Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck batter with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
chapys, DaaBoss, C6H8O7, Jcvjr, Haywood
71590 Registered Users
105 registered members (53' Stude, 830Lee, andyd, 2015_PSD, aquariuscsm, Alfred_B, 8 invisible), 2,543 guests, and 20 spiders.
Topics306,131
Posts5,287,016
Members71,590
Buying tap and die set. SAE or metric first? #5391126 04/01/20 05:47 PM
HawkeyeScott Offline OP
About to buy a tap and die set to clean (or cut new) threads on a stripped transfer case drain plug hole. I believe the threads are metric but if I’m cutting new ones and installing a new bolt, I don’t have to necessarily keep them that way. I’m probably leaning metric, though, in hopes of cleaning up the threads that are there, and cutting all new ones as a last resort.
Any recommendations on buying metric or SAE? My goal for now is to buy just one set.
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391138 04/01/20 05:54 PM
K
Kira Offline
K
Don't.
Any set which would include drain hole sizes will be on the larger end of the size spectrum be it English or Metric.
Settle on a thread size and just buy the one you need.
I haven't looked at a catalog in a long time but I'd bet there are also "paired" sets consisting of one tap and it's matching die.
No need to buy a set of large thread cutting tools when in all likelihood you'll never use 'em.
Then again, you know what you have in mind....I'm just mentioning it.
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391145 04/01/20 06:00 PM
T
Trav Offline
T
Be careful, some drain plugs on diffs and transfer case are NPT, not common in sets. What size are you working with and what do you want to do, fit a insert or coil or go oversize?
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391147 04/01/20 06:01 PM
I
Imp4 Online Content
Online Content
I
Old timey tool and die maker here.
It is almost never a good idea to introduce a different thread system into a product that is based on one standard or another.
Pick the correct system and then exactly the size you need.
Not sure of your circumstances but large tap and die sets (8+ pieces) are almost always a loser's choice for the shade tree mechanic. They're expensive and there's just too many sizes you're buying that you will never use.
Best bet is to find a buddy or acquaintance that is a machinist or mechanic. Borrow the size you need and nothing more.
Or, buy only the size required from Ebay or Amazon.
Problem solved.
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391150 04/01/20 06:03 PM
H
HangFire Offline
H
If it is a one time need, as Kira said just get that one tap.
If you primarily service modern cars, often or in the rust belt, get a small quality set of Metric most used sizes, and then add oddball sizes as needed, one by one. You will find yourself using them to clean up threads, not just tap holes and make bolts.
If doing old SAE cars or plumbing and house work, then it's SAE. Same thing.
If you really needed the big set, you would know it, and already have it... Unless you're embarking on a custom framed race car or some other grand metal project.
Various musings: http://hangfire.net
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391158 04/01/20 06:11 PM
Thanks. My issue is that I took the drain bolt to the hardware store to find out what size of tap I needed. The guy put a nut on it and said it was 14mm, 2 pitch. Ordered a tap in that size from Amazon since no local stores had it and when it came, it was too small. It clears the hole entirely. Based on the slow Amazon shipping, this cost me about two weeks. (I’m still not clear on how I ended up with the wrong sized tap based on my field research!)
So, my goal in buying the set was to avoid chasing a second or third tap that doesn’t quite work and get the situation resolved soon, even if it’s a little pricier. Maybe a better decision is to order a few more single taps at once and return the ones I don’t need.
Thanks for the help. This is why I appreciate this site.
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391159 04/01/20 06:11 PM
Chris142 Offline
If I was going to do this I would pick the Bolt/Plug then get the tap to match it. You do not want to tap a hole only to find out that you can't find what you need to properly screw into it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391170 04/01/20 06:25 PM
T
Trav Offline
T
How is the correct size tap supposed to work in a stripped out hole? It is going to be as loose as the original bolt. If this is holding fluid use a Time Sert M14x2 if that is the correct size.
On second thoughts give the job to a pro and save yourself the possibility of buggering the T case.
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391181 04/01/20 06:39 PM
Only the first three or four threads on the case are messed up. The 14mm tap clears those and the good ones, too. It was never going to be the right size.
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391189 04/01/20 06:47 PM
The Critic Online Crying
Online Crying
I really like this set:
https://www.astrotools.com/automotive-tap-die-set-metric.html
For $62, you get all of the common automotive metric sizes. I have a set and it works fine for limited use.
If cleaning up the threads does not work, you will need to do a thread insert. I prefer timeserts, other people prefer Helicoil.
Edit- just noticed the M14x2. That is not included in the kit and isn’t exactly a common size either. In your case, just buy the M14x2 separately.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391196 04/01/20 06:52 PM
I
Imp4 Online Content
Online Content
I
What vehicle year, make, model, and drive train?
Maybe it's just better to tell you the correct size at this point....
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391233 04/01/20 07:21 PM
Z
zzyzzx Online Sleepy
Online Sleepy
Z
Metric.
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391258 04/01/20 07:42 PM
It’s a 2008 Suburban 1500 with the 5.3L and 4L60E.
Here’s the plug: https://www.amazon.com/ACDelco-19133162-Original-Equipment-Transfer/dp/B010GNXS72
Thanks.
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391298 04/01/20 08:21 PM
9
92saturnsl2 Offline
9
I purchased a set of both SAE and metric at Harbor Freight and it was money WELL spent. There is nothing worse than being in the middle of a project / repair and have a stripped fastener stop you dead in your tracks. I put up with that enough times that I broke down and bought both sets and don't regret it for a second. It's come in handy so many times (and not just automotive stuff) I've lost count.
I don't see the exact product I bought (it was 7-8 years ago) on their website, but it's very similar to this: link
Mine has a larger metal case, but might otherwise be the same product, same titanium coating. I remember paying about $75 each. Harbor Freight has a cheaper carbon steel set, but I've learned to avoid the cheapest Harbor Freight tools like the plague, but I've had excellent luck with their mid to high tier products. I've really worked many of these tap & dies and they've never given me a bit of trouble. Would I trust HF tools if I needed them to earn a living? No. But typical homeowner / backyard mechanic type use where they'll get used a couple-few times a year, they work great in my experience.
If you have to choose one set or the other, I'd go with metric if you're primarily using these for automotive stuff. That should cover most any car made from the mid 80's forward.
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: Buying tap and die set. SAE or metric first? [Re: HawkeyeScott] #5391309 04/01/20 08:33 PM
P10crew Offline
Don’t run a tap into any engine or tranny parts. Use thread chasers. Many companies offer them. I got my sets from ARP.
