charge 12v truck batter with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
chapys, DaaBoss, C6H8O7, Jcvjr, Haywood
71590 Registered Users
89 registered members (830Lee, aquariuscsm, 86cutlass307, 2015_PSD, 2004tdigls, 53' Stude, 12 invisible), 2,643 guests, and 36 spiders.
Topics306,129
Posts5,286,992
Members71,590
Trailblazer tire pressures #5389930 03/31/20 06:01 AM
Z
zrxkawboy Offline OP
Z
I recently picked up a 2007 Trailblazer 4x4. The door sticker says 30 psi front and 35 psi rear. The recommended front pressure is lower than I would expect. For anyone with experience with these vehicles, what do you run for tire pressure? Thanks!
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Trailblazer tire pressures [Re: zrxkawboy] #5389931 03/31/20 06:03 AM
F
FordBroncoVWJeta Offline
F
32 front 36 rear.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Trailblazer tire pressures [Re: zrxkawboy] #5389947 03/31/20 06:43 AM
Char Baby Offline
I usually start with the recommended PSI listed in the door jamb and tweak the PSI up/down based on my preference and/or need the way FBVWJ has done. This tweaking could change ever so slightly as tires wear and when new tires are installed bssed on tire brand/model/type(load rating).
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Trailblazer tire pressures [Re: zrxkawboy] #5389959 03/31/20 07:18 AM
W
whatnext Offline
W
^^ this. Start with the listed pressure. Watch how the tires are wearing and go from there.
I know, lots of drivers don't look at their tires unless they are rolling away from the vehicle on the road. So for those types, why does tire pressure matter?
On an important note: the listed pressure for the rear tires may be for a full load of passengers and cargo in the vehicle. So with only front seat passengers, the rear tire pressure should not be more than the fronts for even tire wear.
Re: Trailblazer tire pressures [Re: zrxkawboy] #5389964 03/31/20 07:21 AM
F
Falcon_LS Offline
F
Mine is export spec with 255/60R17 tires instead of 245/65R17, which specs 35 PSI all round. That said, I keep mine at 38 PSI.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: Trailblazer tire pressures [Re: zrxkawboy] #5389990 03/31/20 08:04 AM
M
MasterSolenoid Offline
M
My vehicle is the same - front @ 30 / rear @ 35
I aim for 31-32 all around / it makes rotating the tires easier.
With the warmer weather coming, you will need to let some air out.
Get yourself a good (digital) Pressure Gauge
It makes life a lot easier.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Trailblazer tire pressures [Re: zrxkawboy] #5390000 03/31/20 08:15 AM
K
Kira Offline
K
Being Spring with its varying temps, the OP can monitor seepage.
My recently restored all seasons are at 40 now but I check 'em frequently in Spring and Fall. Now that's excitement.
Re: Trailblazer tire pressures [Re: zrxkawboy] #5390016 03/31/20 08:43 AM
6
64bawagon Offline
6
When I had my 07 I ran the tires at the pressure on the placard. I dont figure I am any smarter than the people that designed, built and warrantied the vehicle and the tires.
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Trailblazer tire pressures [Re: zrxkawboy] #5390048 03/31/20 09:28 AM
chemman Offline
I have run 30 psi front and 35 psi rear from day 1 and have not had any handling problems nor have I had any tread wear problems with my '04 TrailBlazer.
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: Trailblazer tire pressures [Re: zrxkawboy] #5390111 03/31/20 11:21 AM
B
BrianF Offline
B
I have run 35 psi front rear as my lower end and upwards of 40. I try to keep them all at 38 psi cold as it seems to be the best compromise at handling, ride and fuel economy. Splitting hairs with only a few psi but I prefer on the higher end.
I have had as good of tire wear as I can for my driving conditions. The wear is nice and even across the tire.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
