Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
55 registered members (Best F100, ABN_CBT_ENGR, A_Harman, BigGeo, Amkeer, 4 invisible), 1,032 guests, and 100 spiders.
Topics306,117
Posts5,287,833
Members71,604
Are harbor freight generators any good? #5390162 03/31/20 12:37 PM
NavyVet88 Offline OP
Topic.
For one small deep freezer and a regular size 90’s fridge. Should it be needed.
2013 Honda Civic LX 1.8L 178k M1 HM 0w20 with Fram XG7317
2002 Ford Ranger Edge 3.0L 67k Castrol Edge 5w30 with Fram XG3600
Maintenance Technician by trade, working class for life.
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390170 03/31/20 12:44 PM
Chris142 Offline
I have several. I have one of the 2stroke ones that I have had for many years. It has so many hours on it I quit counting. I also have the 3200w-4000W 4 stroke one and It's been great. The 2 things you need to do to them is to throw away the sparkplug that comes with them and replace it with a name brand one,preferably a Denso or NGK. Also use quality oil,especially important in the 2 stroke one.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390174 03/31/20 12:49 PM
Thanks friend. Definitely gonna be picking one up soon.
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390182 03/31/20 12:55 PM
samven Offline
I have had the 3200-4000w generator for 7 years now and it is still running although I dont use it that often. I bought it for backup for the freezer and some lights incase of power outage. I will get it out every year or so if it has not been used and start and run a half tank through it. I always drain the tank and carb bowl, close the choke and pull the cord a few times to clear the carb passages then pull the plug and fog the cylinder. It always starts on the second pull when I get it out.
Re: Are harbor freight generators any good? [Re: Chris142] #5390268 03/31/20 03:09 PM
DIY4quality Offline
Great tip on replacing the spark plug!
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390285 03/31/20 03:43 PM
M
Miller88 Online Content
Online Content
M
I have had the little 2 stroke one for a few years. The spark plug that came with it is junk. Otherwise it's been great. I can also say that I've run the thing WAY over capacity for hours on end and it just keeps taking it! It's a great little generator!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390314 03/31/20 04:43 PM
A
Alfred_B Offline
A
Yes, they are good. I have had good luck with the spark plugs on the one I have bought but most people replace them because they are unknown brand.
I like the two stroke one as an ironic symbol mainly. I think it's licensed from Fuji or some other Japanese manufacturer.Time tested design.
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390322 03/31/20 04:49 PM
M
mk378 Offline
M
Do they still have a two cycle model? I don't see one on their website.
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390342 03/31/20 05:13 PM
A
Al Offline
A
If it is going to be used for a fridge..look at the one that has the highest running amps/watts. The gen needs to be at least 2.5 times that. Keep the gen as small as possible. It will likely be more efficient. You need to figure out how mush gasoline you need...its probably a lot more than you thought.
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390347 03/31/20 05:16 PM
Cujet Offline
I have the little 2 stroke. It's not a high quality generator and I don't expect it to be. Per the online suggestions, I installed an NGK plug, replaced the fuel line and mix the oil at 32 to 1. It's been fine up until I broke the fuel shut off lever. I ordered another, which is just as poorly made, and backwards too!
The air filter is does not seal tightly and despite regular cleanings, it has dirt beyond the filter element. Probably best to run this unit on a box or stand. Otherwise it will ingest dirt.
The larger units use the same type of low build quality. Not awful, but certainly not robust.
Champion makes much the same product line, but they are built to better specifications.
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390367 03/31/20 05:50 PM
A
atikovi Offline
A
Got one from Pep Boys 10-15 years ago. 3500 watt I think. Probably haven't run it more than 10-15 hours but seems well made. Can't remember when/if I changed the oil on it though but did replace the carb last year for about $10.
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390385 03/31/20 06:19 PM
J
JimPghPA Offline
J
Mine are not Harbor Freight. I have a Coleman Powermate 4 cycle 5500 running Watts / 6250 Watts peak that has a 10 Hp Tecumseh 4 cycle engine, and a 2200 Watt Generac inverter type.
Along with draining all the fuel and draining the carburetor for long term storage I fog the cylinder with Sta-Bil spray cylinder foaming oil and put a clean rag over the spark-plug hole and pull the rope a few times, then put the spark-plug back and with the ignition turned off pull the rope a few times, then pull the rope slowly stopping when the you begin to feel the rope being hard to pull because of compression of the cylinder. This leaves the valve springs not in full compression which one of them would be if a valve was open.
Then I spray the inside of the carburetor with WD-40 and be sure to get the tube in the center of the carb where the fuel comes up, and if you can see them get it in the very small hole towards the intake of the carb. WD-40 is very combustible so do this only when you will not be pulling the rope any more, because the engine might start from compression heat even if the ignition is off.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390391 03/31/20 06:22 PM
J
JimPghPA Offline
J
If you do not have Sta-Bil spray fogging oil a spoon-full of any clean unused auto oil is good enough to use.
An additional advantage of lightly pulling the rope and stopping on a compression is that by closing both valves you prevent moisture in the air from getting into the cylinder during storage.
JimPghPa
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390393 03/31/20 06:25 PM
spasm3 Offline
I have the hf 4375 unit, i do not have many hours on it, but it handles what i need fine. Starts easy, seems to run about 3.75 hrs on a gallon. Holds 4 gallons. I run mine every 2-3 months for about 10 minutes. I like that it has a fuel shut off, so i can run it dry if i want to.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Are harbor freight generators any good? [Re: NavyVet88] #5390429 03/31/20 07:22 PM
spasm3 Offline
Originally Posted by NavyVet88
Topic.
Buy a small one for fuel usage. if just that, a 2000 watt unit would do.
