge the battery.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391165 04/01/20 06:19 PM
T
Trav Offline
T
Check the voltage from the alternator.
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391175 04/01/20 06:29 PM
O
ondarvr Offline
O
Some vehicle brands and models have had problems with the computer not going to sleep properly when the car is shut off, this drains the battery.
Also some use two stage charging to increase mileage, the charging system goes into a lower voltage mode when there's little load and the battery is close to being charged. This leaves the battery perpetually under charged.
Both of these can reduce battery life significantly.
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391183 04/01/20 06:42 PM
W
wrcsixeight Offline
W
Excessive parasitic draw while the car is sitting, coupled with short drives where there is never adequate time to return the battery to near full.
I have data from my own vehicle in terms of how long it takes the charging system to return that which was used to start the overnight cold engine.
It is about 45 seconds when the voltage regulator is seeking and holding 14.7 volts.
This is determined by amperage. I was holding the battery at 14.7v and noticing how many amps were required to maintain that voltage before starting the engine.
After starting the engine, once amps taper to that same level at 14.7v, the battery is as at the same state of charge as before starting the engine.
It took ~45 seconds at 14.7v on my vehicle for this to occur. This is with a precise 500 amp 50MV deltec shunt measuring amperage into and out of the battery.
So unless one drives for less than ~45 seconds, short trip driving is by itself not the cause of premature battery failure, but short trip driving has no chance of returning a less than fully charged battery to full charge, and with ideal charging voltages, which NEVER occur in 99.99% of vehicles on the road, a lead acid battery cannot get from 80% to 100% charged in less than 3.5 hours.
I know that many will say it takes 5 or more minutes to return that which the starter used to start the engine. I can;t see this happening on a modern fuel injected gas engine, but likely was true with carbs and longer engine cranking times and perhaps multiple starting attempts being required.
Likely it took longer than 5 minutes in such circumstances.
Since fuel injection and quick starting vehicles became the norm, batteries have become lighter and lighter in the same size group, with thinner and more fragile plates more susceptible to shedding material. This makes them more susceptible to degradation when cycled, even if only to 80%, and more susceptible to heat and vibration.
Vehicles today have much higher parasitic draws, which make it harder to get the battery fully charged especially when they sit unused often, and many vehicles are intentionally keeping the battery at lower states of charge in order to squeeze out some executive bonus money when CAFE standards are met.
Marine batteries are more durable than dedicated starting batteries when cycled deeper, but come nowhere close to actual deep cycle batteries in this regard. A group 27 starting battery in 1970 would likely be 15% heavier than a group 27 starting sold today, perhaps even heavier than a marine group 27 which can be as high as 62 Lbs for a marine and as light as 48lbs for starting.
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391185 04/01/20 06:43 PM
2
2009Edge Offline
2
Designed Obsolescent crush
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391202 04/01/20 06:58 PM
I
Imp4 Online Content
Online Content
I
Either but the Walmart Everstart Max with the 5-year warranty or the Costco Interstate with 42+ month warranty.
Get something for batteries dying incredibly early...
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391204 04/01/20 07:02 PM
B
bullwinkle Online Confused
Online Confused
B
What battery manufacturer? If it's Exide, maybe they're just not good enough? A daily driver, especially if you're going at least 5 miles, shouldn't be killing them unless there's really bad battery connections or a charging system problem.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391222 04/01/20 07:13 PM
E
ecotourist Offline
E
My BMW was killing batteries. My BMW specialty shop found the problem. The AC fan was coming on at random times when the ignition was off. The battery could be run down to a no start in as little as a couple of hours. Apparently a common problem with BMWs.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Trav] #5391251 04/01/20 07:37 PM
spasm3 Offline
This. I had a Saturn auto that would shift into 4th at every stop. Turns out the alternator was putting out 17 to 24v!!
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391296 04/01/20 08:19 PM
A
andyd Offline
A
The 1/2amp floater I bought at HF for 4.99 works great for maintaining the Rats battery. I was gonna put it on the Fridge's 01/20 Maxx 24f, But a 3hr run to midstate on the 'Pike Tues, should have fixed. But for grins, I should check it grin2
Thick oil is better grin2
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391316 04/01/20 08:41 PM
E
Eddie Offline
E
I would first get the alternator output checked at auto parts store. I the alt out put is good, then check for the amount of current draw after the engine is off. I don't have a value for the parasite draw but, it should be low-Someone will more knowledge will give a value. If the alternator out put is good and the parasitic draw is reasonable then it's the battery either bad or undercharged due to lack of driving. Ed
2014 CX5 Touring 2.5L :-)
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: ondarvr] #5391373 04/01/20 09:44 PM
B
bbhero Offline
B
This ^^^^^^^^^^
And like Trav said check the alternator..
And check for too big of a parasitic draw.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Oneill5491] #5391436 04/01/20 11:36 PM
Y
Y_K Offline
Y
When you buy a new battery, charge it always. No matter what they tell you at the store. All new ones I bought in past needed this.
“This disease making us more cruel to one another than if we are doggs.” -- Samuel Pepys 1666
Re: What would kill batteries in < 20 mo for daily driver in temperate climate? [Re: Imp4] #5391482 04/02/20 01:42 AM
Carmudgeon Offline
Costco dropped their 42-month replacement warranty to 36-months a little while back. Even their new AGMs have the same term.
I contemplate this as my 46.5 month old Costco battery has revealed itself as unable to hold a charge during these times of home detention and extended idle times.
