Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
38 registered members (Amkeer, CapriRacer, Aerojoe, 87sammy, 53' Stude, 4 invisible), 934 guests, and 26 spiders.
Topics306,116
Posts5,287,825
Members71,604
Tacky additive in bar and chain oil #5390332 03/31/20 05:02 PM
T
TreyT42 Offline OP
T
I've been researching what the additive in 30 SAE tacky oil that makes it hang on to the chain when it's whooping around at a couple thousand feet/sec. and am wondering if the vegetable oil alternatives have this "anti-sling" additive(s) in them as well.
To my knowledge, this additive is some sort of crosslinked rubber-ish polymer that must be made of hydrocarbons to be so compatible with the oil base lubricant.
Is there any anti-sling in the alternatives and does anyone know what the additive(s) is/are? I am trying to understand the mechanism for how the anti-sling additive works instead of just being thick enough to hold on to the bar and chain. Anyone have any experience or knowledge?
Re: Tacky additive in bar and chain oil [Re: TreyT42] #5390416 03/31/20 07:01 PM
R
Rand Offline
R
Re: Tacky additive in bar and chain oil [Re: TreyT42] #5390491 03/31/20 09:16 PM
Chris142 Offline
Stp?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Tacky additive in bar and chain oil [Re: Chris142] #5390568 04/01/20 12:53 AM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by Chris142
Stp?
Similar but not the same. The old STP contains an OCP that is a VII but with a different chemical formulation than does a tackifier.
A tackifier and an OCP VII is a copolymer solution of ethylene and propylene. The ratio of ethylene and propylene determines if the final solution will be either a OCP VII or a Tackifier.
Hydrocarbon chemistry is Pretty cool.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Tacky additive in bar and chain oil [Re: TreyT42] #5390582 04/01/20 02:17 AM
K
Kamele0N Offline
K
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Tacky additive in bar and chain oil [Re: TreyT42] #5390636 04/01/20 06:28 AM
T
TreyT42 Offline OP
T
Thanks for the links and info guys...definitely on the right track.
Any knowledge what the tackifiers are? I know polyisobutylene (PIB) was a big one back in the day, but I'm not sure what they used to cross link it since I can't see how PIB itself can be crosslinked.
I'm trying to increase the string and cling propensity to avoid the misting that was mentioned in the other posts without increasing the viscosity too much (or at all in a perfect world).
