Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
62 registered members (4WD, ABN_CBT_ENGR, alarmguy, Astro14, Best F100, A_Harman, 5 invisible), 1,069 guests, and 67 spiders.
Topics306,117
Posts5,287,836
Members71,604
Briggs Stratton Quantum engine surging #5390178 03/31/20 12:53 PM
A
alex_at Offline OP
A
Hi,
I have an old lawn mower that does the job just fine, except the briggs stratton quantum engine is surging.
I disassembled the unit to find that black mixture/speed governor on top of the carburator is constantly moving when the engine is running. If I block it so it can't move the mower runs fine, no surging. See picture attached
How to fix this?
Is the spring loose, a screw loose or do I need a new carb?
Thanks,
Alex
[Linked Image]
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390190 03/31/20 01:06 PM
Z
ZebRuaj Offline
Z
Autochoke?
Spring is doing its job. You probably just need to clean out the carb.
~I fix stuff.
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390194 03/31/20 01:08 PM
samven Offline
The governor is hunting. Might be a weak spring or linkage is dirty and need clean/lube. If the spring is weak it is constantly overshooting, falling back then repeat. If things are dirty it binds then over corrects then drops back and repeats. Make sure you note what hole the spring is in if it has adjustments. You dont want to start playing with those you will only make it imposable to figure out. Use a soft tooth brush and brake cleaner to get all the grease and dirt off then just a touch of oil and retest before you buy a new spring.
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390195 03/31/20 01:10 PM
J
JohnG Offline
J
Is this under load or at idle? If it's at idle, without load, try reducing the idle speed a little. You are definitely getting "into" the governor with the surge. I've seen it a lot. Usually putting a load on the engine smooths this action out, but not always. Pressure washers seem to be the biggest offenders.
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390199 03/31/20 01:16 PM
A
alex_at Offline OP
A
no issues at idle, but as soon as I set the speed to max it starts .....
carb is getting a clean tomorrow maybe, I will note what setting the sping is.
If nothing helps, a new carb is only 25$ shipped.
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390224 03/31/20 01:54 PM
W
WhyMe Offline
W
surging in my experience means it running lean. Clean the carb orifices and see what happens
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390226 03/31/20 02:01 PM
J
jakewells Offline
J
Either a dirty carb or a worn throttle shaft.
2001 Mercury Cougar base 2.5l CD4E automatic.
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390229 03/31/20 02:03 PM
R
rocky37 Offline
R
The mower is surging/hunting because the carb is dirty. The main jet needs to be cleaned. You may be able to clean the carb without removing the carb. There is a main jet at the bottom of the carb that retains the fuel bowl. Take that bolt/jet off and spray carb cleaner through it. This may be enough to fix the issue. The reason why the engine is surging is because the carb is causing a lean condition and this causes the engine to slow down. After slowing down, the condition is back to normal and the governor will increase engine speed and then the condition starts all over again...surging.
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390242 03/31/20 02:23 PM
B
Brybo86 Offline
B
i had a mower with that same engine
after starting it one spring it was surging
try holding the spring/throttle in a fixed position, if it still surges then your carb is dirty
if holding it still (try holding it still at low and high RPM) stops the surging then you just need to buy a new governor spring
i bought a new spring and the mower is still running great to this day
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390250 03/31/20 02:38 PM
M
mk378 Offline
M
The part that is moving is the throttle plate. With no load, the engine should run steady and slow if you hold it against the stop on the slow end.
If it stalls out when you do that, the low speed circuit in the carb is clogged, and that will cause the rpm to surge up and down with no load. Basically the engine stops firing completely instead of going slow-- as it slows down too much the governor pulls the throttle toward wide open, and then it starts firing again and revs up too much. This repeats as the surging pattern.
Some versions do not have a low speed circuit at all and they are prone to surge anyway.
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390271 03/31/20 03:13 PM
Convert Offline
Clean the carburetor, the emulsifier tube has for tiny little holes in it towards the threaded end ,clean those holes out and everything should be fine .had the same problem with my snowblower with a Briggs engine.
TOMB
TOMB
2006 Volvo XC90
2013 Toyota Tacoma TRD Sport
1976 Moto Guzzi Convert
USAF 1966-1970
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390284 03/31/20 03:40 PM
L
Lubener Offline
L
Carb needing cleaning, rebuilding or replacement.
The "thinking" man's friend.
Re: Briggs Stratton Quantum engine surging [Re: WhyMe] #5390381 03/31/20 06:15 PM
E
eljefino Offline
E
+2
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390539 03/31/20 10:56 PM
M
motor_oil_madman Offline
M
It will suge if you run it without the air cleaner on just fyi. Had that happen once while I was testing my carb cleaning job. Then it stopped once I put it back on.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Briggs Stratton Quantum engine surging [Re: alex_at] #5390684 04/01/20 07:50 AM
A
alex_at Offline OP
A
so update:
Took the carb off and opened it up. It was pretty clean, I was expecting varnish and gunk.
I didn't have carb cleaner on hand, shops are closed due to corona. But brake cleaner and my portable mini compressor did the job.
Now it runs fine. No surging, just nicely running.
After reassembly I managed to completely flood the engine, i was priming too much. But got it running.
Changed the 3 or 4 yr old 5W-40 A3/B4 to Petro Canada Duron XL 15W-40.
Discovered that the cutting knife was pretty loose - so fixed that too.
Now the mowing season can begin.
Thanks everyone for your help.
